RTV1100 (2009) Wire question
/ RTV1100 (2009) Wire question #1
SpudHauler
Gold Member
Canada
RTV1100 2009
Does anyone know what the Blue connector located behind the panel by the Orange differential lock button is used for?
It has 4 wires, Black, Red/Yellow, Green/White, and Blue.
Can't seem to find any reference in the manual, but must be for an additional piece of equipment.
/ RTV1100 (2009) Wire question #2
The only thing I see on the schematic that isn't a factory used connection, that appears to have that color combination would be an emergency beacon. Can't be sure though, it's location isn't shown.
I have the workshop manual and parts book. What page did you find your information on?
/ RTV1100 (2009) Wire question #4
I only have the schematic..not the manual.
Thanks, I am going to use power from this set of wires to power relays for my winch and another for the 12 volt hydraulic selector valve. Neither have a big draw as they only feed two relays, but it is great because one is live with the key on and the other is always live and should work well for my winch.
I'd be interested in getting all of the schematic if possible.
Great help!
Thank you.
Brian
/ RTV1100 (2009) Wire question #7
Great help!
Thank you.
Brian
Actually there is a winch lead intigrated into the machine, somewhere...I'll scan the whole thing for you..it's 2 pages..so you'll have to put it back together.
Yes, I know about the winch lead, it is under the bonnet up front on the right hand side and they want you to mount the contactor box back by the radiator. It's too far away so I don't use it. Perhaps when I add something else it will come in handy.
In my situation, I only mount the remote connector by the diff lock button and don't use Warn's dash mount switch. Kids play with too many buttons and would ruin the winch without knowing what they have done. My RT40 Warn doesn't have the wireless remote, which now I wish I had ordered. Anyway it works great so hopefully it gets very little use, as in I don't get stuck!
/ RTV1100 (2009) Wire question #9
Here you go..Hopefully they're readable..They're upside down..So you'll have to rotate them
  • RTV1100 Schematic10001.pdf
  • RTV1100 Schematic20001.pdf
Thank You very much. Prints came out just fine.
/ RTV1100 (2009) Wire question #11
You're wecome..I might have to hit you up for something from the shop manual someday...
/ RTV1100 (2009) Wire question #12
Well since this is a wire question page can anyone tell me what the red/yellow wire with female connector and the black wire with the male connector are for in the fuse box on the rtv 1100? Also what would be a good way to disable an RTV 1100? I had some guys at work move my bota across the parking lot. I left my door unlocked so I had it coming, but is there anyway to lock it into gear so it cannot be put into neutral or a way to keep it from starting with a hidden switch?
Looking at the wire diagram, it looks like it's for the "beacon switch harness". Most of these types of things are for accessories they sell.
/ RTV1100 (2009) Wire question #14
Thanks a lot for solving that puzzle for me. I'll make a note in my owners manual of it. Thanks again.
/ RTV1100 (2009) Wire question #15
Open the door to the fuse box and pull one of the fuses out of the block, then it won't start.
equipman, he is referring to someone putting the trany out of gear and pushing the rtv to a new location.
perhaps some kind of lock on the shift gate of the trany or a lock on the emergency brake would stop them in cases where the doors is left unlocked.
Best and simplest solution, lock the doors.
UNUSED 2026 INDUSTRIAS AMERICA 7014 7'X14' DUMP TR (A62130)
UNUSED 2026...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
30 Yard Roll Off Dumpster (A61166)
30 Yard Roll Off...
UNUSED JCT DUSTLESS BLASTER (A62131)
UNUSED JCT...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
