2001 JD 2520 fuse block
/ 2001 JD 2520 fuse block #1
cdavid1944
Cedar Falls, Iowa
JD 2520, 1948 Ford 8N
The manual I have for my JD 2520 shows a fuse block with multiple fuses and empty spaces. On my 2001 JD 2520 there is only a small connector with 4 fuses numbered 1 (10 amp), 2 (10 amp), 3 (15 amp) and 4 (25 amp). I want 12 volts out the back to run the pump on my sprayer. My question is what do 1,2,3,4 control and where do I get live 12 volts. The manual also shows a cigar lighter plug beside the rockshaft lever. That doesn't exist either. Can anyone help me with an electrical diagram for this early model? Thanks.
/ 2001 JD 2520 fuse block #2
Welcome to TBN:D
It would be best to run a new +12v power fed from the battery to power your sprayer. The factory harness is sized for very little growth, and the draw of a sprayer pump may be to much. Use 12 gauge wire and a 20 amp fuse and you will be all set.
/ 2001 JD 2520 fuse block #3
I echo the kennyd welcome. He always has good information.
You might want to check your model year. The current 2520 was not introduced until 2006. There was a different 2520 in the sixties/seventies.
/ 2001 JD 2520 fuse block #4
I'd amend that suggestion to using a currently ignition hot source to trigger an appropriately sized relay for that battery sourced power.
I like having everything shut down when I kill the engine, including electrically powered accessories/attachments.
I stand corrected, it is 2006 not 2001. Thanks for the correction.
/ 2001 JD 2520 fuse block #6
Yes, great point...I was trying to keep it simple for the OP.
UNUSED IRMC HIGH END MASSAGE CHAIR (A64281)
UNUSED IRMC HIGH...
(15) UNUSED 3 1/2' X 8' PLASTIC PROTECTION MATS (A64281)
(15) UNUSED 3 1/2'...
UNUSED X-STAR 300 GALLON FUEL TRAILER (A64280)
UNUSED X-STAR 300...
(2) UNUSED 17.5L-24 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
2017 Dodge Grand Caravan Van (A61574)
2017 Dodge Grand...
2018 Utility FS2CHA 48ft. 36 Ton T/A Flatbed Trailer (A61573)
2018 Utility...
