Tiller forward or reverse tine tiller?
/ forward or reverse tine tiller? #1
scrapper
Pennsylvania
Kubota L 3400
I gonna get a new 60" tiller for my tractor. Which is better, foward directional tines or reverse? If it matters, my ground is somewhat rocky.
Thanks, Mike
/ forward or reverse tine tiller? #2
I gonna get a new 60" tiller for my tractor. Which is better, forward directional tines or reverse? If it matters, my ground is somewhat rocky.
Thanks, Mike
A question that has lots of discussion here.
I use a reverse rotation tiller and like it a lot. However, if you have rocky soil I suggest you go with a regular rotation machine. It will kick the rocks out the back instead of bind them up into the tiller. Either way, be sure it has a slip clutch instead of a sheer pin.
/ forward or reverse tine tiller? #3
IF the rocks are big enough to get jammed up in the tiller then I would also recommend a regular forward rotation one with slip clutch. Mine too is reverse rotation but not rocks around here to worry about. Get the slip clutch regardless.
:thumbsup:
Troy
Thanks guys, I have been looking at a Land Pride reverse and the King Kutter forward. About $900 difference in the price is also leaning me towards the forward, lol.
/ forward or reverse tine tiller? #5
I have yet to hear anyone bad mouth the KK tillers. MY only concern would be with service after the sale if something should break.
:thumbsup:
Troy
/ forward or reverse tine tiller? #6
My preference is for the reverse rotation also, but I don't have rocks to worry about so I think you have gotten really good advice.
/ forward or reverse tine tiller? #7
Heed the rock recommendations. I have lots of 6" plus sized rock on my land. They are always stalling the tiller. I like the one pass operations of the RT tiller but not the rocks.
/ forward or reverse tine tiller? #8
Reverse rotation is very effective because the tines aren't pushing the tractor before the soil is properly worked.
If you have large rocks just take a more shallow bite and when the tiller bounces over a big one just back up and use a spud bar to remove it safely to the FEL.
I'm afraid there's no getting around hand labor in removing the larger rocks...but doing that will pay dividends in the future.
/ forward or reverse tine tiller? #9
Savageactor7 is right on about the labor in tilling a field for the first time. I found several rocks to big to be lifted by hand that i had to dig out of the ground. After tilling a 7 acre field I had enough rocks piles up to start a quary.
/ forward or reverse tine tiller? #10
:) One option would be to purchase a tiller that the A-frame and gearbox assembly can be reversed for reverse rotation. I know several manufactures make them.
UNUSED WOLVERINE QMP3-16-6T QUICK ATTACH PLATE (A62131)
UNUSED WOLVERINE...
2000 ITASCA SUNCRUISER 37G CLASS A RV (A58214)
2000 ITASCA...
HOMEMADE 52"X12' S/A TRAILER (A62130)
HOMEMADE 52"X12'...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
