Engine starter bolts
/ Engine starter bolts #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
I was going to remove the starter on my PT-1445, Ford industrial gas engine, and the start terminal twisted off. Yea,bummer. I thought taking off the starter would be easy, but ran into a problem. One of the starter bolts, bolts to the starter from the flywheel side. Anybody ever seen something like this. It looks like I will have to pull the engine, remove the pumps, flywheel. and don't know what else. Just stupid that all three bolts are not on the outside.
/ Engine starter bolts #2
JJ seems like when a person thinks a job is going to be easy that is when everything that can go wrong goes wrong. Hope it isn't too difficult of a fix for you. If you can get penetrating oil on the part that is still in there and let it soak for a while that might help. Probably no such luck as to have enough sticking out to be able to grip it with vice grips or channel locks to get it out and probably to much of a confined area to get a left hand drill bit to get it out. Man having to pull the engine to get a bolt out, hope something comes together for you.
/ Engine starter bolts #3
Maybe you could drill the third bolt out from the front to get the starter off. Fish the remnants of the bolt head out while the starter is off. Then install a thread insert into the block so you could use a bolt from the front.
/ Engine starter bolts #4
The only thing that comes to mind here is that maybe there is an access hole/port somewhere to get a wrench to the bolt without having to pull the engine. I vaguely remember pulling a starter on a vehicle engine years ago which had one bolt from each side, but it's been to long to remember much else. Don't think I had to pull the engine though. I hope maybe this helps.
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
2019 Chevrolet Cruz Sedan (A60352)
2019 Chevrolet...
2016 JLG 1932ES ELECTRIC SCISSOR LIFT (A59823)
2016 JLG 1932ES...
Deere 333E (A60462)
Deere 333E (A60462)
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A61307)
2020 Takeuchi...
