B2630 top link max length?
/ B2630 top link max length? #1
rglaser
Waynesville, Ohio
Kubota B2630 & ZD323
I seem to always have my top link at or near max length and since aquiring a box blade now want it even longer than it will go. My max length is approximately 22 inches center to center of pins. This brings me to two questions:
1) Where can I buy a longer top link that will fit? (Tractor supply one won't fit because the "ball" part that attaches to the tractor is too wide).
2) Did I get the incorrect top link with my tractor? (Fellow B2630 owners, how long is your top link at max length?)
Thanks in advance for the assistance.
-Rob Glaser
/ B2630 top link max length? #2
-Rob Glaser
I bought one years ago from TSC when I added Pat's because it added length to arms setting implements back further. I believe I may have beat the arms open a big with a small sledge to accept their longer arm/bigger ball or could grind ball rim off a fraction on the arm. Think others have done the grinding deal.
Thanks JT. I ground it down and got it on there. Only had to remove about a 16th from each side.
I would still like to hear top link max length from any B2630 or B3030 owners out there.
Thanks,
Rob
/ B2630 top link max length? #4
According to This the range is 15-1/2" to 21"
Thanks Inky but that is not the factory part I am refering to. That looks more like the one I got from Tractor Supply.
Any B2630 or B3030 owners willing to measure theirs for me? Purrrrty please?
-Rob
/ B2630 top link max length? #6
I have a brand new OEM one for a BX25... I can measure that if you want...
Gotta warn you though... I won't be able to post the answer until next week
/ B2630 top link max length? #7
-Rob
I will measure mine and post it Saturday ASAP.
/ B2630 top link max length? #8
The top link on my B3030 measures 26-3/4" fully extended. You must have the wrong one.
/ B2630 top link max length? #9
-Rob Glaser
OK, went to the barn to measure the length on my B2630 this beautiful morning, and I got about 26.5" from pin to pin at max extension. Seems you do have an incorrect one. If I were you, I'd check with the seller about getting the longer one free of charge. Otherwise, a local dealer, or call Messicks or Barlow to get one shipped, or the net dealer of your choice. Those extra inches can make a lot of difference, as in many things on this earth.:D
Good luck, remember me as a b2630 brother, there are others including davatk, search his posts for others as well from their replies for future reference. Hope you find one easy.
hawkhart
Thank you Toolguy and Hawkheart for taking the time to measure and post the info I needed to be sure I had the wrong top link for my tractor! I contacted the dealer and will be swaping for the correct part tonight after work. The information freely shared on this site is amazing. I owe you all another one.
-Rob
Got the correct top link from the dealer (I think). Photo is attached. Thanks again for the help fellas!
-Rob
