Hydraulic top link
/ Hydraulic top link #1
galaxie428
Gold Member
Rushville, IN
Bobcat CT230
This may seem like a silly question to some of you but I know very little about hydraulics and tractors. I have a CT230 with one set of rear remotes. I am looking into getting a hydro top link. I assume I can control it with my rear remotes without adding anything additional other than the top link and hoses. Is this correct?
If any of you have added one to your 230, what bore and length are you using?
Thanks,
Jason
/ Hydraulic top link #2
Correct, you can control it with the rear remote lever. Just add the link and hoses.
Do you have one or two controls?
I called CCM with the dimensions of my manual link and went from there. I believe I have a 2" bore and 1/4" hoses. I went with 30" hoses and put a loop in them for flexibility. I can't tell you the length and stroke due to my tractor being in another location but I can say the one CCM provided has more than enough travel in both directions for my box blade. Hydraulic top link is by far the best thing I have done to my tractor.
Thanks Sprocket.
If by control you mean the control for my remotes then I only have one lever. It has an "A" & a "B".
/ Hydraulic top link #4
Thanks Sprocket.
That will work fine for the toplink. You can add one more for a tilt cylinder or get one with a detent to run attachments with downstream controls.
You will be very happy with a hydraulic toplink though. Get one with a double piloted check valve (keeps the cylinder locked in the desired position by not allowing it to bleed down through the system)...you won't be sorry. You can get a top quality cylinder from CCM for less than $200. Hoses can be made locally. I used a piece of fuel line to figure out routing and length. Don't forget to allow for full movement of the 3pt when you get hoses made.
Ouch, since I just bought a tiller, this may have to wait a bit. I thought I saw them for around $50 or so at Agri-supply. Maybe those don't have the double piloted check valve that you mentioned.
/ Hydraulic top link #6
I too, have 1 set of remotes. If I want both top-n-tilt, do I need the second set of remotes? Is there a complete kit for top-n-tilt out there? Thanks
/ Hydraulic top link #7
Woohoo... I'll jump in too. I had the same question.. kinda.
I have a 1.5" diameter cylinder knocking about that is the right length for a top-link. My 3-point is rated to 450Kg.. It should do the job... right? :D
I'll be skipping the expensive valving: I reckon my remote will do a good enough job for me :)
/ Hydraulic top link #8
you need one set of remotes for each cylinder, for Top and Tilt- 2 remotes needed. Kits for adding another remote should be available.
/ Hydraulic top link #9
Not to be stupid, well I guess I am.... but
What is top n tilt?
/ Hydraulic top link #10
Hydraulic top link and a hydraulic side link. That way we doesn't have to get off tractor to adjust implements as often.:):thumbsup:
/ Hydraulic top link #11
OK, I know what the top link cylinder would be good for, but what would the side cylinder be good for?
/ Hydraulic top link #12
Not an expert on this either but from what I've seen t-n-t allows you lower one side (right front and right rear) so you can carve out ditches, etc.
/ Hydraulic top link #13
Top & Tilt makes adjustments of grading type implements to be made in motion while you are grading. Very very convenient. Top link adjusts the tilt of the blade front to back while the side link allows you to adjust the blade side to side which is a common necessity when road grading.
/ Hydraulic top link #14
so you put a cyliner in place of the riight side lower ajustable link?
/ Hydraulic top link #16
ahh yeah I see how that will make life much easier grading, looks like will be high on my "customizing" priority list
/ Hydraulic top link #17
Last week I was at a local dealer and saw a demonstration somebody was doing. It was for self-contained hydraulic top link. It didn't have any hoses at all. The thing made small adjustments on the fly while he used a box blade on some gravel. It was pretty slick.
/ Hydraulic top link #18
do you know who the manufacturer is?
/ Hydraulic top link #19
:drink:
I dont understand :confused2: sorry but if the cylinder was self contained how was the guy adjusting it on the fly? and where is the control to angle it. I thought the whole point of the cylinder was to place the blade the way you wanted it with pressure holding it and moving it to that angle. How did the self contained make the pressure I would think it be the same as a manual toplink Again I need a cold :drink:
/ Hydraulic top link #20
:drink:
It was probably a linear actuator.
1207 (A64280)
1207 (A64280)
2006 Ford Crown Victoria Sedan (A61574)
2006 Ford Crown...
Caterpillar Information Guides (A63117)
Caterpillar...
John Deere 2840 Tractor (A64047)
John Deere 2840...
4004SFL (A59228)
4004SFL (A59228)
2016 CATERPILLAR 299D2 SKID STEER (A63276)
2016 CATERPILLAR...
