Loader wont hold position
/ Loader wont hold position #1
Mighty Dodge
The Hereford Zone, MD
JD 4200
The 420 loader on my JD 4200 started dropping a little as it it has air in the lines. It will drop about six inches then stop. This started suddenly this week. I changed the fluid, filter & cleaned suction screen last fall. I switched the lines around so the curl circuit raises and lowers the loader....same thing. It will sometimes lift very slowly until it gets about half way up then speed up. Anybody have an idea as to what's going on?
M.D.
/ Loader wont hold position #2
The seals in the lift cylinder(s) are probably starting to leak internally, not that uncommon in these loaders. They are easy to re-seal.
Ok, I just noticed another symptom. If I just barely pull the stick back just a little the loader will drop as if fluid is bypassing through the valve. It never did this before. Still think it's the cylinders or possibly crud in the the loader valve?
M.D.
/ Loader wont hold position #4
How many hours of loader use on the 420 FEL?
Read up on the recent FEL cyl seal replacement thread, for some idea of what it entails. Is was good. I'll try to find it for you. If me, I'd chase the seals first, because it acted the same when you switched to the curl side of the valve.
Thanx
Yeah I think the cylinders could use new seals but there seems to be something else going on also. Guess I won't know for sure until I rebuild the cylinders. The tractor/loader has 613 hours on it.
M.D.
/ Loader wont hold position #6
M.D.
I would say you have a leaking cylinder seal PLUS a worned/failing valve spool.....
A double acting cylinder with bad seal will not lower anytime if valve spool is tight...unless there is a heavy load on the cylinder.....pressure will then reach the point when then work port releif valve (if there is one) will open....
If rod diameter is half the cylinder bore diameter, pressure from load will become 4 (four) times higher, when cylinder seal is leaking....so if you have load on your cylinder you will lift it with enough pump flow, but with valve in neutral this high pressure will make cylinder drop down faster than normal....especially if you MOVE THE VALVE A LITTLE BIT!!!
/ Loader wont hold position #7
Rebuild the valve! also try switching from the curl to the lift!
/ Loader wont hold position #8
Art
The OP mentioned right off that he switched the curl to the lift....and got the same thing.
Seems that would lead to the cylinders...not the valve. Or am I missing something?
/ Loader wont hold position #9
Art
yes... double acting cylinder wont drop down unless valve is leaking....here is a clue.....the volume of the cylinder rod goes where???!!!
/ Loader wont hold position #10
There is no rebuilding of these valves...The spools are a lapped fit and only sold as a kit that includes the valve body.
/ Loader wont hold position #11
Sorry AKKAMAAN, but this is just not true. I do know the theory behind what you say. However, I have had hundreds of cylinders brought into my shop. People complaining that the cylinder drifts. I explain the same thing everytime. 99% chance the piston seals are worn and resealing the cylinder will solve the problem. Outside chance the valve spool or other component is worn causing internal leakage. I rebuild the cylinder and what do you know, customer comes back and says that the problem is solved. Ask absolutely anyone in a hydraulic shop and you get the same answer. I'm no engineer or scientist, just know what I see in the real world.
/ Loader wont hold position #12
I guess the oil just moves past the seals from one side to the other...:confused3:
/ Loader wont hold position #13
M.D.
I have a question that I should have asked earlier....
Do you have POWER DOWN and FLOAT on that FEL, in addition to the LIFT function...or just lift and lower by gravity???
With float it would take a four position valve though...
/ Loader wont hold position #14
I do Agree with what you say about the piston seal. I have not said that Piston seal wont be bad. What I am saying is that The valve MUST leak as well....Otherwise the cylinder wont go down!!
This might be hard to understand, but the volume difference between capped side and rod side of piston, equals the volume of the rod. And when cylinder drops, rod goes into the cylinder....if seal is bad, pressure on capped side and rod side will equalize ae the cross area of the rod is the net piston area...and to drop down the volume of the rod need somewhere to go....and that will be out through the valve.......and if this valve have a spool for single action (even though the cylinder is a double action), the oil will leak out through the wide open rod side drain workport.
If cylinder is true double acting, the oil volume of the rod, MUST go out (leakage) trough one or both work ports (spool valve lands). (the only option to that is external leakage).
To remember is that if we have a heavy load in the bucket, which create a for example, 2500psi when cylinder seal is OK, not leaking. If the rod diameter is half of the bore diameter, the pressure will be 10000psi, under that load, when cylinder seal is leaking....10000psi will almost make hoses burst, and for sure some leakage even trough the best spool valve
math
3.0" bore x-area=7.0686 force 17672lbs >> pressure 2500psi
1.5" rod x-area=1.7671 force 17672lbs >> pressure 10000psi
This can also be reviewed at Brendan Casey's Troubleshooting hydraulic cylinder drift
/ Loader wont hold position #15
I completely undersand everything you discuss. However, this theory absolutely does not hold true in the real world. Also, I have zero respect for Mr. Casey and his ramblings. He is simply the self proclaimed king of internet hydraulics. He also tells you to remove your suction strainer and throw it away.
Look, don't and won't get into a peeing match over this. Just simply stating that a worn piston seal, in the real world not on paper, will absolutely cause a cylinder to drift with no other leakages, internal or external. Simple indisputable fact. I can give you the name and phone #'s of loads of my customers that will swear to it.
/ Loader wont hold position #16
I do not like to post this, because I know you will hate me even more ....:D....but I do it for the others, that are more patient with my posts....:thumbsup:
I totally agree that most of the times (real world) a blown cylinder seal causes cylinder to drift, especially under load pressure, BUT IT WILL NEED HELP. A real bad seal is like taking the whole piston of the rod.....and all suddenly we have a single action cylinder with the "bore" size of the rod.....If cylinder drifts, where is the oil going out???
If no external leakage, or work port relief valve.....the spool is the only option!!! PERIOD!!!
Now we have a few spool options that can cause the drift!!!
1> Natural leakage, designed by valve manufacturer, this wont make cylinder drift very fast though....but faster at 10000psi than designed 2500psi....
2>The spool is designed with constant drainage to tank on port connected to rod side of this "double acting" cylinder (when cylinder only can get lowered by gravity)
3>The spool have some wear from long time operation and the spool leakage is increased....will create (much) faster cylinder drift than point 1>
PS
The reason why the cylinder seal is so common cause for drifting, is that the seal can break down instantly, but the spool need 1000's of hours operation time before it is worned enough cause drifting by it self. But together with a leaking seal they both need each other s leakage to cause the drift
Wow, this thread livened up. I ordered the cylinder rebuild kits today. I'll let everyone know what happens after the rebuild.
Thanx for all the info
M.D.
/ Loader wont hold position #18
M.D.
I am just down the road a piece if you get in a bind;)
/ Loader wont hold position #19
M.D.
I am sure the cylinder is going to be fine after a new seal kit, but as I posted earlier, depending on what kind of spool you have on the rod side port, there could be an valve issue as well!!
Do you have force down on the loader??? Or just power up and gravity down??
2017 Ford Transit 250 Cargo Van (A64556)
2017 Ford Transit...
Kivel Quick Hitch Skid Steer Attachment (A64553)
Kivel Quick Hitch...
SEARS ELECTRIC AIR COMPRESSOR (A64276)
SEARS ELECTRIC AIR...
INDUSTRIAS AMERICA 2426 - 10' OFFSET DISC HARROW (A64277)
INDUSTRIAS AMERICA...
New 1.5x27 Ratchet Strap (A65583)
New 1.5x27 Ratchet...
Tropic Trailer 18ft T/A Flatbed Equipment Trailer (A64553)
Tropic Trailer...
