Plumbing remotes - need help
/ Plumbing remotes - need help #1
Jay4200
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
I want to plumb a couple of rear remotes on my L4200 to run hydraulic chute controls for my snowblower. My tractor only has a single set of 'power beyond' lines in the rear (used for my backhoe), and I have to unplug the hydraulics from the 3pt hitch to run them, so I can't run a 3pt implement and have rear hydraulics at the same time.
I don't have any specific plans yet, but I think the best place to tap in would be my FEL controls, since I'll never be using the bucket and blower at the same time. Does that sound reasonable, or should I be looking somewhere else? Should I consider re-plumbing the machine completely (power beyond vs. 3pt hydraulics is kinda stupid), or just kludge in specifically what I need? I guess I need a couple of dual-acting valves and some hoses and connectors. Sound right? If I find a set of feed hoses, how do I tell which is supply and which is return? How do I tell what size/type connectors that I need to tap into existing stuff? Is there a link with connector dimensions somewhere?
Where is the best place to buy the equipment that I need? I found Surplus Center a while back for valves and such, and found a guy on the 'net a few years ago that did hydraulic lines for something like $1/foot + connectors, but I don't know if I still have the URL for that one.
I have zero experience with mucking around with hydraulic systems, and don't know anything about this type of project, so I have a lot to learn, and I'm looking for any and all information and/or suggestions.
thanks much - JayC
/ Plumbing remotes - need help #2
Jay,
When your backhoe is removed you plug two hoses together correct? These are the hose you can plumb your new valve into and not loose 3PH operation.
Jay,
Hey Kenny - how's it goin'?
I don't think I am supposed to plug two hoses together (never ran w/o the backhoe, so I'm not sure). I would assume that if I connected the BH connections together, I'd short-circuit the hydraulic system and nothing would work. Is that not correct? The BH 'power beyond' is not valved, and has two female quick disconnects, so when I disconnect the BH they just sit there. The way it is plumbed now, at least as far as I know, the high-pressure hose that powers 'power beyond' the in the back is disconnected, and another is plugged in, which powers the 3pt. I called the shop that had it last before the PO a few years ago when I messed with it the last time - I think that they plumbed it, and they told me that the BH take the 3pt hitch hydraulics. I've never actually connected and run the 3pt, so I'm not sure.
Assuming all above is correct, it seems to me that I could simply stick a tee in where the BH and 3pt high-pressure hoses connect, which would power them both at the same time. Then I could just plug a couple of remote valves into the rear 'power beyond' hoses.
JayC
/ Plumbing remotes - need help #4
100% backwards. The fluid has to go somewhere, so the hose MUST be connected together if the BH is removed. The pump is always pumping fluid if the engine is running. If the fluid can't flow then your PRV (pressure relief valve) will pop open and your engine will lug down-the fluid will overheat if you let it run this way.
Are you SURE they are both female? One should be, but the other should be male so they can plug together. I understand it's not valved,that is what a PB circuit is-a constant flow of hydraulic oil.
No, you cannot Tee into any high-pressure hydraulic lines. The fluid will "take the path of least resistance" and nothing would work well.
Can you take some detailed pictures of your setup?
/ Plumbing remotes - need help #5
If it were me, and I'm just a rookie at this mind you... I'd start from scratch and take the return line from the loader valve, which should be "power beyond" capable to run the 3 ph as well, and run that to another power beyond capable valve (two spool would be ideal, 4 way 3 position) One spool would be detented in all three positions. You really only need a two position spool, but I'm not sure if you can get one combined with a 3 position as well. Anyway, the first spool runs your backhoe connections in one detented position, and is in neutral in the center position. The second spool is a straightforward 3 position, spring centered spool, to operate the snowblower chute. The return (power beyond) from the new valve will go to the 3 ph inlet, and the return from that will go to your tank connection. No tees anywhere except possibly on the tank return line, no pressure there so it doesn't matter.
I may be all wrong on this, if I am please show me the error of my ways, I'm still learning.
Chilly
Why does the fluid have to go somewhere? It doesn't go anywhere when the backhoe is connect and I'm not pushing any controls, at least I don't think it does. The high-pressure side should just sit there at high pressure (?). Or, does a valve actually run in bypass-mode until you push it one way or the other?
Definitely both female. They are also hard-mounted to the tractor with a quick disconnect sleeve, so if you forget to unplug the hoses, they pop off by themselves as soon as they are yanked - good thing too, since it only took me twice before I drove away with them connected.
I don't understand this either. There surely isn't a pump for each path, so all of the paths have to be teed somewhere. Since I'll never use the bucket and rear remotes at the same time, I figured that would work fine.
Maybe my base understanding of the system is flawed. I am assuming that the hydraulic pump creates a high-pressure side, so all of the supply hoses sit at full pressure (2500PSI or so) all the time. When a valve opens, that pressure forces fluid into a cylinder, and the fluid from the other side gets pushed through the low-pressure side into a reservoir, to be sucked up by the pump to maintain the high-pressure. Is this not how a hydraulic system works? Are you saying that a pump runs as a circulator, and only builds pressure when the return path is closed off? Maybe I'm confused between an open vs. closed center system - don't know what my Kubota has.
JayC
/ Plumbing remotes - need help #7
I left a post on MTF but here is a simple reply. I would assume you have open center hydraulics, so hydraulics does not stay in 2500 psi or you will be running in relief causing oil to heat up. If you had a closed loop then you would be staying at 2500 psi with propably a variable piston pump used on construction equipment. The valve on open center when actuated will close off flow down stream and redirect it to cylinder allowing you to get up to 2500 psi or what ever pressure it takes to move to that point. May only take 1200.
Thanks - I read them both. I guess I misunderstood the fundamental theory behind the system. I found a couple of good descriptions on the web, so I'm starting to get it. I'll have to get some verification on that hose jumper though. I'm going to call the dealer that plumbed it today and see what I can find out.
thanks again - JayC
/ Plumbing remotes - need help #9
Because the pump will blow up if doesn't. You have a constant displacement pump so it is ALWAYS pumping.
Your valve are "Open Center", which means that the fluid flows through the valve when it's in neutral.
See above description.
Then you would need a jumper to "complete the circuit" when the backhoe is removed.
Remember, the valves are OPEN CENTER so the fluid flow THROUGH them when it in neutral. If you Tee a valve in-then try to get pressure from it the fluid will "take the path of least resistance" and flow through the another valve. All valve MUST be in series.
It is. I suggest you search some in the Hydraulics forum. ALL this has been discussed 100's of times. Terms like "power beyond" and "remote" will return hours of reading.
When all valves are in neutral, there is very little pressure developed-about 500 to 800 PSI or so due to the resistance the hoses, fitting and valves create to the flowing fluid. Only when the fluid is forced to due work and meets resistance (like from trying to move a cylinder) is pressure developed.
Basically, yes-that is what I am saying. It's because your system is "open center" and has a constant displacement pump.
I have been describing OC systems. What you are describing is a CC (closed center) system that uses a variable displacement pump.
Open center.
Again, I ask you to search some-maybe you will read another description that explains it better than me.
/ Plumbing remotes - need help #11
It's taking me a while to get my head around it as well, but it's coming clearer now. Reading here has helped a lot. You don't always get everything in one flash of revelation, to me it's more like a piece of the puzzle drops into place one at a time.
The power beyond idea took me a while, once I understood that everything had to be in series it made more sense. I'd never heard the term before I got into tractors.
The variable displacement pump/closed center, fixed displacement pump/open center relationship was another light bulb moment.
I find people confuse open and closed center systems with valves that block flow to a cylinder or motor and those that allow it to move freely when not being supplied with flow.
Chilly
Thanks for your descriptions Kenny. Yes, I misunderstood the system - it is OC and now I get it. I found some good reference material and educated myself on the system basics. I also called the dealer that set the machine up many moons ago, and whomever I spoke with the first time apparently gave me bad information, which I think caused much of the confusion on my part. It turns out that my 3pt IS enabled with the power beyond, and the hose that I have to unplug/plug is a bypass that closes the loop on the power beyond run. Plugging a jumper into the hoses would do the same thing, as you suggested.
Unfortunately, this means that my 3pt might be broken, since I've never been able to make it move, but the jury is still out for that experiment. However, it also means that I can simply plug a valve set into my existing power beyond run and get the hydraulic remotes for my blower that I want without having to re-plumb anything. So, assuming I can get my 3pt to work, I should be in great shape getting my blower set up put together.
JayC
/ Plumbing remotes - need help #13
Great news Jay, glad to help. I bet your 3PH is fine...It may just be all the way up now and with no weight on it, it won't drop. Take that BH off and check it out.
/ Plumbing remotes - need help #14
JayC
if your backhoe is a 3ph model, and you can't get the 3ph to raise or lower while it is attached, that is understandable. my 3ph backhoe (woods 7500) has a diagonal brace that essentially goes from the bottom pins on the backhoe to the top pin on the tractor 3ph. this makes a reinforcing triangle, and you will not be able to raise or lower the hitch because of that. if you didn't have this setup, every time you put the hoe bucket into the ground, it would want to temporarily lift your hoe and 3ph arms with the hydraulics, instead of digging into the ground.
My BH is a subframe mount - I think my Woods 9000 would rip a 3pt right off. As it is, it can throw my L4200 around like a piece of tissue paper if I get a bit hamfisted with the controls (it has gotten ugly a couple of times).
I have no idea where my 3pt control is set - I know I've put it up/down, and bumped it a half-million times. Given that my 3pt is always active, it's no surprise that it's stuck up. I did set the control down and stand on it once, but I might've had the drop-speed control valve closed for all I know. I know quite a bit more about the system now, and I'm hoping to make it up to my place this coming weekend - I plan on spending some time playing around with my tractor, and should be able to find out what the deal is in relatively short order.
JayC
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2017 Volkswagon CC Sport Sedan (A64557)
2017 Volkswagon CC...
1995 Khronert 307 SS Single Comp 6,500 Gallon Insulated T/A Chemical Tanker Trailer (A64194)
1995 Khronert 307...
1989 STE 307 SS 4 Comp Non Insulated T/A Chemical Tanker Trailer (A64194)
1989 STE 307 SS 4...
2013 Ford Escape SUV (A64557)
2013 Ford Escape...
12 in. WRXLS Excavator Bucket Attachment (A64194)
12 in. WRXLS...
