Leveling an excavator
/ Leveling an excavator #1
RayCo
Chester County, PA
Kubota BX24, Case 580 Super L
Last night I was digging on a hillside with my backhoe, but used the stabilizers to level out the tractor so that I could try to create a level bottom hole. As I was digging, I found myself wondering if such a thing is possible with excavators. Since they don't have stabilizers, are you stuck at the angle of the ground that you're on? Or, is there a little bit of swaying between the platform and the body in some models to help compensate for slight slopes?
Just curious.
/ Leveling an excavator #2
Just curious.
you turn the ex up or down hill then level off with blade if it's a mini up to 10 tons or a blade runner. Not sure on the bigger ones. I've seen them tip.
So the backfill blade is designed to be rigid enough for this as opposed to just pushing dirt, typically? Good to know, thank you.
/ Leveling an excavator #5
You can also start digging in line and put your take-out in line with your low side track and then drive on it to get level.
/ Leveling an excavator #7
Also swing the bucket from side to side to 'sweep' a level work area.
Actually, that's not a very good practice unless you like working on them and enjoy buying slew rings and slew motors. They're not exactly easy to get to or cheap.
/ Leveling an excavator #8
I have the 4 way blade. It's heavy duty on my Bobcat 335. After using it, I would have liked a 6 way like Kubota has but the 4 way does a very good job and it's stout.
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
2017 FORD F-150 FOOD TRANSPORT TRUCK (A60736)
2017 FORD F-150...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
John Deere 344L Loader (A60352)
John Deere 344L...
