Leveling an excavator
/ Leveling an excavator #1
RayCo
Chester County, PA
Kubota BX24, Case 580 Super L
Last night I was digging on a hillside with my backhoe, but used the stabilizers to level out the tractor so that I could try to create a level bottom hole. As I was digging, I found myself wondering if such a thing is possible with excavators. Since they don't have stabilizers, are you stuck at the angle of the ground that you're on? Or, is there a little bit of swaying between the platform and the body in some models to help compensate for slight slopes?
Just curious.
/ Leveling an excavator #2
Just curious.
you turn the ex up or down hill then level off with blade if it's a mini up to 10 tons or a blade runner. Not sure on the bigger ones. I've seen them tip.
So the backfill blade is designed to be rigid enough for this as opposed to just pushing dirt, typically? Good to know, thank you.
/ Leveling an excavator #5
You can also start digging in line and put your take-out in line with your low side track and then drive on it to get level.
/ Leveling an excavator #7
Also swing the bucket from side to side to 'sweep' a level work area.
Actually, that's not a very good practice unless you like working on them and enjoy buying slew rings and slew motors. They're not exactly easy to get to or cheap.
/ Leveling an excavator #8
I have the 4 way blade. It's heavy duty on my Bobcat 335. After using it, I would have liked a 6 way like Kubota has but the 4 way does a very good job and it's stout.
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
John Deere 995 (A60462)
John Deere 995...
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
