3Pt Adjuster link IHC 424
/ 3Pt Adjuster link IHC 424 #1
dieselscout80
South Carolina
New Holland TC45DA
What other tractor adjuster links will work to replace the right side adjuster on a 424 3 point hitch? I'm sure the 444 will, but will the X/54/x64/74/X84/x85 series work?
Mine is about worn out.
/ 3Pt Adjuster link IHC 424 #2
I looked on Case/IH parts list for the adjuster for your tractor. They make 2 versions. One like yours, and another that the crank is almost verticle, out the top, but at a slight angle. Looks to be a little more user friendly from the operator's seat.
I googled the part number, for one like yours, and noting appeared. However, the other assembly came up with many results, and are used on lots of models.
New aftermarket adjuster assemblies can be bought in the $80 to $90 range, from just the few I checked out.
Here is the part number if you care to copy and paste, and do a search
3069056R91
/ 3Pt Adjuster link IHC 424 #3
I checked with A&I aftermarket and they are only showing the crank lever coming out the top for the 424? That is unusual. Ken Sweet
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
20ft 2-Door Shipping Container (A61567)
20ft 2-Door...
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
(2) UNUSED 14X17.5 TIRES W/8 LUG RIMS (A62130)
(2) UNUSED 14X17.5...
Baby Goat Decorative Statue (A61569)
Baby Goat...
UNUSED 44" HYD MINI ROCK GRAPPLE BUCKET (A62130)
UNUSED 44" HYD...
