HarborFreight Tubing Bender item #99736
/ HarborFreight Tubing Bender item #99736 #1
ncredleg
I was in the Raleigh HF and saw that they had a Tubing bender in stock that I had not seen before.I was wondering if anyone had any experience with it.
/ HarborFreight Tubing Bender item #99736 #2
A few years ago I bought the 7 ton Harbor Freight model for $69.99. I have used it several times and it has done a very nice job. It is a little slow, but since I use it one or twice per year it is tolerable. I would say this is one HF tool that I would recommend. :)
/ HarborFreight Tubing Bender item #99736 #3
HF sells pipe benders. Pipe is measured inside, tubing is measured/called by outside.
If you want to use it to bend tubing there is a trick. Using 1" for example. First bend a piece of 1" pipe then cut that bent piece around the side of the bend to make an insert to put on the bender shoe. Using the insert you can bend tubing.
The HF bender does a fair job, there is a learning curve to pipe/tubing bending and you will make some mistakes.
Thanks everyone. I had seen the pipe benders before that were just a bottle jack and some fixtures but this one almost looks like a proper mandrel bender.
/ HarborFreight Tubing Bender item #99736 #5
I saw a tubing roller on their website for about 180. Looks like it will do from 3/4 to 2" tubing.
/ HarborFreight Tubing Bender item #99736 #7
I would like to see them bend 2" tubing . There just doesn't seem to be enough leverage.
Bill
So, There should`nt be any crushing to the inside of the bend? I want to build a chasiss for a mini bugggy but I don`t want it to look like a Wally World swing set.:laughing:
Also , I am working on a dual axle dumper using an older Snapper rear engine rider and I would like to to keep it cohesive with the center member.Which was specifically why I was looking at the tubing benders.
/ HarborFreight Tubing Bender item #99736 #9
Bill
That is what pipe wrenches are for. The steel ones not aluminum. That gives you a place to slide the pipe over for real leverage.:D
For this kind of work you may have to look at more expensive commercial grade hydraulic benders.:)
/ HarborFreight Tubing Bender item #99736 #10
The 99736 is not the tool for building roll cages or chassis.
It will not have the power to bend the wall thickness needed for a cage, nor will it probably be able to bend a tight enough radius.
These are the low cost units that will do the job.http://www.summitracing.com/parts/HCK-WFB2
http://www.medfordtools.com/mb3.html
There may be others, google manual tubing benders.
There is a difference in a pipe bender and a tubing bender.
Usually a pipe bender wont do the job with out crimping the inside bend, which is unacceptable for a roll bar bend. As already noted you can sometimes modify a pipe bender to work, but from my experience ( running a race car fab shop for 10 years) the results are a bit spotty.
/ HarborFreight Tubing Bender item #99736 #11
I started off with an el-cheapo bottle jack pipe bender, 10 or 12 ton maybe. I then bought a set of dies for one of the $600 hydraulic benders. The set came with a 7" radius steel die that could bend 110 degrees, a strap to hold the pipe at one end, and an aluminum block about a foot long with a groove cut into it. Using some scrap steel (I made the mistake of using 3/8 plate so it weighs a ton) and copied the design of the bender the die fit on.
All and all I probably have $250 (may cost more now, I don't know) into the whole thing and have bent a dozen or so roll cages. Currently my step brother is using it to make a cage for a Suzuki Samurai. It would be easy to use a hydraulic press in place of the bottle jack if you had one. I've never used a non-hydraulic bender, not sure if I would want to bend a lot of tubing with out the help of hydraulic pressure. If interested I can get some pictures of it.
CrazyAl pictures would be great. Thanks
GT2 .Thanks that looks like a winner.
/ HarborFreight Tubing Bender item #99736 #14
Couple years back I bought a HF, the kind with a bottle jack. It was bad, flattened the inside of the bend ,not worth having, I took it back.
/ HarborFreight Tubing Bender item #99736 #16
I got the dies from Pro-Tool in FL. I did a quick search for the company and came across this website.
Tubing Bender
It's someone who, like me, made a tubing bender. The difference between his and mine is mine sits horizontal and the base of the jack mounts to the end plate. I mounted the jack so the handle to pump it sits on the bottom so it doesn't run out of oil as you pump it up. I made a simple swivel stand. Because I used a pipe bender I used one of the top rollers for the aluminum track to ride on, I just slid a short piece of pipe over the roller to give it a smooth surface. I used a 3/4" grade 8 bolt for the roller and have multiple holes since the jack doesn't have enough stroke to do a full 120 degrees.
The main reason I went horizontal vs vertical like he did is I wanted to be able to bend a single length of tubing in different directions. With his you would have to put it on a table or something but it takes little to no effort to bend tubing so it wouldn't be hard. My plan was to use a potrapower cylinder like an Enerpac with a longer stroke. Just never got around to doing it.
If you would still like to see a picture of mine I'll be seeing my step brother next week and can take a picture or two.
Crazyal. Pictures would be great.Thanks,
/ HarborFreight Tubing Bender item #99736 #18
The weather has been a little crazy around here lately so my brother-in-law waited until this weekend to drop off the bender. If you still like me to take a few pictures I can.
@crazyal.That would be great. Thanks:thumbsup:
2017 Chevrolet Tahoe SUV (A59231)
2017 Chevrolet...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60430)
(INOP) 2018 BOMAG...
Margaritaville Miniature Decorative Truck (A59231)
Margaritaville...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
