HarborFreight Tubing Bender item #99736
   / HarborFreight Tubing Bender item #99736 #11
I started off with an el-cheapo bottle jack pipe bender, 10 or 12 ton maybe. I then bought a set of dies for one of the $600 hydraulic benders. The set came with a 7" radius steel die that could bend 110 degrees, a strap to hold the pipe at one end, and an aluminum block about a foot long with a groove cut into it. Using some scrap steel (I made the mistake of using 3/8 plate so it weighs a ton) and copied the design of the bender the die fit on.
All and all I probably have $250 (may cost more now, I don't know) into the whole thing and have bent a dozen or so roll cages. Currently my step brother is using it to make a cage for a Suzuki Samurai. It would be easy to use a hydraulic press in place of the bottle jack if you had one. I've never used a non-hydraulic bender, not sure if I would want to bend a lot of tubing with out the help of hydraulic pressure. If interested I can get some pictures of it.
CrazyAl pictures would be great. Thanks
GT2 .Thanks that looks like a winner.
   / HarborFreight Tubing Bender item #99736 #14
Couple years back I bought a HF, the kind with a bottle jack. It was bad, flattened the inside of the bend ,not worth having, I took it back.
   / HarborFreight Tubing Bender item #99736 #16
I got the dies from Pro-Tool in FL. I did a quick search for the company and came across this website.
Tubing Bender
It's someone who, like me, made a tubing bender. The difference between his and mine is mine sits horizontal and the base of the jack mounts to the end plate. I mounted the jack so the handle to pump it sits on the bottom so it doesn't run out of oil as you pump it up. I made a simple swivel stand. Because I used a pipe bender I used one of the top rollers for the aluminum track to ride on, I just slid a short piece of pipe over the roller to give it a smooth surface. I used a 3/4" grade 8 bolt for the roller and have multiple holes since the jack doesn't have enough stroke to do a full 120 degrees.
The main reason I went horizontal vs vertical like he did is I wanted to be able to bend a single length of tubing in different directions. With his you would have to put it on a table or something but it takes little to no effort to bend tubing so it wouldn't be hard. My plan was to use a potrapower cylinder like an Enerpac with a longer stroke. Just never got around to doing it.
If you would still like to see a picture of mine I'll be seeing my step brother next week and can take a picture or two.
Crazyal. Pictures would be great.Thanks,
   / HarborFreight Tubing Bender item #99736 #18
The weather has been a little crazy around here lately so my brother-in-law waited until this weekend to drop off the bender. If you still like me to take a few pictures I can.
@crazyal.That would be great. Thanks:thumbsup:
New Landhonor Gas Water Pump (A59000)
New Landhonor Gas...
2009 Ford F-150 Ext. Cab Pickup Truck (A55973)
2009 Ford F-150...
2014 Nissan Sentra (A56859)
2014 Nissan Sentra...
2013 Yale Forklift (A56435)
2013 Yale Forklift...
2015 JOHN DEERE 35G EXCAVATOR (A52709)
2015 JOHN DEERE...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
