New to me backblade
/ New to me backblade #1
Mousefield
Elite Member
Qualicum Beach on Vancouver Island, BC. Canada
Sold 2008 CK35 HST
Last year about this time I bought a used home made backblade. It worked ok but you could tell it was home made, not the right holes for the angles etc. It was heavy 7 ft made out of ½ inch steel plate. Well a few days ago I scooped up a used one from Craigslist. I was the first one to call, got it for only $100.00. :D Tried it out today and it works very well, enjoyed my seat time doing our road. Here are a few pics of it working away, the good thing is I don't have to repaint it, already came orange. :thumbsup:
It is lighter weight than the other one, more weight is better???
/ New to me backblade #2
Nice work:thumbsup: I noticed you have 6 foot box blade, how did it work for road maintenance.
/ New to me backblade #4
That was a steal with that offset feature. Talking about doing some serious side ditching you got the blade.
The boxblade is what I usually use for the road. There are a couple of areas that tend to go wavy on me. Have tried different ways to get rid of that. With the backblade I can now cut across the high spots, by angling the backblade, to get the road level. :thumbsup:
/ New to me backblade #6
Nice blade. It doesn't look like it angles. But, you can always to that with your 3ph arm adjustment. Love the offset design. I have a woods and in order to offset it, you have to unbolt the whole blade and move it over. Quite the PITA.
/ New to me backblade #7
Looks like a good deal there, Mouse', and a smooth job on the road. I do not know much about back blades, so someone else will have to answer the question about weight. That one looks hefty enough to move some dirt, so that is about all you need. Great to be able to work at good angle. My favorite toy as a kid was one of those yellow road scapers like the county used to smooth the dirt roads out in the rural areas.
Regarding the use of a box blade for the same work, I use the BB since that is all I have. I am still learning on it, but have achieved some good results. Question: On the 3pt hitch on my CK30, there are some holes in the holding arm. Can one side be shorthened or lenghtened enough to get some angle on the box blade?
This new blade does angle, 5 positons :D and can be turned backwards. The home built 7 ft I got last year could not be turned backwards. I will be putting this one up for sale today.
From lakngulf,
Not 100% certain but don't think they are designed to be used at an angle.:(
/ New to me backblade #10
I mean angled relative to the grading plane. Thus, allowing you to mound/trench. Most such blades angle left/right/all-the-way-round as well as up/down to one side or the other. They can be adjusted 2 axes. I don't see how your blade supports up/down grading angle adjustment; it's simply flat relative to the plane the tractor is setting on. A lot of blades are like this. In such cases the angle can be adjusted by changing the length of the right 3PH arm using the crank handle on it.
I mean angled relative to the grading plane. Thus, allowing you to mound/trench. Most such blades angle left/right/all-the-way-round as well as up/down to one side or the other. I don't see how your blade supports up/down grading angle adjustment; it's simply flat. A lot of blades are like this. In such cases the angle can be adjusted by changing the length of the right 3PH arm using the crank handle on it.
Sorry I misread your post. :( Yes the right (looking forward) 3 pt arm has a crank on it to angle the blade up or down (left or right) That way I can put a crown on the road or dig a ditch. :)
/ New to me backblade #12
Mousefield you got one heck of a deal!I think this is what you and GittyUP are refering to as far as bank grading on some manual blades(none hydrolic).Here are some pics of my Servis e3wm(1958-1964-?)Please do not think I"am trying to jack your thread.BTW Mousefield enjoyed your pics and grading work,no doubt blade paid for it self already.
Boone
Ezekiel 20:19
/ New to me backblade #13
Its a slider blade. If you loosen the bolts that allow it to slide you should be able to angle. Its faster and easier to angle your arms if you need a bit of angle however.
I have a hoswe slider blade myself.:thumbsup:
/ New to me backblade #14
Boone
Ezekiel 20:19
My neighbor has a similar albeit lighter blade. Angle changes are allot faster and easier then with the slider blade.:thumbsup:
Sliders do have some advantages depending on what you are doing.:D Being able to offset the blade to one side can be useful.
Had a look and your are right. Be honest I didn't even realize that it is a slider blade. I assuming that it is even more expensive new? :)
250 gal Livestock Lick Tank (A66408)
250 gal Livestock...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2006 MACK VISION (A65643)
2006 MACK VISION...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2022 EZ-GO ELITE...
2018 John Deere 5125R Tractor (A64047)
2018 John Deere...
