Buying Advice Quarter-inching Valve
/ Quarter-inching Valve #1
tractorshopper
Upstate South Carolina
Kubota BX2380
Is the 3PH positioning a pain on the BX's and B's since it does not have the infinite position adjustment? I hope I'm getting that right, but on other tractors I've used we've called it draft.
I'm not sure how exactly the qtr inching works on the smaller machines and since that's what I'm looking to purchase, want to get a feel if it should be a big deal to me or not.
Do you just raise and lower to where you want the implement and then let go of it and it stays there?
Sorry to be a pain, but I want to really understand as much as I can about such a large purchase.
Planned rear implement uses will be bush hogging 3.5 acres, box scraping and landscaping some, and tilling a small garden each year.
Still struggling deciding between a BX 2360, 2660, or B 2320, MMM (for the other 4 acres), FEL and above implements.
/ Quarter-inching Valve #2
I do not have a tiller, so can't comment on it. I do not find the 1/4" valve on the 3 pt. hitch to be that much of an issue with the box blade or rear blade. I adjust what they are doing more with the top link which controls how agressive they are digging in. I do find it an annoyance with the rotary mower. You can certainly use it, but as you mow, it will tend to sag down, so you have to bump it up every once in awhile. Not a huge issue, but enough to annoy me. I will probably look at adding some type of chain system to limit the drop.
To get a position control on a Kubota, you have to go to the B2630 or an L.
/ Quarter-inching Valve #3
My B7800 supposedly has it. It seems to go up and down just like my other tractors. It has never been a problem for me.
/ Quarter-inching Valve #4
The quarter inching valve actually has 5 positions, from what I can tell. There is a neutral position and you can 1/4" it up and down, or you can lift all the way up or let it all the way down but you have to hold the lever until it gets all the way up or down in that function. I use a tiller with mine with no problem. I have the regular draft control on my other tractor but don't have a problem with this set up. You can also control the speed of how quickly the 3PH raises or lowers with a knob usually located in front of the seat down low.
/ Quarter-inching Valve #5
I have a B with the quarter inching valve and I think it's a pain in the neck. My next tractor will absolutely have position control.
/ Quarter-inching Valve #6
Don't forget that there is a big difference between "position control" and "draft control".
/ Quarter-inching Valve #7
Well, kinda like KU Gator; would really like to have it, but no one makes a position control 3-point, so you just have to live with it.
I tried to find a company that sold a chain setup, but couldn't find one, so for bush hogging/rotary cutting, I too will fab up a chain system too. It is just a mild annoyance as I have used BX's without it for eight years.
As Bird points out, "draft control" is a whole different thing.
/ Quarter-inching Valve #8
Quite briefly, 1/4 inching doesn't work. Now maybe one of the dealers will chime in here, and tell me what I am doing wrong, but in either position (fast, or slow) my control lever brings up a rear implement so fast it makes the front of the tractor bounce. It has been useless for me, and I depend fully on top link adjustment, etc. to get box blading work done. You can set a lower limit which I've done, and that has helped in some situations, bush hogging, using the middlebuster, etc. Still, there is very little control over fine adjustment to any rear mounted implement with my tractor.
/ Quarter-inching Valve #9
The 1/4"ing is different on the B7800 than the B3200. B7800 would drop a fraction each time it hit detent and all the way if the lever went to bottom of slot. The B3200 does not have the fraction drop at the first notch. it drops till you release with no marked drops other than your hand.
Thanks everyone for the feedback and thanks Bird for the link. I've been using the term draft incorrectly for quite a while now.
I won't use much sub soil implement so draft is not an issue at all for what I would need.
For position control, which is my true concern, I have so far only found one small tractor with this feature and that's the cub/yanmar, but I'm not sure it's enough of a big deal to steer me that way. I really like the Kubota's and really like my local dealer.
Seems my biggest problem with qtr inching will be while bush hogging several times per year.
/ Quarter-inching Valve #12
I have an L3130 with position control and my new BX2360 without. If I would not had the L and just one tractor I would have went with a 2X20 deere with it. For a bush hog there is nothing that will work as nice.
/ Quarter-inching Valve #13
I had a 1995 Kubota B7100 without position control. I used a tiller, brush hog, box blade, etc. with it. And of course, I then had a B2710 that did have postion control. I much, much prefer position control, but it's certainly not a real necessity; lots of people use lots of tractors without it.
/ Quarter-inching Valve #14
For bush hogging, you can set the lower limit by moving a stop under the right fender, and that will allow you to go back repeatidly to the same mowing height. It is a bit of a trial, and error to get it set, but it does work. Bird is right, of course that thousands of folks use, and get jobs done with Kubotas that don't have position control. I'm not sure that justifies Kubota leaving it off to save a few bucks though. The 2000 series John Deeres have position control too as do the 1500 series Masseys, the Mahindras, and the Kioti. Kubota is the only one without it on tractors this size, and slightly larger.
/ Quarter-inching Valve #15
I've had a tractor (L3240) with position control and some tractors without, BX1500, B7800, BX2350, B3200, BX2660, BX25, F2680 (not a tractor but raises and lowers deck) and BX2200. I would never consider having or not having position control as a determining factor of buying one tractor brand over another tractor brand. Position control is good/better but as a determining factor,:) I think not! I do not brush hog but have utilized most of the other listed implements. I had a RFM which has some similiar features/uses as Brush hog/rotary mower.
/ Quarter-inching Valve #16
Actually only some of the 2000 Series John Deeres have position control; my 2305 does not.
/ Quarter-inching Valve #17
And with the small Deeres, I think you are giving up the 3 range HST, so there always seems to be trade-offs.
The B2630 has the position control and some recent buyers/posters have said they got discounts which may make them more competitive with the 2X20 series.
John Thomas - RFM's have wheels on all 4 corners of the mower to carry the weight so, you drop it and go. The rotary mower is heavy with usually only 1 wheel in the back, at most two, but none up front, so the weight must be carried by the 3pt hitch. You can set a rough adjustment of the rear wheel and then ideally want the front of the mower just slightly lower than the height of the back of the mower. Easy enough to set, but with the 1/4" valve, it won't stay set at that position. It sags lower as you mow, so you have to make adjustments as you go. If you get lost in the second verse of She Thinks My Tractor's Sexy, you look back and see the front of the mower is on the ground.
/ Quarter-inching Valve #18
Depends on your usage. If I spent most of my tractor time mowing or doing FEL work, no problem at all. The more the usage leans to 3pt ground-engaging implements, the more irritating the lack of position control can be. Grading with the quarter-inching valve is tedious. Set approximate position, then bump, bump, bump. Too high, too low, try again. Lift the implement, say for a turn, start all over again. Combine that with no top/tilt, and it's no wonder people get frustrated.
/ Quarter-inching Valve #19
Totally agree. I had position control on a L3240 and combined with the extendable arms was great but my uses are mostly mowing, FEL and ocassional 3PH use. I bought 3ph Quick hitches early on and doubt I'd go without them. For someone to not pay $70 for a QH is beyond me.
/ Quarter-inching Valve #20
Totally agree - add to that if you come from a background of using position control your whole life and then not have it - very frustrating - and if you regularly jump from one tractor to another and the one does not have it - here again frustrating. And I could not get used to the squeal from the hydraulic system - seems unnecessary.
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
WILDKAT 78 ROCK GRAPPLE (A61572)
WILDKAT 78 ROCK...
(INOP) WHITE 2-180 TRACTOR (A63291)
(INOP) WHITE 2-180...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
2025 Swict 84in Bucket Skid Steer Attachment (A61572)
2025 Swict 84in...
