Why I Need More Than 1 Tractor
/ Why I Need More Than 1 Tractor #21
My neighbor, who is 70 years old and still farms full time, has 12 tractors, 2 five ton grain trucks, 1 skid loader, 1 backhoe, 1 combine, two riding mowers, a Kawasaki mule, 2 pickup trucks, and a car. Not counting all the attachments. This guy spends every waking minute taking care of his equipment. Maybe too much of a good thing? He seems to enjoy it.
/ Why I Need More Than 1 Tractor #22
I like that 1 tractor per implement rule, especially during the spring planting season. At that time, I leave one tractor on a plow, one on a disc and one on a planter. This saves a lot of time changing implements. Also, I seem to have less breakdowns overall by splitting the workload between several tractors (I use (6) total, (4) in the fields and (2) for cutting the lawn.
/ Why I Need More Than 1 Tractor #23
Now, don't get me wrong... I like toys and all. :) However, I don't like maintaining so many engines on "work" machines. That's what attracted me to my Power Trac and its quick attach system. I can change non-powered implements in 15 seconds (watch here) without getting off the tractor. Powered implements take about 30 seconds longer because I have to get off and connect two hydraulic hoses. The quick attach system makes it insanely easy to switch implements. I actually look forward to changing implements just because it is so fun to do! :thumbsup:
The only way I could justify two tractors was if I needed one that was either larger, or I had to do pulling or plowing tasks, which the PT does not excel at. For my typical home owner tasks, one PT is just about perfect. :D
/ Why I Need More Than 1 Tractor #24
This is the way I prefer also. Speaking for myself I will take care a certain amount of equipment extremely well. Too much equipment wouldn't be taken care of near so well.
/ Why I Need More Than 1 Tractor #25
I have two tractors and the main reason is when I haul manure or wood or anything I take a tractor to load with, it is nice to have that extra tractor at home to push up the piles before the next load. In the winter I use "baby K" to haul in wood for the boiler and clean up the small snowfalls and save the big
stuff for the L4350.
/ Why I Need More Than 1 Tractor #26
I'm bassically at 2 tractors and 1 Bobcat. I'm in the process of a project to get the Bobcat running. I picked it up very cheap and I knew going into this was going to be a major project.
I'm going the other direction - looking for more ways to use horses. I'm considering getting a team of shires to do more grunt work - my bride prefers to see the percherons in front of a pretty wagon ;)
Have you considered a PTO cart...
Draft horse, mule, and oxen power - Rural Heritage online
Liberty PTO Cart
/ Why I Need More Than 1 Tractor #29
I have two tractors and a backhoe works well for me, lawn mowers are separate. There are times I could use two loaders but not often enough to worry about.
/ Why I Need More Than 1 Tractor #31
Perhaps something Amish here. Trying to figure it out. We have a lot of Amish and Mennonite around where we live now. We are the odd ones here and not them.
We're up in the Holmes County area a few times a year working with and learning from some of the Amish farmers in that area; they are a wealth of knowledge on doing things smart and simple.
So, you get to change the engine oil AND muck out stalls? KISS in reverse...
You're not saving much money over buying a tractor either.
/ Why I Need More Than 1 Tractor #34
You always need a second tractor to pull the first one out of the mud.
So what do you do when the second one gets stuck going after the first?? ;)
/ Why I Need More Than 1 Tractor #37
Back when all I had was 2wd tractors, If I had to go into an area where there was a risk of getting stuck, I would never use my largest tractor. That way I could always use the big one, held in reserve, to get the smaller one out. I have never got a 4wd stuck in 5 years since owning one. One time, when I lost traction on all 4 tires pulling a disc thru a mud-hole, I simply used the bucket to pull myself out. With 4wd, there is rarely a reason to remove the bucket, as the weight up front dont hurt you like it does on a 2wd, and you can always use it to pull or push your way out of the mud. I cant imagine a sitation that would cause me to get my 4wd with R1 tires stuck, but I have a healthy respect for the mud from many years of 2wd tractor operation.
/ Why I Need More Than 1 Tractor #38
Since I didn't have a second tractor to start with, when I got the 861 stuck twice, I just used the truck.
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
Sterling AT (A63689)
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
2017 Caterpillar 349FL Hydraulic Excavator (A61572)
2017 Caterpillar...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
