Need paint sprayer help.
/ Need paint sprayer help. #1
N80
Super Member
SC
Kubota L4400 4wd w/LA 703 FEL
I have a log cabin that needs to be re-stained. Should have been done about 2 years ago. Anyway, the first time we brushed it and rolled it. Took a long time and just about killed us. Subsequent coatings can be sprayed on and I think I'll go that route this time.
From what I've heard, the little Wagner sprayers really aren't up to the task of doing a whole house exterior job. But I could be wrong about that.
Anyway, this job really needs to be done every few years so I'm thinking about getting a decent airless spray system like a Graco which they sell at the big box stores.
Anyone know anything about these? What does it mean by airless? Does stain require special parts or special clean-up?
The model I'm looking at is about $400. And handles stains, interior paints and medium exterior paints. Any others I should look into?
/ Need paint sprayer help. #2
I to have to redo my log siding.I got log home cleaner which is applied by a pump up sprayer then rinsed with water.After a few days to dry,I,ll have the stain applied by the same pump up sprayer and back brush it in.The airless sprayers use a piston to spray,auto body type guns use air pressure.Hope this helps ya out.
/ Need paint sprayer help. #3
I have the same Graco sprayer that you have pictured. I love it. Spent about $400.00 on one at Home Depot last year to paint my 30x40 shop. It took me longer to tape off the windows and door than it took to paint the entire shop with that thing.
Just make sure you clean it properly before putting it back into the box to store for the next time. It pumped the thick stain I used with no problem.
Chris
/ Need paint sprayer help. #4
I'll also recommend the Graco sprayers. I have had one for years and I think it is the model up from that. Nice thing about the Graco's is there are parts and service available through many of the better paint stores. Hardest thing to learn is to keep it clean and when you think it is clean, clean it again.
MarkV
Thanks guys. I think I'm going to splurge and get this thing. We had such a hard time the first time that we have put it off to long. If this sprayer makes it quicker and easier that will be worth it and if we do it more regulary, the way we should, it will be more than worth it. My tool shed needs painting to.
/ Need paint sprayer help. #6
Your making a good choice. i have one too, works great,just be sure to clean it well and buy the correct lubricant and run the lube thru the pump when storing.
takes longer to mask than paint! You can go to a pro painting supply and buy a hand held screen that you can use to save on masking. Just hold it against the surface you dont want covered. It leaves a good edge, plus saves time.
The screen sounds like a good idea.
They also make a 30" extension tube for the spray gun.
When we did this the first time we had scaffolding that we had used when we built. We do not have scaffolding now so the peaks of the end walls would require my tall extension ladders. I hate all ladder and I hate painting from a ladder more than anything. But, with that 30" extension tube I bet I can reach everything from my tractor bucket which would just be great.
(I know it isn't safe to use the bucket as a man lift and I don't recommend that anyone do it.)
/ Need paint sprayer help. #8
If i was in going to get a extension, id go longer, like 6-8' so i can work more from the ground. Bear in mind the extensions i was looking at (6') were $100+ you might be able to find for less. The spray is forceful enough that you can reach 2' above your extended arm without issue.
Spray shield http://doitbest.com/Paint+Paddles_+Pails_+and+Accessories-Warner+Mfg.-model-10053-doitbest-sku-792985.dib Thats a 36" but they can be found larger
/ Need paint sprayer help. #9
We used a wagner with a man-lift, took 11 hrs to do a 1600 sq ft capecod log, and a 24 x 24 garage. I used the backpack and had good luck. I would have liked that extension though. We used woodguard in honey 2000. You can re-apply over it any time without prep work. I would recommend a roller on a pole to take care of any runs...
/ Need paint sprayer help. #10
N80 make sure you pick up some dust masks and a spray hood to cover your hair. There are also throw away cover all's if you feel like you need them.
MarkV
/ Need paint sprayer help. #11
In addition to what MarkV said about clothing, I would also suggest a large brush like a pushbroom and a smaller one like a foxtail brush. Brushing over the sprayed area lightly will help the stain fill all cracks and crevices for a smoother application. I have an old horsehair pushbroom that I use on my cedar dutchlap siding, and it works very well.
/ Need paint sprayer help. #12
When I bought my Graco sprayer I also bought the roller attachment. Haven't used it yet (still hanging on my shop wall in the carton). I'm not sure how well it works, but I thought since I was buying the sprayer I just as well go all out and get the roller attachment.
Chris
/ Need paint sprayer help. #13
If you are doing a big job, there is nothing better!
As in any paint job, the most important phase is the prep work, make sure that you mask off, or learn how to use a
spray masker(practice on some scrap first)
Get your self a GOOD respirator, or you will be doing your health a disservice.
Cover you self, Hat, coveralls, etc,
And clean the sprayer well after each use, I usually run water thru 3-4 times, until it runs clear, and then mineral spirits to lube the unit.
Campbell-Hausfeld isn't a bad brand.
Happy Painting!
Excellent tips guys. Thanks. Will probably try to get this done in the next few weeks. Of course I've been saying that for 2 years now but hopefully once I spend the money on this unit I'll feel compelled to get the job done.
2008 FORD CROWN VICTORIA  CAR (A66091)
2008 FORD CROWN...
FOUR RACKS OF MISC FILTERS (A67714)
FOUR RACKS OF MISC...
500BBL WHEELED FRAC TANK (A67714)
500BBL WHEELED...
PALLET OF MISC SIZE STYLED JACKS (A67714)
PALLET OF MISC...
PALLET OF WOODEN STAKES (A68842)
PALLET OF WOODEN...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
