Buying Advice close to pulling the trigger on a BX2360
/ close to pulling the trigger on a BX2360 #1
cpb
I am close to pulling a trigger on buying a BX2360 with a FEL, 60" MMM and the front end snow blower.
Is anyone familiar with the tooth bars that you can attach to the bucket? How easy are they to install and how effective are they? Will they be helpful with doing a little light grading and clearing of brush?
/ close to pulling the trigger on a BX2360 #2
I am familiar with a toothbar. I bought one for my first tractor. Didn't do anything for me. Sold it to my neighbor. He never used it and I bought it back from him last week for $50 and sold it last week to milkmans brother along with my Pat's. Milkman bought a boxblade or traded me a single bottom plow for it. I bought a RatchetRake for a B3200, sold the B3200 and then sold the RatchetRake that fit the B3200. Have since bought another RatchetRake that fits my BX's. In my opinion, having owned both, the RatchetRake and Boxblade is more effective. The boxblade is one of the most versatile of all implements. It is for light grading and ditch digging and leveling and adding weight to the rear of the tractor and also can dig up the ground prior to tilling. The RatchetRake is also promoted as being for clearing brush tool, The RatchetRake then comes along and finish grades the ground for throwing the seed down. Bad news is the RatchetRake is going to be a bit hard to obtain for a few months.
Everything Attachments - Skid Steer Attachments, Tractor Attachments, 3 Point Hitch Attachments, Farm Tractor Implements.
Ratchet Rake, LLC
Check both of these sites for education and fun purposes.:thumbsup:
/ close to pulling the trigger on a BX2360 #3
Tooth bAr helps you dig with the FEL. They usually make leveling more difficult since on most models the teeth extend below the bottom of the bucket. I use mine for digging holes, moving piles of dirt and tehn will take it off or use the Box Blade for finish grading.
How helpful they will be depends on your soil type and what you want to do.
Roy
/ close to pulling the trigger on a BX2360 #4
They say they are helpful.
I don't have any need for 1 as Have a BH and a 48'' tiller that I use to break up the soil with .
/ close to pulling the trigger on a BX2360 #5
cpb
i own a bx2360. i am very happy with it except for a leaking front rim and the fact that the typical kubota weightbox will not attach without major modification to a land pride quick hitch qh-15. we did the mods on the box and it is still disapointingly not right . . . enough on that/for now.
the bx2360 is a light tractor and i would suggest you will need the ballastbox for loader and snowblower work, for stability and increased traction.
i also have a ratchet rake and a toothbar. i bought the rr to help me in an area of about 8,000/renovation. the ratchet rake was about half the price of a landscape rake. it was a good buying decision. ultimately i will sell the least useful (if i allow myself to describe them that way/no!) one. a toothbar will increase the utility of your loader (marham & w.r. long, get good press here).
you might even consider a bucket wearbar.
lastly, to protect the underside, i bought the bro-tek skid plates.
it's a great tractor- pull the trigger- shrekbelly
/ close to pulling the trigger on a BX2360 #6
I don't have a toothbar and don't think I've missed it.
Pre-backhoe, there were a handful of times that it MAY have been helpful. Post-backhoe, I really have zero need for one as my "digging" is not done with the FEL.
The way I use my FEL, even not considering the backhoe, perhaps 5% of my tasks (and that's being generous) would be easier WITH a toothbar. However, I'd prefer to REMOVE a toothbar to complete fully 70% of the tasks I perform with the FEL. That leaves perhaps 25% of the tasks that I'd have no preference whatsoever on whether there is a toothbar present or not.
IMHO, the money is better spent elsewhere.
/ close to pulling the trigger on a BX2360 #7
I don't have a backhoe , so do all my digging with the FEL and toothbar on my BX2660. I would not do without a toohbar now and was under $200 if I remember right.
If you have clay and don't have a backhoe, then you will want/need it .
One other advantage is that the extended 8 inches of teeth now allows you to pickup and carry a log or pipes/culvert, or even dimensional wood, sometimes without even getting out of your seat. I also use it in winter because it allows bucket to hold slightly more and it scrppes the ice better.
And when you do need smooth finish of a bucket it only takes three minutes to take the two bolts off.
jake
/ close to pulling the trigger on a BX2360 #8
So far I haven't seen the need for a toothbar and I've dug in some pretty hard clay. I'm sure they help though.
/ close to pulling the trigger on a BX2360 #9
jake
What kind of tooth bar do you have, I am thinking about getting one or a ratchet rake, just don't know which one I would use most?
/ close to pulling the trigger on a BX2360 #10
jake
Forks would do most of those jobs easier or better. I have clay, had a toothbar and sold it. Bought it back one day and sold it the next day.
/ close to pulling the trigger on a BX2360 #11
They aren't really competitors. The RR for me is more sueful since I use it for leveling dirt for finish grade, back dragging to round up rocks, twigs and such. The toothbar is more for digging and popping up rocks. The RR will probably pop up surface rocks better than toothbar since teeth are sharper and closer together on RR. Can't dig with RR or I won't. Sold my toothbar after having it for a year and it being more hinderance than help. Traded tractors so I had to order another RR to fit tractors I have. Can't see going without a FEL, Boxblade and RR and of course a mowing deck.
/ close to pulling the trigger on a BX2360 #12
I bought a BX2350 almost 2 years ago. The first accessory I bought for it was a Markham tooth bar. That has proven to be the most useful add-on purchase I've made to date. It comes off in the fall for winter snow work with the FEL. Otherwise, it stays on.
I think Markham has either been bought out or merged with some other company. I can't find Markham welding on the Internet just now.
There are other good units. W.R. Long comes to mind. But there is no way I wouldn't have a tooth bar, now that I've had this one.
Doug
/ close to pulling the trigger on a BX2360 #13
yep mine was a Markham also
/ close to pulling the trigger on a BX2360 #14
Sounds like I need a RR for my BX and toothbar for my L.
Caterpillar Truck Engine Service Manuals (A63117)
Caterpillar Truck...
2014 Nissan Murano Cross Cabriolet AWD SUV (A61574)
2014 Nissan Murano...
Caterpillar 814/815/816F Landfill Compactor Service and Parts Manuals (A63117)
Caterpillar...
Caterpillar 920/930 Wheel Loader Service, Parts and Maintenance Manuals (A63117)
Caterpillar...
2015 Ford Escape SUV (A61574)
2015 Ford Escape...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
