Dozer work -- How much will it cost me?
/ Dozer work -- How much will it cost me? #21
Now there is a compo that is hard to beat tractor with FEL and a mini ex. The issue I had with a BH was turning radious. When I need to clean my pond{or other work} It is hard to do it with a BH. With the mini ex I can get right up allmost in the pond and swing full scale to load trailer or FEL with muck{cat tails etc}. Plus with the ex I don't have to mess around with how to park and setup. The only problem I have now is that the wife found out how handy the little machine is :D. Like I said mine is small, but it is worth it's weight in gold{atleast to me}.
On to your question "Who makes a good mini ex?" Well if your buying used a better question might be who was/is the better owner :) With that said I own a JCB and believe it is a great machine, BUT can be hard to find parts???? I do like Yanmar they seem to be wide spread and cheap. Kubota is nice but harder to find and can be pricey. Bobcat I was told to stay away from, I was told they lacked power. I am not knocking Bobcat and when/if I get another I would be willing to check them out. There are plenty of machines out there, search a few out, then start a thread on here as to how well they are liked.
I can give you one place to start a search machinerytrader.com. Once you get into the site you can narrow your search to size, price, and even area. Hope this helps and keep us updated. probably should start another thread :)
/ Dozer work -- How much will it cost me? #22
I paid $4000 to clear approx 6 acres and take off the stumps and trees. This was for my new home. Probably 75 to 100 trees 15" to 25" diameter with 1/2 being pine. Graded and compacted a 60 x 80 spot for a building and did quite a bit of soil leveling. Took around 50 to 60 hours of Dozer (had a scoop) work. Pretty Large Dozer. Along with approx 25+ dumptruck loads. At all times there were around 3 guys working and the dumptrucks went to the Loader Operators farm.
I had 3 other quotes and they ranged from $5500 just piling up the stumps to burn (not easy in my area) to $9600 grinding the wood and carrying the stumps. At first I thought $4000 was high...
/ Dozer work -- How much will it cost me? #23
I bought a 312 to dig stumps, move some big rocks, dig the foundation, and eventually sell. You're taking a chance buying the equipment, I've already put 2K into repairs welding the stick and replacing cylinder seals, etc. which I knew about before buying, and reduced the selling price that much more. If you buy it at the right price, you can work it for a year and break even when selling, unless you run into a major repair.
For a smaller job you would spend 4-5K on, I don't know if it would be worth it....but, it sure is a lot of fun, and pretty easy to pick up. Some great seat time....
Good luck!
/ Dozer work -- How much will it cost me? #24
I bought a used mini 5 1/2 yrs ago to do some work around the house. I figured Id use it get the work done and sell it for what I paid for......... well 5 1/2 yrs later i still have it , have got LOTS of things done with it that keep needing to be done. I really dont have a plan to sell it and my wife isnt saying anything about it now ......... I did say now ! LOL She first said WHAT THE &$@# did you buy that for!!!!!!!!! she was not happy but since she has used it and saw the things she can do with it she is happy with it. Yes she operates it and does well with it. Plus it is fun to use !!!! I have put 400 hrs on it and have spent about $150 in repairs. I would go with the excavator with a thumb on it and take your time and do it yourself.
/ Dozer work -- How much will it cost me? #25
I rented a Volvo ECR 145 with a dozer blade and thumb to clear about 7 acres of wooded mixed land. I rented it for a month and my Volvo guy threw in free delivery and pick-up. We were able to get through 1/2 acres a day stumps pulled, holes filled and rough graded with the blade. Ended up finishing well before we had to return the machine. I was amazed by how powerful and really well designed the machine was. It's about a 33k lbs machine and we were able to pull 24" stumps no problem and digging the larger ones was a joy. Month cost me $3,500.00 with insurance and a damage waiver. I had 2 quotes in NJ both were over $5K to do the same work. I think it was worth it! If you have the time do it yourself.
Good luck
/ Dozer work -- How much will it cost me? #26
Several years ago I hired a contractor who wanted to be paid by the eight hour day. He had two men that worked for him and provided an excavator and a large loader.
They would do whatever I wanted done for $2500. for the day. I paid him $7500. and he cleared 4 acres of huge willow trees ( about a dozen ) around some ponds and a grove of pinetrees.
/ Dozer work -- How much will it cost me? #27
Good luck
robs, how long ago was this that the cost was $3500/month. I am very interested in doing what you did and I also have about 7 acres of stumps to clear, no trees, just stump and a 700' windrow.
/ Dozer work -- How much will it cost me? #28
/ Dozer work -- How much will it cost me? #29
This is an appropriate point I guess to interject - got 65-70 mostly pine stumps with 35 @ 30-40" at the butt, and another 25-30 @ 15-20" over three cleared acres, along with ledge and boulders to be moved. Yes its a nasty job esp with the boulders and ledge. With a large machine this is probably 2-3 days stumps and 2 days rock realignment.
The goal is to have the stumps removed and gone, then the stone/boulders - the large stuff arranged in a rock walls and in treeline area so I can then come in and replant trees and grade the area with my unit.
I have done this before on the property but in a smaller scale 15-20 stumps for $2500 range so now we are looking at a much larger task along with hauling the stumps and quantity we have (burning is not an option with just 6 Ac and multi days of burning needed).
I am getting a first bid and will see how that shapes up - I can get a sunbelt rental 30K excavator for $3K for the month. Then i need to deal with probably 4-5 log truck loads of stumps @ $350 ea...+- . My gut is telling me to hire this out to the big machine 60K excavator with thumb and a 100 yd trailer to haul away the stumps.. Dont know the numbers yet but he said a week roughly so I would estimate this is going to come in @ $5-6K give or take for pulling the stumps, removal and rock re-alignment..
When does one "have it done" vs "doing it" I guess is what this comes down to. Time will tell once I have the bid (s) to get it done..
/ Dozer work -- How much will it cost me? #32
Gerard,
The JD 8100 griinder is a really neat setup - looks like it will chew up a big stump in minutes. The first issue is finding one, then the concern would be in rocks embedded in the stumps comprimising blade life, then last how would it work on 40" butts - I suppose they have a larger blade or make multiple "drills" but this is very cool indeed.
The other video appears to core the stump - maybe 18" - again it has its place I suppose but for big stumps its a multi core job it would appear.
/ Dozer work -- How much will it cost me? #33
All true and it takes a pretty big tractor. They all look to be 150 hp or better and still get knocked around a little. But it's even quicker than an excavator, you don't have to transport/burn stumps, and it looked like tou can clear a pretty big area pretty quickly. I saw even bigger versions than the ones I posted that can do bigger stumps. Also I would think the corer one could do any size stump if you took multiple cores but with that one you still have to dispose of the cores........
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 International (A59230)
2012 International...
7888SFL (A61567)
7888SFL (A61567)
2011 Freightliner B2 School Bus (A61568)
2011 Freightliner...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
ROLL OF 6' CHAINLINK FENCE (A62131)
ROLL OF 6'...
