Mowing deck bolts
   / Mowing deck bolts #1
JOHNTHOMAS
Super Member
Somerset, Ky
F2690 4WD RTV X1140 MX5400 HST ZD1211
While I have my deck off, I want to replace or actually get a spare set of blades so can sharpen one set when I decide I have time and then replace them when they dull, just rotate them. I finally tried my air impct wrench on my tire removal and it's great so I want/need to buy a socket to fit the bolt holding blades on. What size socket? It's also opposite of righty tighty and lefty loosee isn't it?
   / Mowing deck bolts #2
Since no one has answered you yet, they look the same as on my B3030. They take a 30mm socket & they're right hand threads.
   / Mowing deck bolts #3
I use a 30 MM for my 60 " deck too.
   / Mowing deck bolts
Thanks guys. 30MM it is. Right hand threads mean opposite of most threads, right? Means I have to turn these to the right to loosen them and left to tighten them?
   / Mowing deck bolts #6
JT,
They are normal Righty Tighty, Lefty Loosey.
   / Mowing deck bolts #7
Interesting... here's what the red version looks like. Notice the smaller nuts (24mm) on blades....:D
You're right-- air impact wrench darned near compulsory to remove those nuts!
   / Mowing deck bolts #8
I actually use a couple of 1/2" breaker bars to change blades and of course a torque wrench. Tighten 75-80 foot pounds. I don't even bother to take the deck off.
   / Mowing deck bolts
Decks off for fluids and filters service, don't have breaker bars or torque wrench and do have air wrench.:) I'll be more careful of what I cut with my new blades while I sharpen these old ones and maybe won't have to change them again until next service when deck will be off again.
   / Mowing deck bolts #10
Since my wife learned not to "mow gravel", my blades make it through a whole season usually, but for a while...
Using an impact wrench sure is easier since you have the deck off.
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A51039)
2018 Rock Solid...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
2020 PETERBILT 337 BOX TRUCK (A51222)
2020 PETERBILT 337...
2012 PETERBILT 388 SLEEPER TRUCK (A51222)
2012 PETERBILT 388...
2001 GMC W4 CRANE TRUCK (A51222)
2001 GMC W4 CRANE...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
