Mowing deck bolts
   / Mowing deck bolts #1
JOHNTHOMAS
Super Member
Somerset, Ky
F2690 4WD RTV X1140 MX5400 HST ZD1211
While I have my deck off, I want to replace or actually get a spare set of blades so can sharpen one set when I decide I have time and then replace them when they dull, just rotate them. I finally tried my air impct wrench on my tire removal and it's great so I want/need to buy a socket to fit the bolt holding blades on. What size socket? It's also opposite of righty tighty and lefty loosee isn't it?
   / Mowing deck bolts #2
Since no one has answered you yet, they look the same as on my B3030. They take a 30mm socket & they're right hand threads.
   / Mowing deck bolts #3
I use a 30 MM for my 60 " deck too.
   / Mowing deck bolts
Thanks guys. 30MM it is. Right hand threads mean opposite of most threads, right? Means I have to turn these to the right to loosen them and left to tighten them?
   / Mowing deck bolts #6
JT,
They are normal Righty Tighty, Lefty Loosey.
   / Mowing deck bolts #7
Interesting... here's what the red version looks like. Notice the smaller nuts (24mm) on blades....:D
You're right-- air impact wrench darned near compulsory to remove those nuts!
   / Mowing deck bolts #8
I actually use a couple of 1/2" breaker bars to change blades and of course a torque wrench. Tighten 75-80 foot pounds. I don't even bother to take the deck off.
   / Mowing deck bolts
Decks off for fluids and filters service, don't have breaker bars or torque wrench and do have air wrench.:) I'll be more careful of what I cut with my new blades while I sharpen these old ones and maybe won't have to change them again until next service when deck will be off again.
   / Mowing deck bolts #10
Since my wife learned not to "mow gravel", my blades make it through a whole season usually, but for a while...
Using an impact wrench sure is easier since you have the deck off.
2013 Ford Econoline E350 Passenger Van (A49461)
2013 Ford...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A50322)
2017 Bomag BW90...
2014 STEPHENS 200BBL TANKER TRAILER (A50854)
2014 STEPHENS...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2015 Ford F-450...
GARDNER DENVER 480 VOLT AIR COMPRESSOR (A50854)
GARDNER DENVER 480...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
