Tractor won't move
/ Tractor won't move #1
tnbowhunter
South East Tennessee
YM 2220D
The weather finally warmed up enough to disc the garden this weekend. After sitting all Winter I was a little anxious about "Marvin" starting. I put the fully charged battery on and turned the key. To my amazement old Marv started right up!! I let him warm up for a few minuites, put him in reverse, let out the clutch...............nothing. Checked to make sure the power shift was in gear [it was] tried again.............nothing. Hmmm, I thought this is strange!!!! I put the gear selector in 1st gear and again let out the clutch and away we go. I disced the garden with many starts and stops with no more problems. The next morning I thought I would try again and the same scenario. After several tries it finally budged and ran great.
Now I'm wondering what might be the problem. I checked the fluids and they were all at the full mark. I'm thinking now it might possible be the hydraulic filter or screen. Any suggestions?
Thanks in advance!!
/ Tractor won't move #2
Fluid and filter/screen would be my first thought as well. It sounds like the fluid has to warm up a bit before it will flow well enough to operate.
/ Tractor won't move #3
replace the filter and clean the screen. what fluid are you using, JD303 or mercon. if the filter/screen does not work let us know and we will give the next things to check.
/ Tractor won't move #4
Hey Bow Hunter
I have used mercon dextron ATF in my Yanmars since the 90s, and they work flawlessly !
When we receive our tractors from Japan they usually have ATF in the trannys if they are a power shift .
They warm up faster, and ATF has a lot of detergent to keep everything clean inside the trans.
It works for us.:D
/ Tractor won't move #5
My tractor had bad fluid in the trans when I bought it.......actually I had water in it due to a bad filler cap and it hadn't been changed for a long time. I couldn't get it to engage in any gear. I cleaned screen, changed filter and replaced fluid with dextron 3 ATF......once started....it took a minute to get through the system but once it did......everything works fine. All gears work well. Just make sure the filter you put on is the proper micron level......some aftermarket filters are in the 30 micron range......this may be too thick to actually filter the oil. In this case....the oil just passes through the by-pass.....and your oil is not filtered. I believe the proper micron level is in the 10 range. You can buy these thru Hoye.....there may even be an aftermarket available. I plan to eventually replace my oil with JD 303 but for now........the Dextron works fine.
Thanks for all the replys guys. I have had my tractor for two years now and this is the first issue I have had with it. I will have to admit that I did not change the Tranny fluid or filter last year as I probably should have. I did change the oil and filter and I always grease all the fittings etc. though. I did check the transmission fluid and it did look good, not milky, dirty etc but I should of spent the time and money and changed it anyway. I did notice it was just a little low one time last year and I topped it off with JD 303 which I thought was the correct fluid. Now i'm a little confused.............should I change it to dextron ATF? It does sound like it would work better and keep everything inside the transmission clean.
It will probably be this weekend before I can work on my tractor but I will let everyone know how it goes.
Thanks again!!!!
/ Tractor won't move #7
when you clean your screen you will loose most of your fluid, I would change to mercon at that time. Like Ernie said the tractors from Japan with power shift seem to always have auto trans fluid in them.
/ Tractor won't move #8
I have a 1510D with Dextron. It works great for me and I had no problems this past winter like I had the year before. I did have a problem that sometimes it would not like to go in reverse when it was cold. My shifter is on the tunnel and not on the column like the 2220. I took it apart today and found what I believe is the problem. Where the shift lever attaches to the shift spool there is a 5 mm x 25 mm pin. I found that my pin was bent and worn. I replaced the pin with a hard bolt and it seems to be fine now. I think that the shifter spool was not being put completely into the detent position for reverse, because the lever had too much slop and could not move far enough. When it is warm it seemed to self locate the detent position. Any way it works for me.
Mike
/ Tractor won't move #9
Hey Bow Hunter
It works for us.:D
Ernie, how can you tell what is in there? I bought my Ym2000B right out of the shipping container 9 years ago, changed the coal black engine oil, and backflushed the rice paddy water from the system, but have never had any reason to mess with the hy/tran fluid. I don't know what JD303 looks like, but it does have the reddish translucent color of ATF.
/ Tractor won't move #10
I changed my fluid last summer and the JD303 I used was the color of honey. What came out looked like milky honey.
/ Tractor won't move #11
The service manual for my 186D calls for JD303. A local tractor shop that work on Yanmars......told me I could use either JD 303 or Dextron. He did say that the shifting may be a little jerkier with Dextron but it would not cause a problem. I currently have Dextron in my tractor....all is fine. I plan to eventually put JD 303 back in.....no hurry. Also......there are lots of products out there that say they meet JD303 specs.......not sure how good some of them may be. You can order JD303 from O'Reilly's/Shucks...product number 74509 (5 gal.).....for $39.99.....you can also get it from JD for a lot more. Check your screen and change your filter! As for color......303 is light brown.....like honey. ATF is purple/red.
Aw jeeze, now I really feel like an idiot. I thought I was a pretty good "shade tree" mechanic but I had a few spare minuites so I figured I would go ahead and clean the screen while I had time. Trouble is I can't find the dang screen. My manual says the screen is "typically a 3 or 4 bolt cover behind the operators left foot in the transmission housing,etc etc." I thought it was behind a cover on the transmission but after I took the cover off there wasn't anything there that I thought looked like it might contain a screen. There is a cover close to where the shifter goes into the transmission and I started to remove that but somthing tells me that is not the right cover. Now I really need help.:confused: Someone please point me in the right direction. My tractor is a 2220D.
BTW I checked the transmission level again and did notice that the fluid has a reddish tint to it so I suspect that it already has ATF in it. The level was spot on. I started the tractor up, let it warm up for a few min and when I put it into reverse to back it out of the shed it didn't hesitate one bit. Still, I think the fluid, filter and the mysterious screen need to be changed.
/ Tractor won't move #13
"tractor universal" oil in a 1510 - slightly slow in very cold conditions.
/ Tractor won't move #14
tnbowhunter, I think your screen is down low on the transmission, it is on the left side.
/ Tractor won't move #15
If it looks red, it's probably ATF:D
/ Tractor won't move #16
TNBBOWHUNTER, GO TO SEARCH, TYPE IN "2210 SCREEN" UNDER YANMAR. GOOD PICTURE OF SCREEN COVER EVEN THO IT IS TURNED SIDEWAYS.
/ Tractor won't move #17
When you say ATF, does that mean the old type (Ford) ATF, or (Chevy) Dexron, or does it matter? I want to try and stick with whatever is in there when I ever have to change it, (works great).
/ Tractor won't move #18
Thanks in advance!!
I don't know anything about your tractor but when you say "powershift" my mind immediately thinks "temperamental 12V switch".
Is that a possibility?
/ Tractor won't move #19
No the "powershift" on Yanmar is a jewel of a tranny. It is a mechanical transmission with hydraulic clutch packs that engage the different gears. You can change gears without the clutch and therefore, work which requires forward and back motion (ie. loader) can be performed much faster. It is far from temperamental--it is often described as "bulletproof."
The ATF used is Dextron--I use Dextron III.
Mike
/ Tractor won't move #20
I am searching for the hydraulic screen filter on my yanmar F16d but I can't find it. I know that it must be somewhere in left side of the tractor closed with 3 bolts. can someone post photo of it so I can find it?
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
2023 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61573)
2023 Peterbilt 567...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
2025 32in. Mini Excavator Bucket Attachment (A61572)
2025 32in. Mini...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
2015 Nissan Altima SV Sedan (A59231)
2015 Nissan Altima...
