mini excavator
/ mini excavator #1
meanstreak
holland ny
tc 45d
Hi guys,
I'm interested in a mini excavator with an enclosed cab maybe a grader blade with tilt if they make one. Can anyone recommened one?
thanks Blake
/ mini excavator #2
Yes they do have tilting blades now. Are you planing on new, or used? What are the plans for it, type of work to be done? What weight class are you wanting? Give us a little more info and that will help to get the ball rolling.
There are many different brands and most are okay. kubota, yanmar, cat, gehl, takeuchi, kobelco, john deere, new holland, JCB, bobcat, yuchai, etc etc etc.
/ mini excavator
just using it around the property,doing some landscaping. looking for 45hp or so.
/ mini excavator #4
I have a Takeuchi and believe it is the strongest machine for it's weight. However, if you have about $60k to spend, go buy you a really nice new Kubota. I've had a couple of Bobcats and wouldn't buy another. Here's a really, really nice Kubota to give you an idea http://www.kubota.com/product/KX161/KX161.aspx
/ mini excavator #6
I think you'll find that when looking for an excavator you'll be searching weight class more then HP. I have a small one{JCB} that weighs just under 4000lbs, it is very strong for its size and handy. If you're just messing around the yard then 6000lb class may be all you need. Again fill us in on some of your planed chores, it would help to point you in a better direction?
You may also want to check out the heavyequipmentforums. They have loads of info and even a special place for mini's
/ mini excavator #7
Yeah, that's true. Mine is about 6 tons and is in the hp range he stated. As 20 20 knows, the size machine I have will work circles around a full sized backhoe in pure digging and trenching work. It just won't pick up piles and carry them around. I have a couple of tractors and a 100 hp trackloader for that. :)
You can do some mighty landscaping with a 6 ton machine. I don't know what you want to do, but it may be a bit much in reality. There again, you may be wanting to landscape 40 acres.
/ mini excavator #8
My little Yanmar VIO27 is a really handy size. I do plumbing and home chores with it. The hydraulic quick connector makes it the most useful machine I have.
/ mini excavator #9
Hi guys,
thanks Blake
My father in law just bought a Cat 303CR(30hp) w/blade, cab, & HQC and absolutely loves it. The 303.5 is almost 40hp. He owns an excavation company with his brother so you seem to have different needs. I don't know if you can get the blade w/tilt. I do know he also looked at at Kubota and Deere and the Cat was the best deal:shocked:. Not only because of price but also the cab was by far the best as his brother is a tad on the large size. I've played with it a bit and it's definitley a nice machine. However I do think grading could be done more efficiently as the mini's blade is more for back filling.
/ mini excavator #10
Kubota has had the swing "dozer" blades for several years. They are extremely useful, IMO. I bought a Kubota KX-121-3 last year for use around the farm. Absolutely love it!
Mini ex's don't need a lot of engine HP. 40 hp would be a pretty big one. If you ever want to transport it, weight becomes the issue. The 121 was as much weight as I wanted to haul around (around 9000# plus a 4500# trailer is close to maxing out a 1 ton dually pickup).
I don't have the enclosed cab. Lot's of $$$ more for that and I haven't felt the need. I put a hundred hours on mine last summer and fall.
Ken
2017 Toro GrandStand 52in Stand-On Mower (A64553)
2017 Toro...
213097 (A64276)
213097 (A64276)
JOHN DEERE 8360R TRACTOR (A64278)
JOHN DEERE 8360R...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2008 Allmand Max-Lite ML20 20KW Towable Light Tower (A64194)
2008 Allmand...
Dixie Chopper (A64557)
