Pumps pumps pumps
/ Pumps pumps pumps #1
dodge85rc
MN
On the home made tractor I am building I am going to be using the hydraulics to run some "pto" attachments. I have a clutch pump that is rated at about 20 gpm, which is sufficient to run the attachments and should have enough left over to run the steering and a few hydraulic cylinder valves occasionally. What I am starting to think may be the way to go, instead of trying to split the flow and divvy things up, would I be better off to just run a small pump(I have several that are in the 3-5 gpm range) to dedicate to my hydraulic steering and hydraulic valves and keep the clutch pump for the PTO functions and just wire it up to a toggle switch to turn it on as needed. My next question would be, in that scenario would I need 2 suction lines or could I just use one and T off of it or install a priority divider valve?
/ Pumps pumps pumps #2
I believe I would use two suction lines. A flow divider for such things as the power steering would be a good thing.
/ Pumps pumps pumps #3
What would be the difference between two suction lines and a properly sized single line with a T and corresponding properly sized lines?? :confused:
Go with the smaller dedicated pump for steering.:D
/ Pumps pumps pumps #4
Agree! No difference!!!
/ Pumps pumps pumps #5
I think you are assuming that the suction port on the tank is way larger than it is. If the suction port on the reservoir is sized for the current pump, say, 1 in, and you are adding another equal size or larger pump, what are you going to do, use both pumps to draw from that same 1 in port.
Probably have to get a new reservoir, or cut and weld in a new port.
/ Pumps pumps pumps
So I'm lost does it matter if there are 2 suction lines or will a T suffice? The suction line port on the tank is 1 inch.
/ Pumps pumps pumps #7
You will have to know the total GPM's of both pumps in order to figure out if the current suction port is adequate for the volume of fluid. I am thinking that you need two ports.
/ Pumps pumps pumps #8
well....1" is way to small for 20gpm+.....you need at least 1 3/4" for 23gpm and the recommended 4ft per second fluid velocity....then more, 2", if you add mor flow (up to 31gpm)
Have a [URL="http://akkamaan.com/hydraulic/excelsizingnomogram.xlsx"]xlsx-calculator here for hose sizing[/URL]if someone have Excel 97, and want to play with it....on your own risk of course.....LOL
/ Pumps pumps pumps #9
http://kuriyama.thomasnet.com/Asset/H SizingNomogram.pdf
Hydraulic Hose Sizing
* Flow speeds at the lower end of the ranges should be used when designing for a continuous duty system. The inside diameter of the hoses should be chosen such that the needed flow rates can be supplied at fluid speeds within the acceptable ranges listed above.
* The following equation can be used to relate flow desired flow rate
to hose diameter:
Where Q is fluid flow rate in gallons per minute, D is the inside diameter of the hose in inches and V is fluid speed in feet per second, 20 to 25
Q = 2.45 X D2 X V
/ Pumps pumps pumps
to hose diameter:
Q = 2.45 X D2 X V
According to that, with a 20 gpm pump, 1 inch suction line I am right at the lowest mark for velocity for suction lines, if I drew my line straight.
/ Pumps pumps pumps #11
looks more like almost 2" to me....
/ Pumps pumps pumps #12
I would like to see a picture of your clutch pump. I have one for my tracked vehicle project. I don't have a electric clutch for it so I have machined a tapered hub to fit in place of the clutch. Mine only had a 1,000 rpm rating of 10 GPM at 2500 PSI, so I imagine it could deliver 20 GPM like yours at 2000 RPM or so? Mine has a 24ORB inlet and I think 16 ORB outlet. In my case the shaft on the pump is so short I may not be able to use the face mounting bolt holes as they will interfere with the pully. thanks
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
Woods 72" Brush Cutter (A64047)
Woods 72" Brush...
2015 John Deere 332G Skid Steer w/ Bucket (A63688)
2015 John Deere...
2017 Bobcat MT85 (A64126)
2017 Bobcat MT85...
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A64281)
UNUSED WOLVERINE...
2017 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
