Buying Advice 400CX vs 400X
/ 400CX vs 400X #1
tschwerm
Southeastern Wisconsin
John Deere 2005 4120
I am looking at used 4120 and some have the 400X and others have the 400CX
Other than what i have researched on extra lifting capacity and self leveling for the 400CX are there any of you experts that could shed a light on disadvantages to the 400CX. I thought I saw somewhere ?rollback angle? what is that?
/ 400CX vs 400X #2
Rollback angle is how far the bucket "curls" back to scoop a load, it is decreased with the CX and can be a issue at times.
/ 400CX vs 400X #3
I have had both types of JD FELs (self leveling, non-self leveling) and skid steer with self leveling. If you plan to use pallet forks, manlift, bale spear or other attachments that need a lift geometry where the postion of the attachment remains constant, then strongly consider the self leveling. Really helpful for pallet fork because frequently I can't see the forks to determine position. Non-self leveling is better for heaping loads of material in the bucket.
You probably can't carry any more stuff/material in the non-self leveling FEL, but when you raise the FEL arms, it is easier to keep it from spilling out of the bucket as you drive. If you use a mixture of duties, I would recommend the self-leveling.
JDs self leveling FEL also gets a little more lift capacity which is never a bad thing.:)
/ 400CX vs 400X #4
How much is it decreased?
/ 400CX vs 400X #6
Do you have the CX and X reversed? Looking at that doc the rollback/dump angles are 43/45 degrees for the CX, and 32 and 46 for the X, so it seems a little better on the CX than the X.
The Rollback Angle at full height is much better on the X (117 vs 43) but I would think that much more than 45 at full height would be dropping crap on the hood. :)
/ 400CX vs 400X #7
The roll back angles are given at ground level. As I raise the cx, the angle stays the same. As some one without a self leveling raises theirs, the angle appears to increase. Some to the point that the bucket opening appears straight up. A heaped bucket with the cx will lose material. I will try to get a pix this afternoon and post it.
/ 400CX vs 400X #8
My last tractor had dents all over the hood! Gravel damage... I seem to recall that the older '00 and '10 series of JD CUTS offered an armour package that included a full-length hood cover.
I used a SL loader this past summer loading small square bales on trailers and hay wagons. It was a great help to ensure that the front end bales didn't plough into the bottom layer of bales (you can't see the front end of the bales) or the rear bales didn't plough into the layer of bales closest to you (while you're gawking at the front of the bale pod).
My next FEL will be self-leveling.
AKfish
/ 400CX vs 400X
Well On Friday I will be experiencing the 400CX I just bought a used one with a 4120
/ 400CX vs 400X #10
Without getting into the technical details, I'll just tell you that I spread about 40 tons of large crushed rock Monday with a 400CX, and I was able to scoop full loads, and carry them with no problem. I kept the loads below hood level in transit, and was able to raise to above eye level for spreading, all with no difficulty, or accidental spillage :). I'm a novice, so I have no experience with non-self-leveling loaders - I was very happy with the performance of the 400CX.
/ 400CX vs 400X #11
As promised, pict. Better late than never. Moot point for the original poster, but for others. The comparisons are not exact, but compare the edge of my 2305 with 200 cx with the 4520 with 400cx. Full loads of 3/8- crushed. All three pict full rolled back.
/ 400CX vs 400X #12
I think the capacity of the 4n1 is less than the standard bucket. And the length of the bottom of the bucket and the depth (length of the sides) is correspondingly less.
So, I'm wondering if the problem of "losing part of your heaped load" is not nearly as bad with a standard or HD bucket and the SL loader as it might be with the 4n1?
AKfish
/ 400CX vs 400X #13
I went with the 400X on my 4720 and wish I would have spent a few extra bucks and got the 400CX. It was my fault for not researching it to see the differences. My dealer told me about the self leveling and I thought I did not need that. However if I had known about the difference in lift capacity I would have gone with the 400CX. :(
/ 400CX vs 400X #14
Me too...
4120 with a 400x and a 4n1
With the additional weight of the bucket, the added lift capacity would have been a big plus.
2018 BRADLEY MACHINE MINI VAC TRAILER (INOPERABLE) (A67714)
2018 BRADLEY...
2016 JOHN DEER 5075M TRACTOR AND BUSH HOG (A66091)
2016 JOHN DEER...
Ez-Go Electric Golf Cart (A64912)
Ez-Go Electric...
New Holland TS6030 (A64911)
New Holland TS6030...
3145 (A63117)
3145 (A63117)
2016 Chevrolet Tahoe SUV (A66738)
2016 Chevrolet...
