64 Ford 4000 Temp Gauge
/ 64 Ford 4000 Temp Gauge #1
Big_Tex
New Braunfels Texas
64' Ford 4000 Industrial
I am trying to install a new temp gauge but the previos owner cut the cable to the block. I have been unable to find where to hook into the block for the temp sensor. Does anyone know where this would go or have a pic or diagram?
/ 64 Ford 4000 Temp Gauge #2
I have a 72 ford 2000 and the temp sensor is on the front of engine right above the water pump. Hope this helps
I will look there this afternoon and see if I can locate it on the front of the engine
I didnt see it up on the front of the engine. Any other ideas on where the original would have been?
/ 64 Ford 4000 Temp Gauge #5
I believe it is the same place as on my NAA model. That would be on the right side of the engine near the rear, just in front of the battery box. I'll check for sure and post back in the morning.
EDIT: Yes, its at the rear of the engine head inline with the spark plugs and just in front of the battery box. The original probably had a bulb in the engine and flexible metal tubing running up to the gage wrapped in a wire spiral for protection.
I will look there this afternoon and let you know if I am able to locate it.
/ 64 Ford 4000 Temp Gauge #7
Here's a scan of a photo showing power steering components, but it also shows the location of the temperature probe (circled in red).
I looked there and did not see anything. I removed the battery and looked all across the back of the engine and did not see anything that resembled access to the block. Everything else on the diagram you posted looks identical to my engine except that component
/ 64 Ford 4000 Temp Gauge #9
I had a '64 Ford 4000 industrial and I swear the temperature probe was right there on the back of the head. as shown in the photo. Your profile says you have a '68 4000 Industrial. Is it possible you have a typo in your thread title? If your tractor is a '68, it might have a different head without the port for the temperature probe. :confused:
BTW: Are you aware that the temperature probe and gage are NOT electrical? There is a bulb that screws into the head and a tube that runs up to the gage. If there is anything electrical, it might be a light that can be installed into the gage for night viewing. If your gage was removed, the head might just have a plug installed where the bulb previously was.
It is a 4000 industrial 4cyl gas with SOS transmission. I am looking for a plug that would fit the new sensor that is a replacemnt for the the 64 4000 that I purchased online. I did see a bolt on the back of the engine but it did not look large enough to house the sensor unit.
I will take some pictures tommorow and post them
/ 64 Ford 4000 Temp Gauge #11
My 4000 was exactly the same. Here's a couple of pictures before I sold the "beast." I was never so happy to see a tractor leaving on a trailer as I was to see this ol' smokin' Ford go. The "Select-O-Leak" transmission was not one of my favorite features.:rolleyes:
/ 64 Ford 4000 Temp Gauge #12
That photo shows the exact location of the temp sender in a 134,144, 172 or 192 cu.in. Ford 4 cylinder engine. There is a provision for the sender to be installed there, no doubt.
Well you guys are correct. It was behind my ground wire so I didnt see it on the corner by the plugs. I was able to get the new temp gauge installed thanks to everyone that gave me input.
Now a new problem has shown up.
I lost all electircal power. No starter Not Aux light when I turn the key. Everything was running fine yesterday and turned over once today before aux light went dead so I am charging my battery right now to see if that is the problem first but any other ideas as it did not seem like the battery was dead when it turned over today. It seems like a pretty simple system so I would think only voltage regulator, battery, starter, and altenator.
After putting the battery back on this morning everything started up and ran fine until around 2pm today then the same thing happened. I try and start and I hear a click so I test the battery and it has full charge but I have no light when I turn the key to the on position any ideas?
/ 64 Ford 4000 Temp Gauge #15
it's not on the back, but on the same side as the spark plugs.
I have a 63 4000 4 cyl I'm working on right now.
soundguy
/ 64 Ford 4000 Temp Gauge #16
put a volt meter on the battery and try to start.. does battery drop?
if no, then check cables and ends to the solenoid, and to ground.
if I read correctly you might have moved your ground cable to replace the temp sender.. did you find a good ground for it.. or a rusty sheet metal ground?
soundguy
I put the ground back in the same spot attatched to the frame that holds the gas tank up?
I put the battery back on charge again tonight to see if that changes anything. I will try the voltmeter in the morning to see what happens when i try and start. Any other ideas let me know and thanks for the help tractorbynet is an amazing community for information.
/ 64 Ford 4000 Temp Gauge #18
Go back to that ground connection and make it clean, bright and tight. Then do the same for the rest of the battery cable connections. The probabliity of your new electrical problem being coincidental is very near zero.
/ 64 Ford 4000 Temp Gauge #19
Ditto that.
sheet metal connections are usually my 2nd choice.. but keep in mind.. that fram is connected to chassie and probably rusty there as well.. and the starter gets it's ground thru chassie, then that rusty connection to the gas tank frame.. then that ? dirty connection to the battery cable.
on some large tractors some people run another ground cable from the chassie ground where the battery hooks to over to a starter hold down bolt.
likely not needed in this application.. though as rick points out.. good clean grouinds are.
soundguy
I moved the ground cable and problem seems to have gone. Only issue left is to get the exhaust manifold connection to the muffler fixed and should be good to go for the spring.
Thanks for all the help. Im sure I will have more questions in the future
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
2003 NV FLATBED CURTAIN SIDE (A67714)
2003 NV FLATBED...
ETNYRE FWD CHIP SPREADER(INOPERABLE) (A67714)
ETNYRE FWD CHIP...
PALLET OF HOSES (A68842)
PALLET OF HOSES...
207923 (A63290)
207923 (A63290)
