2615 HST pedal adjustment
/ 2615 HST pedal adjustment #1
kenboat
Southern Illinois
Satoh Beaver for now
Could someone post the adjustment procedure for the HST foot pedal ? Our tractor wants to creep in reverse when you dont have your foot on the pedal.
Thanks, Ken
My 2615 HST is different. I had seen that post when i searched around.
Thanks, Ken
/ 2615 HST pedal adjustment #4
Thanks, Ken
Mine too, and it creeps. It started when ther was only about 6 hours on the machine.
There's a small piston (probably pneumatic) on the R/H side of the gear box with linkage going to the HST pedals. The piston (about 2" dia.) has shafts on both sides and it all links to a large shaft going into the gearbox.
The ONLY possible adjustment I see is a 12mm nut on the forward piston shaft, but I have not taken any reference measurements yet to get this back where it came from in case any adjustments I make FUBAR the HST response.
Right now, the creep is slight but annoying in both FWD and REV. I'll report back if I'm able to diagnose and fix it..
/ 2615 HST pedal adjustment #5
Here's the adjustment for your pedal. Open the jpeg file with paint and enlarge if you need to. I also attached it as a doc file.
/ 2615 HST pedal adjustment #7
You are the man, George. I have been using computers in my business since 1986 and today I can't get pictures like that on TBN. I have had people try to show me, but if I can't physically get my hands on it I can't seem to do it. I envy you computer people.
/ 2615 HST pedal adjustment #8
I'm not that great of a computer guy. I know just enough to get by. I wish I was more computer savvy then I'd be able to find out why it takes my computer so long to boot up.
I do know how to scan a page on my combination printer, scanner, copier, from a book or picture and save it as a file which is all I did.
Ok George, I will say it to, YOU ARE THE MAN.
We have the tractor inside and going to get it adjusted. I have a small boat shop and we move the boats around with the tractor. It makes it a bit of a pain when it wants to creep back.
Thanks again George, and everyone else. Ken
Well, that was easy. Works perfect now.
Thanks Again, Ken
/ 2615 HST pedal adjustment #12
Thanks Again, Ken
Ken Awesome! I'm going to adjust mine this weekend. Anything special I need to know besides what George posted in the instructions?
Thanks.
/ 2615 HST pedal adjustment #13
George
My thanks to you as well. My 2015 was creeping forward and backward and was getting a little tense when I got close to things.
Your post helped me fix it.
My sincere thanks.
A point of interest... the first step (the rod with the thread on the end that was supposed to have a little slop in it didn't have any slop). So I just went to the part about adjusting the distance to 6.15" and I had to adjust it a little further but it worked!
Sincere thanks again
Patiofarmer
