Homemade gauge wheels for rake
/ Homemade gauge wheels for rake #1
Window Geek
Central Mass.
2006 Kubota 7610 HST 4WD
I built my own set of rake wheels after the TSC wheel set was almost as much as the rake.
I started with a set of 10 350# capacity casters on sale from Harbor Freight. Looked over some of the wheel pictures on TBN and started fabbing right by the rake while attached to the 3PH.
I measured the bolt centers on the rake, then cut and drilled some 3" channel iron I had in the spare pile. I welded old pieces of quick strut to them making sure I gave enough room to have the casters spin. It also gives me better grading since the 7610 Kubota isn't all that long to begin with. I chose the quick strut because it will give (flex twist) without bending permanently during hard turns or hanging up on something.
Next, after figuring which size pipe slipped into other pipe, I welded the sleeve onto the end of the arm. I bought threaded rod joiners (extra long nuts) for the adjusting screws, drilled a hole for the screw to fit through the sleeve, and welded the nuts in place. I left the bolts in the nuts to prevent spatter from messing up the threads.
I wanted the casters to be bolt-on in case they ever got damaged. I built bolt-on plates from twin pieces of 1/4" x 2" flat bar, welding them together side by side. I welded a short section of ¾ pipe onto the plates to act as reinforcement. After making sure they were square to the plate, I slid the larger pipe over the short sections of ¾ pipe and welded those onto the plates. After the wheels were bolted on I assembled it all together onto the rake.
The drawing guy (me) screwed up on the height of the wheel stem and after assembly, it was clear I wouldn't be able to get all the adjustable height I wanted.:mur: I headed back to Home Despot and got some more ¾ and 1 ¼ pipe to extend the height of the wheel stem. I sleeved the ¾ pipe into both wheel stems, tacked them in place and sleeved the extra sections of bigger pipe over that. I finished the top of the longer wheel stems with pipe cap to keep them from sliding out. Welding some 3 inch pieces of ¼ x ½ flat stock onto the adjusting bolts made tightening by hand easy. A buddy of mine painted the arms with urethane paint to finish them up.
The TSC wheel set was $324.00
The home made set cost:
2 Wheels $12.99 ea $25.98
Scrap channel $ 0.00
Scrap Quick strut $ 0.00
Pipes from HD $17.12
Nuts and bolts $ 2.00
Total $45.10 :thumbsup:
Thanks to all the inspiring folks at TBN. You give me the confidence to try new stuff. Someday I'll try to do work like 4shorts or MJNCAD! (More tools and space and time will be needed first!) :D
/ Homemade gauge wheels for rake #3
Impressive. Adjustable, simple and cheap. Woods wanted $335 for a set!
I have been looking for an idea for my rake and this is along the way I was thinking but could not figure out. Thanks.
/ Homemade gauge wheels for rake #4
I am on my second modification or maybe third of my homemade wheels. Wheels have not wanted to track correctly. Let us know how yours do. You have done a nice job putting the together.
Ninefinger, it tracks well. I can set the heights different to get the scoop harder or lighter on one side. The casters always swivel to the line you're pulling on. Turn the rake to 45 degrees right or left and the rake still tracks. If the rake shifts side to side a little from a heavy chunk, the wheels still swivel.
I made the clearance enough that they can spin nearly all the way around. Not that I want to back up, but you always end up missing little spots. If the wheels can't swivel, the rake will lock up the wheels when they hit the back of the rake or bump a stone that won't scuff over.
/ Homemade gauge wheels for rake #8
Looks like you need to keep air in them tires. If so, I'd think hard tires would be the trick. I'm sure you can go that way if you choose. Looks good. I would like to put a wheel or two on the back of my Land Pride Blade.
/ Homemade gauge wheels for rake #9
If this last mod, when I had time to finish it, does not work I think those casters may just be the trick I need. Thanks
/ Homemade gauge wheels for rake #10
Nice work.
The wheels might need to have foam added. Their ability to hold air isn't too reliable. I seem to spend a great deal of time installing new tubes in these for people.
Nice work.
Thanks Gee. The foam idea sounds good. I've always had luck with filling the small pneumatic tires with Slime, the green self seal stuff. If you're raking a lot or making money at it, the foam is a good option. I like the adjustability of air tires and I am definitely not raking much, just a few times a year for me or friends. I've even set the wheels high enough to hold the tines up about 1 1/2 inches so I can rake the leaf piles without beating up the lawn. The more solid tires might not be as forgiving. Either way, if Harbor Freight only sold big solid casters for the same price, I probably would have bought them! :laughing:
There must be a reason that York makes them pneumatic too. I just tried to copy York on the cheap. :D
/ Homemade gauge wheels for rake #12
:D
Guess that explains why my "Anti-scalp ki" for my NH rear mount finish mower was in the 130 dollar range. I was a bit surprised when it showed up in an 8" square box! It was a roughly 6"x4" plastic roller, a 3/8" axle rod, and two cotter pins. Glad it was a peace offering from the regional sales rep, because it didn't make a bit of difference!
/ Homemade gauge wheels for rake #13
Ah that's what I like. An idea that's well thought out and then put into action. Very nice design and workmanship. Oh. You might want to keep an eye out for your postman. Somethings on the way today from Newfoundland :thumbsup:
/ Homemade gauge wheels for rake #14
WINDOW GEEK i want to thank you for the inspiration. I started my build of guage wheels pictures are on the CUSTOMIZATION section. thanks everybody for the input.
/ Homemade gauge wheels for rake #15
Nice work:thumbsup:
As I read with interest GE222 speaks of foam filling tires to prevent flats. Any information on how to do this and what type of foam to use?
/ Homemade gauge wheels for rake #16
Nice Job do you guys think this would work pretty well on a box blade also
Around here the postman only rings once. (thank God!) :laughing:
Thanks 4shorts for your comments and compliments. That paint makes the welding look way better than it is...:eek: But so far, it's held together.
I'm thinking about a simple set of brush forks next. That'll keep me occupied for a bit. Or maybe that brake warning light! I've got to check out the switch options.
/ Homemade gauge wheels for rake #20
Window Geek,
Nice work on the gauge wheels. Hope you have better luck than I did with the HF air-filled tires. I originally had them on my gauge wheels and one blew out within about the first half hour of operation. I have since switched over to solid tires.
1998 STOLL 35' GOOSENECK LIVESTOCK TRAILER (A63291)
1998 STOLL 35'...
1997 JLG N40 Electric 40ft Articulating Boom Lift (A61572)
1997 JLG N40...
2013 International 4300 Bucket Truck 55' (A62613)
2013 International...
2018 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2018 Volvo VNL T/A...
2018 New Holland C227 Compact Track Loader (A63689)
2018 New Holland...
2022 Tesla Model 3 Long Range AWD Sedan (A61574)
2022 Tesla Model 3...
