yanmar 186d new purchase
/ yanmar 186d new purchase #1
jerrybob
Super Member
USA
yanmar 186D....JD LT180....DR Brush Cutter
I recently bought a yanmar 186d.....very nice little tractor. I noticed when I throttle up in higher gears.....some smoke is generated. Seems to be fine when running at lower rpm. Smoke isn't bad.....just a little more than I expected. Is this normal. I plan to change oil and filter and air filter is pretty old looking. Any advice?? Also....being new to the tractor world.....should I do any other maintenence immediatley? Everything seems to work well.
/ yanmar 186d new purchase #2
Welcome and congrats on the new tractor!!! You probably want to add fuel filter to that list for sure. Since it's a new purchase and you may not know how well it was maintained for added peace of mind you may also want to drain the transmission / hydraulic oil and clean the filter screen (or replace filter on your model??) and drain the front axle and refill. A flush and refill of the radiator may be a good idea also. What color is the smoke? Do you see any bubbles blowing into your coolant reservoir once it has reached operating temperature? Are you loosing coolant and you have to add coolant after you work it? Is the fuel clean and fresh? You may want to add a little Power Service additive to your next few tanks of diesel. Mine smokes only at startup mostly when it's cold but otherwise I don't see any smoke.
Thanks for the reply and advice. I will change out the fluids and filters as you suggest. As for coolent loss......I have none....everything seems to be fine. The smoke is a white/light blue color......seems to be worse when I rev. the motor. When I am moving.......seems to go away. Overall...the tractor seems to perform very well. Also.....forgot to mention.....no bubbles.....looks fine. Thanks again for the input.....very helpful.
/ yanmar 186d new purchase #4
Sounds normal to me as long as it's not constant heavy smoke. Some fuel additive like Power Service may help clean up the injectors if they need it. If I missed anything there are some guys on here that will be along shortly I'm sure to correct and advise that know these Yanmars far better than me.
/ yanmar 186d new purchase #5
Lube everything that moves. I neglected my lower lift arm pins and almost destroyed my left side axle housing.
Thanks guys for the good advice. I will be following all of it. Question.....my 186d was originally sold in the US. Can anybody tell me what model number is the "grey market" equivalent? Would the parts be the same?? Spent my first day with my tractor today.......lots of fun!! Thanks
/ yanmar 186d new purchase #7
YM1510D is said to be similar. I've read that its front axle is completely different, and I don't think YM1510D has the external air cleaner, or the big hydraulic filter in front of the fuel filter. And it doesn't have the 'overrun clutch' (one-way ratchet, actually) inside its PTO. I think the engine, sheet metal, and performance specifications are identical. And the gray market dealers who post here have all the parts you need.
I bought a YM186D last summer and I'm just getting familiar with it, so I cant be much of a resource on these. My YM240 is still my primary tractor, with the YM186D intended for working closer under my orchard trees. (Mowing right up next to the treetrunks etc). I sure hope your YM186D is prettier than mine! Photo of both.
Thanks for the info.......I am impressed with the knowledge out there. Really helpful to a new guy. My 186d is quite nice and recently was painted. Picture attached.....nice tractor. Thanks again for your help.
/ yanmar 186d new purchase #9
JerryBob,
I noticed your 186D has a roll bar (ROPS). Can you tell if that was mad for that unit or does it seem to be a custom add-on?
I'm going tomorrow to buy a 186D from the owner of the house w/10 acres we're buying. I've never owned anything more than a lawn mower so this is uncharted territory for me. I appreciate all the info in this forum to get me up to speed...at least 1st gear.
The unit I'm looking at includes at least a brush hog and a blade for which he's asking $5000 for the bundle. I'd like to get the tiller and post hole digger as well. He says the hours meter stopped working so I don't know that number.
Here are some pictures.
http://tinyurl.com/yahgttt
http://tinyurl.com/y8dr9va
http://tinyurl.com/yd63c5r
http://tinyurl.com/yc53cek (auger)
http://tinyurl.com/y8de2l8 (tiller)
http://tinyurl.com/yz96dkw (howse brush hog)
Any insights would be appreciated.
/ yanmar 186d new purchase #10
Those are some nice tractors there. I considered buying a 186D but got a 169D instead due to the lower price and better condition. The 186D will treat you well for sure. These Yanmars are very reliable tractors. Im not sure if the 186D offered factory ROPS but there are aftermarket companies that make ROPS for reasonable prices. I can say that having ROPS makes you feel a whole lot safer, especially with a Loader or using the tractor on hills. Good luck to you both. Those 186D's will treat you well.
/ yanmar 186d new purchase #11
Fixedon66, I would say he is asking top dollar. The front half of the air cleaner is missing so the pre-cleaner is bypassed. I expect that loads up that filter element pretty quick and to me it indicates neglect.
Yours looks nicer than mine but I paid half that. (plus some initial renovation which I think you may have to do too.) Figure $750 ? for a ROPS, to start.
If you have 6 months to look around you can find one nicer with a loader on it for that price.
I would offer less and be ready to haggle. Just my advice; be sure to listen to others before deciding.
Fixedon66.........I thought I hit the send button but maybe not.....if this is a duplicate.....I apoligize. The ROP seems to be part of the original package for my tractor. It could be removed with some effort.....a very nice safety feature. As for the $5000......seems about right....I paid a little less but I also got a FEL. You might want to negociate a bit. I highly suggest you change all filters and fluids as mentioned by the folks in my original post. I found some water in my trans. fluid due to a bad filler cap. Also....oil in front axle was filty. Make sure to lube every fitting....there are lots. Check your trans. screen and clean. I have ordered a bunch of stuff from Hoye Tractor......great folks to deal with....very helpful....they have everything. They have the missing cap on your air filter. Good luck and enjoy your tractor.....the 186d seems toe a great little machine.
/ yanmar 186d new purchase #13
Thanks JerryBob & California! I've mapped out some farm equipment stores around the area and won't make a deal until I get a good idea of what else is available out there.
I don't see needing the equipment until early to mid summer since there are a couple horses on the land to do most of the mowing. :) From car buying experience, buying from an individual seems to be the most economical way to go. I just don't have many contacts in the farming community to get leads on tractors for sale so I don't want to pass up a reasonable deal only to not find anything better in the next few months.
California, you posted a great walk through of testing a 186D someplace here. I cut and pasted and plan to use it today. Thanks.
/ yanmar 186d new purchase #14
The YM186d is a great little tractor, but that one with the equipment seems a bit overused for the price. How are you at maintenace? Is doing tractor maintenance part of why you got the property - it was for me. Honestly. And I've had a few tractors and lived my life on property about like it looks like you are buying.
You will use your little utility tractor more than you can ever imagine at this point. GET A FRONT END LOADER! It will be the primary tool for you just like an old cowboy and his horse.. - and if you are not using as a tractor it will be carrying everything from groceries and hay bales to the tools for whatever job you are doing. You can't buy a new back, so save yours. A good tractor will last you a lifetime.
With all that in mind, I would rather see you spend twice the money and end up with a newer machine with a front end loader. Four wheel drive is a great advantage on any smaller lighter tractor. Implements are universal, and you can get them anytime and they fit any machine.
rScotty
/ yanmar 186d new purchase #15
I agree with what CA said - I'd figure in the cost of a ROP - It likely has an Old battery in it that will need replaced etc etc.
If you are really sold on the unit, I'd proceed with "I'll give you your asking price on the tractor and you throw in the tiller and PHD.
/ yanmar 186d new purchase #16
RScotty,
No, I'm buying the land to enjoy and keep up the land, not the tractor. I've never even ridden a tractor so maintenance will not be easy. I'm pretty handy around the house and with cars but not diesel or tractors.
After visiting some dealers I'm very interested in no interest (pun intended) financing for a new tractor with a front loader, box blade and brush hog. I may see how the brush hog does on the grass around the house and decide if I want to buy a finish mower for that area. I can also keep a eye out for used over the next few months but with my lack of knowledge about tractors, it might be best to pay up front to get an education in USING a tractor and delay (hopefully) my education in maintaining one.
I'll let you know what happens. Obviously if I don't buy the Yanmar I might not find another one so I probably won't be hanging around this forum much longer. You guys have been a great help, though. Thanks again.
/ yanmar 186d new purchase #17
There are other forums attached to TBN besides Yanmar. So if you buy green orange, white, blue , whatever there is a forum for you.
/ yanmar 186d new purchase #18
Lubrication. One point that I know of that several folks miss it the front axle pivot on the main frame under the engine.
It is often neglected, there is a zerk for both front and back bearings, be sure to check or they will be wiped out easily, especially with a loader on.
/ yanmar 186d new purchase #19
Yes, where are those? I looked all over the area from the underside and couldn't find them. Do you access them from the top (on floor of engine compartment)?
/ yanmar 186d new purchase #20
The front axle grees fittings on my 2wd yanmar 2000 are under the axle, if you go to the front of the tractor look under the axle engine area they either point foward on the front and back of the axle or face down, i cant remember. Yours may be busted off from running over trees or stumps?
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
Fellabuncher Dangle head, PARTS ONLY (A62679)
Fellabuncher...
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
2001 John Deere 6210 (A60462)
2001 John Deere...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2015 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2015 FREIGHTLINER...
