B7800 died HELP!!!
   / B7800 died HELP!!! #1
logan97
Gold Member
Blue Ridge Mnts, Va
Kubota B7800 4/wd
This morning while working with the B7800 got off the seat and within 15 seconds it died would not start again. Everything is in neutral,parking brake is on. Looked underneath and noticed near the clutch springs a 1/4" or so bolt dangling ???? HELP!! first day I have been able to work since mid Dec. :confused:
   / B7800 died HELP!!! #2
Is the PTO engaged? if it is it probably wont start due to a safety feature.
   / B7800 died HELP!!! #4
perhaps a bracket holding a saftey switch fell out ? I'd run through all the saftey switches you have on the tractor first.
Did you figure out what the dangling bolt was for?:D
got a schematic from Messicks with the clutch assembly but does not show the bolt that is hanging? turned the key to start position gently moved all levers, PTO 's are not engaged.
   / B7800 died HELP!!! #6
Check the neutral position of the for-rev treadle. Sometimes I have to jiggle the foot pedal to get the safety switch to engage.
However the loose bolt needs to be thoroughly investigated and returned to its' proper home.
Bill
Bill
(Check the neutral position of the for-rev treadle) the engine died while it was running and I was off the seat??
the bolt is from part # 110 from the clutch assembly page,it is in its proper home. It has threads on the end of it. Have not yet determined it's function. :(
   / B7800 died HELP!!! #8
I'm confused...............Won't start or won't crank. Two very different issues.
will not crank.I get a little clunk/click noise when the key is turned to when the red lights come on but this is all.The starter will not engage, nothing?
   / B7800 died HELP!!! #10
Since it died and will not crank you have lost power or ground to the system.
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2017 JOHN DEERE  30G (A50854)
2017 JOHN DEERE...
2014 KENWORTH W900 MID-ROOF SLEEPER (A50854)
2014 KENWORTH W900...
SCAN FOR HAULING AND FINANCING INFORMATION (A51242)
SCAN FOR HAULING...
2022 FREIGHTLINER CASCADIA SLEEPER (A51222)
2022 FREIGHTLINER...
