Clutch on my 2000B
/ Clutch on my 2000B #1
brdavis
Can someone help me?
I have a Yanmar 2000B that I just changed out the rear tires. When I parked the tractor it ran perfect. After changing the tires the clutch quit working. It will not engage. In other words if you start in neutral you can稚 get it in gear. If you try and start in gear it starts rolling even with the clutch pressed. I didn稚 change or work on anything other than replacing the rear tires.
/ Clutch on my 2000B #2
The clutch is just rusted stuck. Lots of ways to free it. Drive it around with clutch depressed and slam on the brakes once in a while. That's what the little latch is for.
That did it. Thanks
/ Clutch on my 2000B #4
Any time you know it's going to sit for more than a few days you should latch the clutch pedal down.
I always wondered what that latch was for.
/ Clutch on my 2000B #6
Does anyone have a Pic. of the latch would you? the reason I ask is my eng Ser.# is the same as the 2000BD 2TR20A but I do have a -A after it also. On my Trans Ser# 15000 I have nothing that even looks like there is or was a latch. The Eng. may have been replaced or possible may have been be a VN recon at one time? Could be no ROP's and just wondering if I should come up with a way to latch down the clutch pedal before I end up with the same problem if I let it sit ?
YM2000-------------22-------2WD-GEAR------------2------------1670--------75-77------------2TR20
YM2000BD-----------22------4WD-GEAR-------------2------------1940---------79.-------------2TR20A
Thanks
Carey
/ Clutch on my 2000B #7
/ Clutch on my 2000B #8
Carey, my YM240 has the same engine, 2TR20A-X. Here's a photo showing my latch. It is bolted to the transmission case about halfway down, behind the most-forward part of the clutch pedal assembly.
I have never used mine, and never had any trouble. I don't see why these clutches are any different than in say a Nissan which is probably the identical clutch. I expect Yanmar designed that for worst-case, ie running half submerged in the rice paddies then putting the tractor away wet and storing it for months until next season.
ps for anybody interested - the pic shows the loader's bracing to the rear axle which takes some stress off the bellhousing. And the 'old man step' I added. I posted that picture here originally to illustrate that step.
/ Clutch on my 2000B #9
did all models come with this? as mine does not have this,nor do i think it needs it. mine has sat for months and not had a sticking clutch.
/ Clutch on my 2000B #10
I never would have thought that over the years Yanmar used more than one setup for that latch.
/ Clutch on my 2000B #11
Not there Cal. If I look hard I can see something in the casting for the screw hole to be drilled or knocked out possibly? I store it under a car port and the new to me has been long gone so if it's raining outside I'm not going to use it unless I have to ;)
Mus.and Neat that is what I was woundering also. Any problems sticking No! just trying to avoid any. I have no intentions of competing with the Price of Rice in China/Japan so I don't see any future water issues:p
Thanks
Carey
/ Clutch on my 2000B #12
When shopping for my Yanmar I saw a lot of them, straight out of the shipping containers, with an ornately carved stick in the tool box. What do you suppose that could have been used for:confused:? BTW I had a stickshift ford that stuck the clutch once. I pushed it up against a tree, bumped the starter a few times and it broke loose.
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
213088 (A64276)
213088 (A64276)
Caterpillar 245D Excavator Service and Parts Manuals (A63117)
Caterpillar 245D...
Bandit 250XP Wood Chipper (A63689)
Bandit 250XP Wood...
UNUSED WOLVERINE HYD GRAPPLE BUCKET (A64281)
UNUSED WOLVERINE...
2011 Freightliner M2 106 Medium Duty T/A Dump Truck (A61573)
2011 Freightliner...
