Need some help with cable controls
/ Need some help with cable controls #41
You're getting there with the mower Cyril. That's just the ticket for mowing scary ditches and near pond shore lines.
/ Need some help with cable controls #42
OK everyone, here are the pix of the mower. No cable control yet, but we're getting there.
Cyril that's a great looking set up. Your son takes awesome photo's there sir. Great looking tractor. Sure wish you'd find a cure for the cables. If there's anything on my end I can do just pm me. I have a lathe and other stuff here at the shop and if you need something made I might be able to help. Between Canada post and USPS we might make it work. That's if you trust a Kubota guy :D Just a thought. Paul
/ Need some help with cable controls #43
I wonder why there is not a lot more of these type of mowers talked about. ive been looking for dealers and prices for this type of mower and its imposible to get a price for a new boom flail mower online, Its easy to find the large side arm mowers but to fit small tractors its impossible.
Although I have not priced new ones personally, I've heard that they're around $18-20K new and I don't think there are alot of them around.
Paul,
Thank you for the offer. I'll send you a PM when I'm ready to tackle it. It should be within the next week. I have a few options available and I'm trying to decide which way to go. Some of the work I'm going to do today will help in making that decision. I'll have some pictures and posts after I get home from the ranch today.
Today went better than I expected. I figured out how to disassemble the cable and get the collar off. First I had to disassemble the control housing (pic #1). Then remove it from the housing (pic #2). Then I could slide the jacket of the cable far enough to see the hexed portion of the cable to unscrew the spool stop from the end of the cable (pic #3). After the spool stop was removed it was just a matter of screwing the collar off the end of the cable.
Another issue I have found is that there is greas in the spring centering portion of the control which is probably origionsl and is now just dried gunk. The old dried grease makes the controls very stiff and sticky. How should I go about cleaning this before regreasing? Also, what type and how much grease whould I use?
Pic #4 is of the full opened control handle and pic #5 is of the existing mounting which is on the right fender. I am going to make a bracket to be able to use this to mount the controls in this location.
/ Need some help with cable controls #47
Are you sure it is grease??? It could be graphite paste too....very common in different types of cables....like parking brakes etc...
No, I'm not sure. I think it is. If you look closely at the first picture above, you can see some of it that is kind of a translucent yellowish color above the spring toward the left. The grease? around the spring is darker (dirtier?). It does look alot like dried grease. It lubricates the nylon? pieces on the shaft where the spring is located. These nylon? pieces are pulled inward to the center when the control lever is actuated and the spring provides pressure to return the lever to neutral when released. One is for each direction the lever is moved. If needed, I can get some clearer pix. All feedback here is appriciated.
Here is a more clear pic.
/ Need some help with cable controls #50
I would soak everything in mineral spirits to clean...then pack with new synthetic grease.
Here are some pix of the origional collars after being removed from the cables. 4shorts, 3rrl, and myself are working on ideas for fabricating new collars in the lengths needed for the cables to operate properly.
Something else I need to figure out, is how do you measure rollpins for proper sizing? I have one which is broken in one of the controls and the manuals do not break down the parts far enough to give descriptions of the rollpins. I will have to measure either another rollpin or one of the holes to determine the proper diameter. Also, as these were made in England, do rollpins come in metric sizes as well as inch measurements?
/ Need some help with cable controls #53
I second KennyD's suggestion of mineral spirits and synthetic grease or cable lube, or I like naphtha since it doesn't leave a light oily film like mineral spirits do.
McMaster-Carr www.mcmaster.com carries metric roll pins (a.k.a. tension pins). The nominal pin diameter is the hole diameter, therefore specify the pin by the hole diameter when you buy them.
I look forward to seeing what you, Paul and Rob come up with.
/ Need some help with cable controls #56
I think I managed to track down the current owners of the company who origionally made the control unit. Morse Cable | Control Cables I eventually plan to contact them, but for now, I'm going with the quick fix.
I'm currently working with Rob (3rrl) and we are looking at just making what I need. I sent one of the pieces to him Monday. I should get some feedback from him shortly.
Work has picked up some and it's been nice taking a mental break from the tractor this week. Hasn't hurt the budget either. I need to go up to the Deere dealer tomorrow as my $85 filter is in for the mower. I still can't believe that the return filter is $85. Ouch. I need to pay for the 15gallons of fluid I got last week too. It's nice having an account at the dealer, but I need to limit myself and spread out the costs. Later next week, I'll look at getting a mount for the controls made.
I heard from Rob (3rrl) today. He doesn't think he'll have any problems milling up new collars. The only issue right now is identifing the correct thread. He thinks he'll have the first one done for me to test around the end of next week. Once we confirm that it works correctly, he'll tap the rest and mail them.
We had an unusually warm and sunny day today. I couldn't resist trying out the mower even though I don't have any controls yet. I operated the valves manually and set the mower to a specific point and started the flail head, then got on the tractor and began mowing. Three passes with the mower set defferently on each pass. Not bad for no controls and old RUSTED knives. Here are a couple pix of the result. The brush was nearly to the wheel track when I started.
/ Need some help with cable controls #60
That's good that you tested it so you can find out if the mower has other issues besides control cables. From your pictures, I'd say once you get the control cables worked out you'll be good to go.
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A61568)
2012 Ford F-350...
Case Steiger 600S Tractor (A64047)
Case Steiger 600S...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
BLUE TRIM LONG 8 BOX WOOD FRAME BARN (A63290)
BLUE TRIM LONG 8...
2017 BX2680 Sub Compact Utility Tractor (A63118)
2017 BX2680 Sub...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
