roquefortnight
- Joined
- Feb 28, 2010
- Messages
- 18
I've had a 60" blower on the back of my 4300 for several years. We get several months of heavy snows here most winters, and have a lot of paths to clear: long driveway, barn over here, chicken house over there, woodshed over there, manure pile waaay over there (because it's the best spot for it, not cause it's something awful). We've also got fields full of stumps and I cut trees most winters, either for firewood or sometimes to sell sawlogs, so I need to clear paths in the snow through fields and woods, both to let the ground freeze up good in early winter and because obviously the tires need something to bit on. I often have to stop and let the blower clear itself or go forward and back up again repeatedly or the heavy snow will stall the tractor engine, which is a 3-cylinder diesel of around 90 c.i.; I think this is a bit larger than your machine. Sometimes I bang into stumps I can't see. This is probably not what you're intending for your tractor but I'm just offering it for others that might have found this thread.
I dislike craning my neck around quite a bit. It does indeed hurt after a while and whether that's due to my physiology or lack of toughness I don't know. I also dislike taking the blower off to put the logging winch on and vice versa, because they have different widths for the 3ph and are parked on bit of a slope and frequently covered in snow and ice.
I doubt many front-mounted machines could put up with the heavy use I put my snowblower through. It's a Couture, by the way, and is fairly primitive with no fancy features but rather heavily constructed. I don't like its cable-actuated rotation mechanism; I suspect the Schulte-style worm gear type is worth the extra money they charge. I've never dented it and I've gone through many, many shear pins (low-grade bolts with locknuts actually) but never damaged any gears or anything, to my knowledge.
For me, the loader and bucket is needed just about whenever I'm using my machine, whether I'm logging or snowthrowing or whatever. I can't imagine having to regularly remove it to put on a snowblower, but maybe doing so is easier than I think.
Orlo seems to have nailed the basic benefit analysis in his post. If you need rugged, and use your loader a lot, or if you think you might sell the snowthrower, get the rear mount. If your needs are not so heavy duty, comfort is more important to you and the extra monetary bite is acceptable, the front mount might be the better choice. It's probably tons more fun to move snow with, too. But I'm glad I got the rearmount.
