Is this normal?
/ Is this normal? #1
kidkioti
Just got the new CK 27 HST delivered this afternoon. Hope to be able to post some photos for you all. This is my First adventure concerning the HST. It has a 3 speed HST and the first thing I did was to put it into H to see what it could do. On the level it started to move :thumbsup: then I tried going up an small incline it started up a bit but then the Tractor came to a complete stop :(. with engine running satisfactorily.
So now I depressed the clutch and selected M that got me up the grade and when I got it upon the flat I selected H. On the level now it seems to be able to move the tractor. If I tried to back up or drive up incline in H from start it doesn't have it. confused:
Is this normal and what I can expect, or is it just me expecting too much. :eek:. Would appreciate your candid input into this if you will? Thank you very much!
/ Is this normal? #2
Are you running the tractor at a high enough RPM? Seems like 1800 to 2000 works best on most of them to keep enough pressure with the HST pumps. Can you hear any noises when it stops moving?
/ Is this normal? #3
Depending on the hill and the RPM's you had the engine at, it may be normal. High gear is really just for flat travel and not for much work or hill climbing. Also, since the tractor is still new it will be slightly underpowered until it really breaks in. This is normal for any new engine and not just the Kioti diesel. I noticed High gear to be much more useful after 50-100 hours of use and can even use it to snow blow the light stuff.
Does the tractor just have a loader on it or do you have a backhoe too? Are the tires loaded? All this extra weight will make the High gear tougher as well.
/ Is this normal? #4
Was it cold? Did you let it warm up?
/ Is this normal? #5
I don't have a Kioti but.... I live on a big hill and I never take the tractor out of low range. In the manual it says high range is a transport only gear. And they mean transport on level ground only gear.
/ Is this normal? #6
I normally let my CK35 HST warm up for a few minutes. Usually run it in medium range at no less than 2000 RPM but most of the time around 2200 RPM. Find if I am driving it in high, on our flat gravel road, it bounces too much for my liking so have done that only a couple of times.
/ Is this normal? #7
Sounds normal, both of the Kubotas I have act the same.
/ Is this normal? #8
My CK30hst doesn't like high range unless the engine is over 2,000rpm. It will go up mild inclines in high range without a bh and no other load. The main thing is don't press the pedal down to fast. It's kind of like starting a standard trans vehicle in high gear. Take several seconds to push the full pedal travel as the tractor picks up speed.
/ Is this normal?
I hoping to attach a few photos of the tractor & area that I will use it in. After reading the posts I had it out a bit more today to see if I could learn anything. The information that was provided gave me a better understanding now of what I can expect. :thumbsup:
Really appreciated the feedback & input you Guys were willing to take the time to post. By your stories you gave me a better idea of what I should know. It also helps me to get to know a little more about each one of you & your equipment. Your suggestions were just what the doctor would order. Hope that it will work both ways.
photo 1 - These deer have seen kiotis before.
photo 2 - Pit Yorkie guarding the New front end plow/blade
photo 3 - New loaded down CK 27 HST Tractor on incline - H range did not work here - No noises about 1800 to 2000 rpms
photo 4 - Not able to get up to the wood today :)
Thank you! KKioti
/ Is this normal? #10
Congrats.
In time you'll learn tricks of the trade...listen to machine as it talks to you. :)
/ Is this normal? #11
That hill doesn't look that bad, I bet even with the backhoe mounted I could make it up that with my little CK20 in High. If you are going to be using High gear then you should be running at around 2400+ rpms. I typically run at about 2600rpms which is where the PTO is at 540rpms. You know they designed these diesel engines to run optimally at that rpm figuring that is where most would be.
So, crank up those rpms a little and slowly engage the HST pedal increasing pressure as you speed up. Also, run in 2wd until you need the 4wd. You will find that makes High gear easier too. 2wd with the locking differential works great for 90% of my work. 4wd is pretty much for snow blowing and pushing snow here.
/ Is this normal? #12
Congrats on your new tractor. You are going to love it. As many others have said, I only use H for travel on flat ground. Even that minor hill in your photo would be L or M for me.
/ Is this normal? #13
In picture 3, you should be able to go up in high but as mentioned, try 2,500 rpm and slowly depressing the pedal. Picture 4, definately no high range for that grade or you have a turbo CK27. :)
/ Is this normal? #14
Not trying to be smart, but did you say you pressing in the CLUTCH in the original post? I'm not familiar with HST's having clutches. Otherwise, I'm with the rest on here in that I use H for road gear only.
And much congrats on the new tractor. Don't be surprised if the hours add up much quicker than you intended. :)
/ Is this normal? #15
You may be completely aware of the concepts below, but to cover the bases, I decided to throw this in the mix. None of the replies specifically cover that the HST pedal is not an accelerator, rather is linked to a hydraulic pump which feeds a hydraulic motor. You effectively have 3 "ranges" with an infinite "gear range" within each range if you use the HST pedal correctly. The harder you push the pedal the more VOLUME of hydraulic fluid you push, which equates to a higher "gear." As you hit an incline, at the point that you start losing engine rpm, release the HST pedal to increase the PRESSURE and decrease volume. The rpm will come up, the tractor speed will probably drop, but you should keep moving. This is no different than had you changed to a lower gear with a gear transmission. Many people expect to maintain tractor speed on an incline in high range, but they most often expect too much. Resist the urge to "give it more gas" with the HST pedal. That is counterproductive for reasons explained above.
I have a lower horsepower Kubota than your tractor, with a backhoe no less, and I can climb a fairly steep hill in high range with a bucket of dirt as long as I heel back as necessary to keep the rpm up. I keep the engine loaded to keep the governor open, but don't let it pull down. The tractor slows down but I do not have to change ranges, which overall saves time. I do this at about 2200 rpm, so I am not running full rpm and I get a lot of work done by fine tuning HST volume versus pressure.
I hope this helps. HST use is the same, regardless of brand, so this is applicable to almost anything except the Kubota HST-Plus type setups. They were designed to make it easier for those who have difficulty making the transition from automobile automatic transmissions to an hst, which ISN'T an automatic transmission, and requires a different operating technique. I have an almost 40 year old Wheel Horse HST that I successfully operate the same way as I do my B7510.
You will eventually find what works for you.
/ Is this normal? #16
I believe all tractors have clutches but may be wrong. I know the Kioti's all do, even the HST models. The clutch is used to start the tractor, switch ranges, and engage the mid and rear PTO's. The clutch pedal is on the left side (sitting on the tractor) and the HST and Brake pedals are on the right.
Note that I said the clutch is used to ENGAGE the PTO's and not DIS-ENGAGE. Unless you need the over-run clutch to slow down an implement like a rear mower or post hole digger, you are better off just sliding the lever to OFF instead of pushing in the clutch. If you do depress the clutch while the PTO is engaged then you will hear a loud clanking noise that sounds like something is broken but that is normal.
/ Is this normal? #17
Interesting. My DK45SE has the brakes on the left and the HST pedals on the right. No clutch.
/ Is this normal? #20
All are not the same. I also had a 2-speed B7610 that'd go anywhere in H (with full bucket). With my DK35se it won't do jack in High. It is strictly for transport. The issue is that Med is geared too low. Could have been geared a little higher to be more useful. I live on a hilly 13 acre property and am constantly shifting from M to H. It's either that or keep in Med and take a nap in between work locations.
Good tractor besides, and works great on level ground, hills are a PITA.
2018 Infiniti QX60 SUV (A64557)
2018 Infiniti QX60...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
2000 INTERNATIONAL 9200 DAY CAB (INOPERABLE) (A65643)
2000 INTERNATIONAL...
(2) New 27X8.5-15 turf tires in John Deere 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 27X8.5-15...
2020 Pitts Chip Trailer P16316 (A62613)
2020 Pitts Chip...
Bush Hog 285 3-Pt Rotary Cutting Mower (A66285)
Bush Hog 285 3-Pt...
