Buying Advice Wheel Weights or Calcium
/ Wheel Weights or Calcium #1
Bacffin
Littleton, Ma.
I have the option to have either wheel weights or calcium for the rear tires on the BX2660 or BX25 during purchase. I will be getting turf tires. Does anyone prefer one over the other? I have a buddy who made up a block of concrete to attach to the 3PH for his MF GC2310 and say's it works fine with no wheel weights.
Are the tires nowadays tubeless or tube? Does it matter?
Thanks Again,
Bruce
/ Wheel Weights or Calcium #2
If you decide to float the tires I recommend asking the dealer to use methanol instead of calcium chloride; any extra cost up front will be offset by not having to replace rims corroded by the CC down the road.
/ Wheel Weights or Calcium #4
I went with weights in lieu of liquid ballast on my BX2660. If you get a flat with fluid you will lose it all or have to pump it out in many cases to repair. Weights just seemed like less trouble to me. I do have liquid in my bigger tractors.
The tires are tubeless. The added weight will help a lot, but with FEL work, I still use counter weight if I am going to do very much.
/ Wheel Weights or Calcium #5
I have rimguard in mine. I prefer that over wheel weights. I had a problem with the valve stem last summer, but didnt need to pump it out. I just popped the bead on one side and replaced stem and then aired up.
/ Wheel Weights or Calcium #6
My Kubota Tractor Owner's Manual specifically approves Calcium Chloride, not methanol, not beet juice, not windshield washer solvent.... Calcium Chloride is effective, economical and safe for use or it would not have been used longer than most of us have been alive, nor would the farmers and contractors that depend on their equipment continue to use it. If the Calcium Chloride presented any real problems, I don't think dealers would continue to use it and risk alienating their customers.
It's used extensively on roads as a de-icer so it's apparently non-toxic. There appears to be no damage to the proliferation of weeds or grass along these roads so the long term effects on vegitation seem to be minimal.
I have a pair of tubeless tires that have been loaded with Calcium for over 35 years with no problem. A normal puncture in a tubeless tire can be repaired in short order with a plug and minimal loss of fluid. Tubes, as recommended by many to combat the "corrosion problem", create serious tire repair inconvenience.
No matter which liquid is used, make sure there is no leakage from valve stems or around the bead. The constant moisture can cause corrosion as unlike inside the tire, air is present in sufficient quantities.
I have no dog in this fight other than an aversion to continuation of what I see as a MYTH. I apologize in advance to anyone who might be offended or might disagree. It is not my intent to disparage, or convert anyone to my way of thinking, only to assist the original poster.
/ Wheel Weights or Calcium #7
I'd go with windshield washer fluid (close to weight of water and cheap if that is a concern) if you want to do it yourself. I'd prefer the extra weight of the rimguard.
The dealer and tire man will want the calcium, as they will likely get the job (and money :) ) for pumping it in and out when, and if, that is ever needed. The manual will support the dealer too.
I recall the reason I finally sold my old tractor was because the rims were rusted as a result of calcium in the tires. Couldn't find replacement rims so gave up on the old antique.
No myth-stake about it. :D
/ Wheel Weights or Calcium #8
I use weights. 60# per side, I think. Came with the tractor. Never had any issues. Thankfully, I've never had a flat, but if I did, I wouldn't want to be messing with the fluid.
/ Wheel Weights or Calcium #9
Went with weights. I wanted nothing to do with corrosion issues and wanted the ability to not have weight when crossing the lawns during spring and fall cleanup.
I'm sorry to be disagreeable, but a leak of calcium chloride (sodium is worse) will leave a very dead spot in a lawn. The grass medians in metropolitan S.E. Michigan are plagued with "salt killed" brown, dead grass from the brine over spray of cars. FWIW.
/ Wheel Weights or Calcium #10
Wow now here is someone with no experience with CC. It is VERY corrosive. The only reason Kubota recommends it is because it is common, not better.
Stay away from CC at all costs if possible.
/ Wheel Weights or Calcium #11
I'll have to point that out to the Kubota dealer who recommended filling my Kubota's rear tires with methanol. ;)
/ Wheel Weights or Calcium #12
Better known, perhaps, as RV winterizing fluid. Good choice, frankly. Cheap, available and reasonably non-toxic and non-corrosive. Slightly lower slush point than WWF is a bonus if living in the far far north.
/ Wheel Weights or Calcium #13
Acid + Base = Salt. The Sodium Chloride we use as table salt is not the only kind of salt; there are many chemical compounds that are a salt, and Calcium Chloride is one of them. Like all salts, Calcium Chloride acts as catalyst in the oxidation of ferrous metals. In other words, just like regular salt, this salt makes iron based metals rust a whole lot faster. Those who drive on salted roads know what salt will do to the underside of your car if you don't have a protective lining sprayed on. Even then, you're likely to get rust.
While Sodium Chloride nor Calcium Chloride might be labeled as a toxin, high concentrations are lethal to living things. We gargle with warm salt water so the osmotic pressure ruptures the cell walls of bacteria. If you consume too much salt, you will die. If you spill the stuff on the ground, nothing will grow there until rainfall or irrigation eventually dissolves the stuff into a low enough concentration for things to grow again.
I personally like to mow with as little weight as possible. I run the Ag tires all the time. I bought a bunch of old disc shaped free weights for use as ballast. I have a customized bar holder on top of my PHD for down pressure when augering. I slip weights on each side of the bar and put the locking collars on. My sub-soiler has a short bar welded vertically on which I stack weight discs and put a collar on top. I am currently designing a flat bar which will bolt to the bottom of the ROPS (side to side) with two round bars welded on that point upwards about 18" or so. I will stack 25# discs on those and then have another cap bar that will lock off the tops of the bars and also bolt to the ROPS. It will look a little like a big version of one of those Chinese abacus calculating devices turned on its side and mounted to the ROPS just behind the seat. I know this will elevate the CG, but I will only use this with the sub-soiler on flat ground. (Both the tractor AND the sub-soiler itself need ballast.) In other circumstances, when the 3ph isn't needed for something else, I just use the box blade or backhoe for ballast, depending on how much weight is needed and how much maneuvering I need to do.
A dedicated ballast box is another alternative. There was a recent thread with lots of good pics of ballast boxes. I liked the one where someone had filled his with concrete, but had a bunch of PVC pipe sleeves throughout it (pointed upwards) into which he could insert the handles of shovels, rakes, etc.
/ Wheel Weights or Calcium #14
Rim Guard. The beet juice puts a lot less strain on the axle and adds more mass than wheel weights. And it isn't a poison or toxin.
Thanks everyone for the suggestions and ideas. I think I will go the route of wheel weights so I don't damage the lawn during the muddy seasons.
~Bruce
/ Wheel Weights or Calcium #16
Actually, I have very extensive experience with calcium chloride, loaded tires, tractors, and construction equipment in general over more years than I care to talk about.
Spend your money as you see fit.
It seems odd that most will swear by Kubota's recommendations for oil and such, yet consider the same engineers idiots when they recommend calcium chloride as a tire filler.
Any guess as to why calcium chloride is common? It works and it's cost effective. It would have been gone years ago if it caused problems. Methanol is certainly not a new discovery.
This is important in this discussion.
"Rust is a general term for a series of iron oxides, usually red oxides, formed by the reaction of iron and oxygen in the presence of water or air moisture." (Wikipedia)
Most common chemical form is Fe2O3.
Iron corrosion or rusting, will happen in the presence of beet juice, orange juice, methanol-water mix, calcium chloride or Budweiser as long as free oxygen is available. (Note that the above formula illustrates that rusting requires 3 molecules of oxygen for each 2 molecules of iron.) In a closed atmosphere such as a tire, the oxidation reaction is limited by the number of oxygen molecules available. Significant rusting requires large amounts of oxygen by volume. There's relatively little oxygen in a filled tire. Once the oxygen is reacted, the corrosion stops. The same quantity of oxygen is available in the tire no matter which of the above mentioned water based solutions is used. Therefore, the extent of rusting will be the same over the years. In any case, there's just not enough oxygen to react with enough steel to cause a problem.
/ Wheel Weights or Calcium #17
To summarize, then....
You and others like Calcium Chloride. I and others like Methanol. And yet others like Rim Guard. We all have our own reasons for our choices, each of which is as valid as any other.
With that in mind, here's a comparison of the most popular ballast choices. As you'll see, they each have pros and cons, so each of us will choose based on what's important to us.
/ Wheel Weights or Calcium #18
If you don't believe CC is corrosive then do some actual research. It is not rocket science.
/ Wheel Weights or Calcium #20
When Oxygen is present, rusting or oxidation occurs. Oxygen is required for oxidation or rusting. All true. Let's get real.
My problem with the idea that "when the oxygen is used up, the oxidation ceases" therefor the logic is, there will be limited damage done. This ignores the fact that oxygen is re-introduced constantly at the valve stem area as it is an imperfect seal. This is why the port hole for the valve stems typically suffer such rusting problems.
Further, this theory of oxygen depletion supposes that no further oxygen will be introduced, over a life time of use, into the tire chamber itself. Actually, tires constantly require inflating, thus there is a constant re-introduction of oxygen each and every time the operator puts his air hose onto that tire. Over a reasonable 30 year period of ownership, hundreds of pounds of compressed air will be re-introduced into the equation. Each and every time the hose from the air compressor is used, further oxygen is provided for additional and ongoing rusting, pitting and corrosive activity to continue.
In the real world, filling tires mounted on a steel rims with anything that has corrosive properties eventually leads to rusting. It's even Biblical!!!
:D:D
"Where rust and thieves do break in."
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F-350 XL...
JOHN DEERE 2040 TRACTOR (A63291)
JOHN DEERE 2040...
2011 Nissan Sentra Sedan (A61574)
2011 Nissan Sentra...
14ft Flatbed Truck Body (A59228)
14ft Flatbed Truck...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
