3-point - how high?
/ 3-point - how high? #1
dobiedisco
Member
Texas
Massey Ferguson 135
How high should the 3pt lift implements? I'm a newbie tractor owner (old MF135) and apologize for the newbie question! I've been using a box blade to level my driveway and it lifts it maybe 2' from the ground to the bottom of the box blade. Thank you!
:confused:
/ 3-point - how high? #2
Lifting 2 ft isn't enough?
Make it even higher if you shorten the top arm.
/ 3-point - how high? #3
That sounds about right. With longer attachments like a bush hog mower or tandem disk; you will have to shorten your top link to raise the rear of those longer implements.
/ 3-point - how high? #5
Unless you are hanging it up on something, I don't see why it makes much differece. I have to shorten the top link on mine when I load the tractor on the trailer or I catch the bottom of the box blade on the ground as the tractor goes up the trailer. But once it is on the ground, the top link has a big effect on the performance of the box blade when it is being used. Shortening the top link will cause the box blade to dig in deeper when it is being dragged accross the area. Too much, and it will stop my tractor. Lengthening it will raise the front of the box and eventually cause it to ride on back of the blade which is curled out allowing more of a smoothing effect with no digging in. Put it down on concrete and adjust the top link and you will see.
It is doing what I need it to so far, but I wanted to see if that sounds right. If it sounded lower than normal, then it would need to be checked out. It actually may be more like 18" to 2'...somewhere in that range. I will be hooking up the boom pole soon to move tree sections to the burn pile and just bought an auger and dirt scoop yesterday. So, just checking to see if it is within a normal range before putting it to work on heavier tasks. Thanks for the feedback...like I said, "newbie!"
My logic is, a car may drive on a flat tire, but that doesn't mean it's good for the tire or the rim.
:laughing:
Forgot to mention that it does shudder a bit when it reaches its highest point.
/ 3-point - how high? #8
20"or so to the bottom of the implement means the lower links are 8-10 inches higher (or thereabouts). That's plenty and I doubt you'd see much more on any CUT.
Obviously, don't compare a CUT to a full sized utility tractor...but even those bigger machines don't have much more travel, but their rear tires are larger in diameter so that rear axle is further from the ground.
As far as the shudder, I suspect the lift cylinder is at or getting close to the end of it's travel. Could also be a little air in your hydraulic system.
/ 3-point - how high? #9
There may also be a need for some linkage adjustment at the top end. Likely is something that feeds the hyd. system info when the top is reached so it closes off a valve.
/ 3-point - how high? #10
You're getting plenty of lift. Think my BB only goes up about 18". The 4010 lift is FAST though. You can pretty much hit the lift at the end of a row, do a brake turn to the next row, slam it down and go onto the next row. The "slam down" depends on where you have the "down" valve adjusted. That's often not as fast.
Only time it doesn't lift so fast and high is regular lift with the bush hog on it. Only way to get the trail wheel very high off the ground is to crank the top link down tight.
Ralph
/ 3-point - how high? #11
I could not get my 2320 to lift the rough cutter high enough (the rear wheel would pretty much drag all the time) and I didnt want to have to adjust the top link once I got it set correctly.. I ended up lowering the pins on the mower..
then I borrowed a neighbors disc and ended up having to adjust the lift arms on the tractor to get a few more inches of clearance..
Brian
/ 3-point - how high? #12
Brian
Which is why the top link is easliy adjustable.
I frequently "tow" my cutter (disconnect the upper link) rather then lift. It's less strain on the tractor, but this is done only on the lawn to the field (100-150 yards). Unless you transport on the road or move the cutter more then ¼ mle), you might want to consider towing.
I'll tinker with those settings as soon as the ground dries up. The guy I bought it from said there shouldn't be any adjustments needed, but I am not sure which implement he'd been using before it was parked and now I recall his adjusting the top arm when he delivered the tractor and hooked up the boom pole to lift the box blade off of the trailer. Thanks for the suggestions.
Mary
PRIME 8312 BOX (A63291)
PRIME 8312 BOX...
2014 Nissan Quest Van (A61574)
2014 Nissan Quest...
LOOK! (A63109)
LOOK! (A63109)
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
LOT OF MISC BAR JOIST (A63291)
LOT OF MISC BAR...
2025 44in Hydraulic Grapple Mini Skid Steer Attachment (A61572)
2025 44in...
