Hydro fluid flow question
/ Hydro fluid flow question #1
Kubota 2350
Michigan, In The Thumb
2016 JD 3046R Cab ...................... Mower: 2016 Scag Tiger Cat II ZTM
Can anyone tell me if the hydro fluid flows through the system with just the engine running, or does the tractor need to be moving to get flow through the system?
Tractor is 4310 JD E Hydro
/ Hydro fluid flow question #2
The fluid is pumped through the "system" whenever the engine is running.
Thanks, I was hoping it worked that way.
Letting the tractor warm when it's cold also warms the hydro oil.
/ Hydro fluid flow question #4
Although the engine will come up to temp much faster. It only has to heat up 3 to 4 quarts of oil, in a CUT, while that hydro contains a couple of gallons of very cold fluid. It takes it much longer to come up to temp. The sluggish hydraulics and rather loud hydro whine alone will let you know it's still cold. :D:D
Does it hurt to drive the tractor with cold Hydro oil?
/ Hydro fluid flow question #6
Define cold? Just baby it a little till it gets flowing...like BP wrote-it will let you know if it's not happy.
/ Hydro fluid flow question #7
Yup, the temp gauge may read "Ready to Go", but that hydro will still be cold. Once the temp gauge is up, gently back the tractor out and gently move around a bit. It takes a while in 10 degree weather, but within ten minutes or so, the hydro quiets down to more normal sound. Your ears become attuned to it after a dozen cold starts or so and you "hear" what it's saying to you.
They do sell "hydro heating pads", no kidding!!! I doubt I will be getting one anytime soon.:D
/ Hydro fluid flow question #8
They do sell "hydro heating blankets", no kidding!!! I doubt I will be getting one anytime soon.:D
Transmission heaters are also available from JD, as well as engine block heaters.
/ Hydro fluid flow question #9
I don't let my 4010 warm up here in Virginia. I just start it up and use it at 1500 rpm for a few minutes before revving to 2000-2200.
If you're living where your starts are below zero F, you probably need to warm it up a bit.
The dealer always makes sure that we buy the low vis hydro fluid. Guess south of about SC, the high vis stuff might be okay.
Ralph
/ Hydro fluid flow question #10
If it's cold, I let mine idle for a bit. I once exploded a filter on my TZ25 at 0f, so pressure obviously do run a bit higher with cold oil.
NH also lists a tranny heater. If I was that worried about it, I'd just leave a 100w light running under the rear end over night.
2023 CATERPILLAR 259D3 SKID STEER (A64279)
2023 CATERPILLAR...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63689)
2021 Takeuchi...
2020 Bobcat MT100 (A64126)
2020 Bobcat MT100...
2016 KENWORTH T680 6X4 T/A DAY CAB TRUCK TRACTOR (A59914)
2016 KENWORTH T680...
2021 Bobcat T76 (A64126)
2021 Bobcat T76...
240 Massey Ferguson Tractor (A61165)
240 Massey...
