MiG welder: how thick can it weld?
/ MiG welder: how thick can it weld? #11
The smaller 220 volt machines are good for hobby work. you can make a good 110 work but you'll be wishing you spent the couple extra bucks so just do it. Now how thick they weld can depend on what shielding gas you use. Theres all kinds of shielding gas. For the hobby guy you cant go wrong with co2. Its cheap and lasts a long time. It also burns in better than the other common gases. The drawback is that co2 will cause more splatter. I have a variety of gases, co2, trimix and argon. I use the argon for aluminum and co2 for most of the steel work. I'll use trimix on occasion when welding sheet metal. I use flux core on all cast steels and for the heaviest jobs, like welding spider gears or suspension brackets onto thick axle tubes. Flux core will burn in the deepest and once you get the feel for it it works pretty good.
/ MiG welder: how thick can it weld? #12
If you're willing to spend the coin there are several MIG welders on the market that will weld 1/2 steel and are still 220V single phase. I have a Thermal Arc 250amp machine that is rated for 1/16 wire and 5/8 steel. It will spray transfer .035 wire with 75/25 mixed gas. It's a great machine, but it was not cheap. It mostly depends on how much you will use it and how much time you want to spend welding. A good MIG machine will save you a lot of time over a stick welder if you are working on new material. The weld speed is much faster and very litte clean up with gas shielded solid wire. Another great advantage of the MIG welder is when you're tacking up an assembly. Super easy to hold something in place with one hand and tack weld it with the other.
/ MiG welder: how thick can it weld? #13
I see what you mean kennyD about welding threads.
I am not a welder, but have a hobbyist hobart wire feed model to do what I need to do. After welding for over a year, I relized with the thicker stuff, there is no penetrentation with thick stuff. The only way to "cheat" is to grind the metal edges to have a DEEEEP bevel and then weld in the thinner edge and then put side welds and build up untill its all filled in. This works for me for what I got, but its soooo time comsuming. I probably will need to get a tombstone stick if I gonna continue to do thick stuff for the tractor.:ashamed:
/ MiG welder: how thick can it weld? #14
to clarify flux core with non-welding hobbyists, there are two different types; Self Shielded FCAW (uses no external shielding gas and runs on DCEN polarity. usually used with the less expensive 110 V machines that does not have a gas solenoid) and Gas Shielded FCAW (runs on DCEP polarity and usually uses CO2 or 75/25 shielding gas). when you say that flux core wire does not have the penetration and is limited to thinner metal welding is true with Self Shielded FCAW of the AWS classification E71T-GS, which has a 70K tensile strength, can be used in all positions, but is limited to General Single pass welding of mild steel. it's hard to beat Gas Shielded FCAW for penetration in all thickness & speed of welding in all positions.
you're right, MIG is a Jet fighter, solid wire welding is called GMAW "gas metal arc welding" the old term MIG stands for "metal inert gas".
I agree that one should get the larger welder. if you think you can get by with a 180 amp welder, get a 250 amp. I have six different welders in my shop; one set up for TIG, one for SMAW, one for GMAW, one for Self Shielded FCAW, one for Gas Shielded FCAW and a mobile unit that can do all of the processes listed above.
/ MiG welder: how thick can it weld? #15
My next project is to build a trailer to trailer my ISEKI G-174.....My new Lincoln 125 amp 20% duty cycle 110 /120 volt is my new toy and has no gas option....or should I say if I buy the gas valves etc....I think this unit is A/C input and DC output....my only question would be...."What" speed...(like dial setting) ....or would trial and error....or just plain practice be the answer I'm lookin' for....I'm usin' 0.35 wire that came supplied with the unit...I owned a gas/flux mig welder unit about 2 years ago that was made in Italy....I didn't care for it at all....so I returned it and bought a O/A Harris copy(China Made) this set sort off blew up(caught fire) my fault for not checkin' the tip as it mentioned to just finger tighten the tips....Hmmmm....so much for that idea.....so I went with the Victor copy so far so good.....first thing I check now is the tip for tightness before turning on the tank valves....anyhow I'm all ears on this mig welding subject....my first welding job a couple days ago....I welded the wire to the brass tip....that sucker is welded better than the metal I was weldin'.... yes and alot of splatter...that is also tough to remove....so I'm confident this little portable will weld what I need to weld....just need practice....and a little knowledge....yes I bought the auto darkening helmet....Thanks guys.....Ampa :thumbsup:
/ MiG welder: how thick can it weld? #16
I have a miller 135 110v mig that I like a lot but at only 10% duty cycle, unless I'm only tacking up some work, it gets to be problematic. Duty cycle, btw, is how many minutes per hr you can safely weld. So 10% is 6 min per hr. I'd spend the dough and get a good 220 machine. Also, get a good autodimming helmet. It will make life much easier for you. I'm going to either the 211 or 252 Miller to get a superior machine. Spend some time at millerwelds.com Their instructional videos are excellent. I wouldn't worry about welding 1/2" in one pass necessarily. In a previous life I made a living as a welder. It is not uncommon to just layer one course on top of another to fill a weld and be able to control the heat, penetration, and general quality/appearance.
I have a Syncrowave 180 for Stick and tig which I intend to turn into a mig welder via sale/purchase. The 180 is a nice machine but my eyes and lack of practice have made tig about unbearable for me now. There was a time I could make any welding test anywhere and I was a hand with tig...but you don't just walk up to it and do quality work:(...so mig is where it is at for me today. Practice, practice, practice!
/ MiG welder: how thick can it weld? #17
I use the flux core, self shielding stuff for thicker metals and cast steels. It will penetrate better than a gas shielded wire with my machine. I use a 220lincoln sp175 plus. Its been good to me, does everything I ask of it as a hobby builder. I even had it fall out of my vehicle going down the highway once. A friend didnt close the trailgate tight, it got banged up but still works like new. Its been a very good purchase.
Thanks for the replies. I do not see a major use for the welder so I'm leaning toward a stick AC/DC 220. Gas and other stuff might complicate my life.
/ MiG welder: how thick can it weld? #19
Ampa... your "tip to work" distance (stick out) should be around 3/8".
if you melted the wire to the tip, then you must have touched the tip to the metal you are trying to weld.
remember that the Cu tip is going to be hot (live) when you pull the trigger. try this; have the wire sticking out of the tip around 3/8 to 1/2", touch the wire to the metal, then pull the trigger.
I wouldn't be welding a trailer until you are a little more experienced.
also, if the wire you are using says AWS class E71T-GS on it, it's mostly intended for static loading and sheet metal work I.E. hand rails, fenders, hobby crafts and such.
it is not intended for dynamic loading, as it has no requirements for impacts... especially at low temps.
thus, you can use it on some parts of a trailer, but not all.
you may want to save up for a AC/DC stick machine so you can cover most situations. you'll need 220 V supply though.
good luck.
/ MiG welder: how thick can it weld? #20
There is also E71T-11, multi pass that you can use to fill a deep V notch.
BTW, self shield flux core runs hotter than the same size solid wire. The flux core wire is formed into a tube and will there fore run hotter. Most hobby mig units will max out at 20-20 volts which are good enough for solid and self shielded wire and short circuit transfer. For gas shielded flux core wire, you need 23-37 volts, spray arc transfer and that is outside what a hobby welder can do.
This is what proper fusion looks like.
2009 Ford F-150 Ext. Cab Pickup Truck (A60352)
2009 Ford F-150...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere S350 (A60462)
John Deere S350...
John Deere 1025R (A53317)
John Deere 1025R...
2008 TOYOTA Camry Solara Convertible (A61569)
2008 TOYOTA Camry...
