Hydraulic Flow Reducer - do they exist?
/ Hydraulic Flow Reducer - do they exist? #1
OtterBrookStables
Maine
John Deere 4120
I have a 72" Frontier Snowblower on the back of my 4120. The chute rotation is hydraulic. Problem is, when you move the lever to adjust, the chute moves VERY quickly - it basically slams to the other direction. You have to carefully feather the hydraulic lever to get any slow adjustment of the chute rotation. Do they make a hydraulic flow reducer (or something else?) that would slow down the chute movement? It would be ideal if there was an in-line quick-connect unit that would go between one of the chute hydrailic lines and the quick connect on the back of the tractor. Ideas?
/ Hydraulic Flow Reducer - do they exist? #2
a couple of years ago the chute rotator on the front of my 2210 stopped working so I took the fitting off at the hyd cylinder and there was what looked to be a simple flat washer with about a 1/8th hole drilled in it I believe for that same reason. There was a little shmegma blocking the hole so I cleaned it and all was good again.
/ Hydraulic Flow Reducer - do they exist? #3
You should be able to put a reducer or valve in there.
On my former 3720, on the front A-Frame lift it had a nice valve that allowed you to
adjust the lift/drop speed by opening or closing the valve. I thought it was funny that they never put such an adjustment on the chute. The Chute on my 4720 (Rear blower) my former 3720, and my 2305 all go way too fast for my taste.
/ Hydraulic Flow Reducer - do they exist? #7
Blueone.... what you put a link to will NOT work.. Well, lemme rephrase..it will work, but only in one direction...what is needed is a Needle Valve:
https://www.surpluscenter.com/item.asp?UID=2156122521021911&item=9-5302-25&catname=
A Needle valve meters flow in BOTH directions...
Correct. The proper search term (in the hydraulics forum) is "restrictor". The needle valves are best because of the adjustability-but they cost more. A small washer in a fitting drilled with a small hole works also.
/ Hydraulic Flow Reducer - do they exist? #8
Both of you guys are sort of correct.
The proper way is to use flow controls on each port of the cylinder and and control the flow out of the cylinder "free flow in - meter out".
If you use a needle valve the cylinder will operate at different speeds when retracting or extending.
/ Hydraulic Flow Reducer - do they exist? #9
Why do you think that?:confused2:
/ Hydraulic Flow Reducer - do they exist? #10
Heh heh heh ......... he said shmegma ! :licking::laughing:
/ Hydraulic Flow Reducer - do they exist? #11
Look at how a cylinder is built; the displacement is different on each side of the piston due to the cylinder rod , the same amount of oil into a different amount of space will result in a change in speed ( and force as well) If you just use one needle valve the flow is equal to each side of the piston, it will retract faster then extend.
/ Hydraulic Flow Reducer - do they exist? #12
Your reasoning is good, but does not apply to this application. It is true that the different displacement affects force, but not speed. The fluid will only move so fast through the restrictor, no matter which way it is moving-or how much of it there is.
/ Hydraulic Flow Reducer - do they exist? #13
Just FYI if interested. JD has used restrictors and they show as still available. No idea what size would be required, and those adjustable ones may be what you want instead but these would be a quick install.
/ Hydraulic Flow Reducer - do they exist? #14
Kenny, this isn't a "Global Warming debate" :D actual science is at work here.
Flow in hydraulics is measured by displacement, usually Gallons per minute or Meters cubed per minute etc. the flow into each end of the cylinder is the same yet the displacement per inch of travel is different therefore the speed must be different. The larger the cylinder rod the greater the difference.
The reason for metering "out" of the cylinder is that by restricting the flow out of the cylinder you get smoother motion because the cylinder can not "free fall". Air or vacuum is compressible but oil is not.
HowStuffWorks "Log Splitters"
http://www.womack-machine.com/pdf/rb365/10p355.pdf
/ Hydraulic Flow Reducer - do they exist? #15
OK, while I will concede that you are 100% technically correct-we are talking about a small cylinder on a snowblower chute. Real-life fact is the speed difference is VERY small, and in this non-precision application using just one adjustable restrictor is sufficient to do what the OP requested. Buying 2 of them would be a waste of money.My :2cents:
/ Hydraulic Flow Reducer - do they exist? #16
2 flow controls: $10.95 x 2 = $21.90
1 needle valve: $25.95
What is the waste?
/ Hydraulic Flow Reducer - do they exist? #17
/ Hydraulic Flow Reducer - do they exist? #18
Actually....
Looking at the specs of posted valves before posting...Priceless
:D
All kidding aside, the flow control valve posted was a 1/8" NPT 2000 psi unit, a "like for like" comparison would be this parker 1/4" NPT unit:
https://www.surpluscenter.com/item.asp?UID=2156122521021911&item=9-5300-25&catname=hydraulic
How do you know the 1/8" won't work, no where did anyone list the port size needed whose not reading the specs correct?
Will a needle valve work? sure it will, but then the OP will come back and say "jeez it goes faster in one direction then the other, why is that?". I was just trying to be proactive.
Show me where any of my statements were wrong? The proper way to control motion in two directions is what I stated, if you want to cobble it go right ahead, but why even waste your time putting in a valve when a pair of vice grips will work just as well.:laughing:
/ Hydraulic Flow Reducer - do they exist? #19
Turbo36...hope you know no ill will was intended in my post, just trying to be comical..... I've always gotten a kick from those discover card commercials (and the joke versions I've seen)...
To answer your questions...None of your statements were wrong...
How do I know the one posted "wont work"...well, its only rated to 2k PSI.. Spec sheet from Deere on the 4120 show the hydraulics being rated to 2500 psi...could you use it...yeah, probably...as for the size, well, 1/8" NPT isnt a common hose size. getting a 1/4" NPT hose assembly is cheap & easy.
Speed difference between extend & retract....I HIGHLY doubt even the most trained eye and sophisticated stopwatch could detect the difference. In theory your 100% right....but in reality how you apply the joystick would make more of a difference... I know I've never noticed a difference on the angle cylinder for my power rake...I use a Needle Valve for my Hydraulic motor rotator...so displacement is the same both ways...
As for the vice grips...well, back in the day when the vice grips were made in the USA, that would be a fine suggestion, but now with the Chinese Vice Grips...not so much :laughing:
/ Hydraulic Flow Reducer - do they exist? #20
I think some people spend more time on this site than they do on their tractors.
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65579)
IMPORTANT PLEASE...
2015 FREIGHTLINER CASCADIA 6x4 T/A DAY CAB TRUCK TRACTOR (A59906)
2015 FREIGHTLINER...
2025 28in. Forks and Frame Mini Skid Steer Attachment (A61572)
2025 28in. Forks...
4004SFL (A59228)
4004SFL (A59228)
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2025 Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
2025 Kivel Quick...
