Mowing Reverse Mowing switch
/ Reverse Mowing switch #1
kcook
MI
Cub Lawn Tractor
Does it stay on after being pushed or does it come off as soon as you go forward? Sorry the SC2400 is the model Im looking at!
Thanks
KC
/ Reverse Mowing switch #2
I don't know what model you are referring to but on my 6284 the reverse PTO switch disengages as soon as you go forward again.
JN
/ Reverse Mowing switch #3
On a Husky it is one of the positions on the ignition switch. Once selected the mower will work in reverse.
/ Reverse Mowing switch #4
Thanks
KC
KC - Cub cadet's (MTD) jargon name for the feature is RevTech - look for that word around the ignition switch or in the machine's brochure...
SC2400 has a switch on the right side, I just wondered after you depress it once will it stay on or do you need to depress it each time you go backwards?
KC
/ Reverse Mowing switch #8
I stand corrected on my 6284 reverse PTO switch. According to my operators manual:
PTO Reverse Override Switch
The PTO reverse override switch is located on the
left fender. Depress the front of the switch to
engage the override which allows the PTO to oper-
ate while the tractor is traveling in the reverse
direction. The indicator light in the override switch
will illuminate when the switch is depressed to the
"ENGAGED" position. Once activated, this func-
tion remains activated until the ignition switch
is turned to the OFF position.
JN
/ Reverse Mowing switch #9
It's been said... but, I thought I'd chime in.
As a Sc2400 owner, I can assure you that you press it once and it stays on until you turn the tractor off. So, for me, that means every time I mow, I just remember to hit the button right off the bat and I'm good until I'm done.
Thanks for the info!!!
KC
/ Reverse Mowing switch #11
Is there a way to bypass the switch? My father just got a 2400 w/blower, and he always forget to hit the switch. Not a fun proposition in wet snow.
/ Reverse Mowing switch #12
Search the forum and you will find numerous posts on bypassing the switch. Most switches are mounted near Reverse Pedal under the tractor and can easily be bent to clear the pedal when depressed.
Bob B.
/ Reverse Mowing switch #13
Wet snow where do I begin
after digging the chute out a couple times he will learn or do like me get mad at my own stupidity, slam the hammer I carry in the cab (the claw kind of fits tru the side handle insert twist and it stays there thru anything)on the side its got a rubber cushion thingy on the butt of the handle it bounces up out of my hand hits the back window and crack!!! Oh did I happen to mention it was the first day after I had put the new back piece on the cab that I built to replace the vinyl now I get to buy another $90. window
some day soon I hope I find where my memory went but also learn to control my temper
LOL
I never looked into it I always figure I will learn to hit it when I pull the pto switch up
although some days I like the reverse lock out thing
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
2025 Pabreak 80in. Hydraulic Dual Cylinder 4-in-1 Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2013 Ford F-250 Crew Cab Pickup Truck (A61568)
2013 Ford F-250...
(APPROX. 100) UNUSED SDLANCH 6' CORRUGATED STEEL (A62131)
(APPROX. 100)...
2016 Ford F-550 4x4 IMT 3203i 2 Ton Crane Mechanics Truck (A61568)
2016 Ford F-550...
Caterpillar 325D Long Reach Excavator (A61567)
Caterpillar 325D...
