Tires Flat tire on my Case 45
/ Flat tire on my Case 45 #1
DH44
North, Texas
Case DX45
Dang mesquites did my front tire a number. I couldn't get enough air into it to seal the bead back up so I brought it into town and had them plug it and added some Slime in it and filled it back up- voila. Now the question- if I want to slime the other one, should I leave it as is and let the air out, install the slime and pump it back up, or should I use a jack and support the weight of it and keep it from flattening out before sliming it?
Thanks
/ Flat tire on my Case 45 #2
Slime is only a temporary fix at best. Why do you not just put tubes in and be done with it?
/ Flat tire on my Case 45 #3
Thanks
Jack it up to be certain you don't break the bead. If you have a FEL, use it. Unlike fix a flat Slime will last for years. You might need to retreat in 5 years, but it should do the job.
/ Flat tire on my Case 45 #4
I suggest jacking up the front or using the FEL as suggested. Slime is excellent for mesquite thorns. I would put at least a quart in each tire. I also have bought a product that's purple from my dealer that actually has little bits of rubber in it. A trick to get your tire back on the bead is to use a rachet tie-down strap in the middle of the tire. Cinch it down very tight and soap the bead good by using a hand-pump spray bottle with dish soap and water. You'll still need a compressor with good airflow to set the bead. You can use the ether and lighter method also, but I'll let somebody else describe that method.
Got the first tire/wheel back on then jacked up the other one. Unscrewed the valve stem, let the air out ans squeezed in 2 bottles of Slime. Aired it back up- no problems. Good to go. I've got a Mule and a 4-wheeler that are all slimed up and haven't had a flat yet. Now I have to get some gallon jugs for the back tires............
/ Flat tire on my Case 45 #6
I'm having better luck with the bullet proof stuff from Gemplers than I am with slime. The tires I've slimed still leak from thorns - but the golf buggy that I bullet proofed - no problems. I have a riding lawn mower with a flat that I need to fix right now... this weekend sometime....I'm sure it's just a thorn I need to pull & plug.
