Snow Snow? Bring it on...
   / Snow? Bring it on... #1
mow4fun
Flemington, NJ
I never had so much fun cleaning snow out!
I get done cleaning and have not broken a drop of sweat and it took half the time. What a machine, very impressed. Best of all, clearing end of driveway is a breeze.
This was a good investment. :)
I still use the snow blower for the side walks but sitting and pushing levers around is much more fun. :)
I have a very steep driveway and it just goes down it and back up with no issues at all. I first tried it with 2 wheel drive and it did fine but did spin a bit, then put in 4wd and simply there is no stopping it. This last snow, I pushed the snow down the driveway about 200 feet (10" of snow) and it handled it with no issues. I have the bar tires on and no chains or fluid in the tires and it is simply unaffected by the snow under it.
   / Snow? Bring it on... #4
I'm surprised you haven't dropped the mower off for the winter plowing season.
I thought about it but it is not in the way and I think it gives addtional weight and balance to the tractor.
   / Snow? Bring it on... #6
Even if this is the case, which I doubt, you're not doing the mower deck any favors.
   / Snow? Bring it on... #7
Just think of it as a Mid Mount Blower :) I'd have the mower running while I was clearing... any snow the bucket missed the mower would suck up and spit out the side ;)
Chilly
Well, I keep thinking it is lowering the center of gravity with the 200lbs or so hanging so low. The snow is only getting on the sides as I push and use my rear blade to scrape behind.
Wouldn't you you think the deck is providing something similar to tires being loaded?
Chilly
I would try that but I have the mulching kit.
   / Snow? Bring it on... #10
Hi mow4fun:
I to left my deck on the first year then midway thru next enough snow go under it and disconnected lift pins. Was 1/2 mile from home what a PITA to get it back on. Now comes off veterans day if not B4.
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2017 KENWORTH T800 TRI AXLE SLEEPER TRUCK (A57880)
2017 KENWORTH T800...
2011 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2011 Freightliner...
DEUTZ MARATHON...
White Metal Roof Panels (A55758)
White Metal Roof...
2018 ARIENS Zero Turn Mower (A56857)
2018 ARIENS Zero...
