Ballast/15gal barrel
/ Ballast/15gal barrel #1
flyingcow
aroostook county maine
I have many 15 gals barrels. thinking about using one of these for ballast. Will it be enough? My rear tires are loaded with Rimgaurd. I also have access to 35 gal drums. Thought 35 gals might be to big and cumbersome. Actually as i type this i think 2(15-gal) barrels might fit side by side in between the bottom 2 links. Too much?
How much does a gal of cement weigh, approx.?
I have a TN75D. Plan on handling pallets of firewood. Might have a 1/2 cord stacked on pallets. Approx 2500lbs, closer to 2,000lbs. Won't be doing a lot of moving around much. Pile on pallets right off of the splitter, move to middle of field, approx a yr later move into garage, next door to boiler.
/ Ballast/15gal barrel #2
26.27 for 1 gal cement, so 35 gal would weigh about 919 lbs.
Portland Cement has a specific gravity of 3.15. Water weighs 8.34 pounds per gallon, and so the problem set up to determine the weight of one gallon of Portland Cement is as follows:
8.34 x 3.15 = 26.271 pounds
A 55 gal drum of water will weigh about 459 lbs.
1 cubic foot of water weighs 62.37 pounds.
55 gal of cement weighs about 1138 lbs
/ Ballast/15gal barrel #3
2 ton /cubic yard, = 18.5lbs per gal (approx) so 15 gal =277lbs, not all that much but if your rear tires are loaded already you may not need much extra weight back there. Don't you just have an implement you can put on?? Most would weigh more than 277 lbs.
7ft bush hog but it's a bit cumbersome.
I probably won't need that much extra weight, but it won't hurt. These barrels seem like a simple and quick way to get ballast. I figure mount some iron thru them, a little welding and fill with cement. A couple of the 15 gal barrels will help. Just like to know what others think.
These pallets of wood will be kept low anyways. Don't plan on stacking them, or loading them onto anything. But chances are, I'll be trying to pick stuff up, way too heavy and way too high.
/ Ballast/15gal barrel #5
I've used old tube that were cattle feed tubs and then filled them with crete' worked out good for an old ford..
soundguy
/ Ballast/15gal barrel #6
Before I created my 3pt weight bracket for suitcase weights, I threw around the idea of creating my own ballast box... One idea I had to keep it small, while still heavy was to add reclaimed lead shot to the cement mix. It's not the cheapest way to roll, but lead weighs more than cement for the same size. Here is a website I found awhile back.
Magnum lead shot, Reclaimed Lead shot, Ballast / Fishing Weight From RotoMetals
If you could get a tire shop to give you old wheel weights, throwing them in the mix would work too.
According to the following website (and, if my math is right), your 15 gal drum filled with lead would be around 1400 lbs. So, a small 15gal drum of lead would weigh a decent amount more than a 55gal drum full of concrete.
Specific Gravity Weights Of Materials from READE
That website is actually fairly helpful. Any scrap steel you had laying around could significantly add to the weight too. If you could somehow fill the 15gal drum with steel, you'd have just under 1000 lbs.
/ Ballast/15gal barrel #7
Be careful you don't get too much.
I've just recently done some of that weight via concrete work. A five gallon pail took exactly one 80 pound bag of redi-mix. They both are 0.66 cubic feet. So 15 gallons should be right around 240 pounds plus any steel you use in fabricating plus any lead that you add if you follow one of the suggestions. The concrete after mix and cured might be a little more than above calculation due to moisture retention.
If you don't have to man handle the weight and can back up to it and hook it on your three point hitch, 250-300 pounds is ok, but if you have to move it by hand, it is going to be a pain.
I recently built a combination front or rear ballast box that uses 4 concrete blocks that I made forms for and put rings in to handle them. Each block weighs about 44 pounds and the steel frame weighs 80 pounds so I can handle each piece without a problem. If it were only going to be used on the rear 3pt hitch I would have just made it one solid piece. But putting it on the front I have to lift it and bolt it to the frame.
/ Ballast/15gal barrel #9
That's quite a disparity in weights!
According to Wiki.answers.com "Normal weight concrete -- a mixture or sand, cement, and stone gravel -- has an accepted density of 145 pounds per cubic foot."
THUS:
1 gal = .133680556 cubic feet
@ 145 lbs to the cubic foot
1 gal = 145 X .133680556 = 19.38368062 lbs
15 gal = 290.7552093 lbs
Just my 2 cents.
Hankus
/ Ballast/15gal barrel #10
If you are talking rear ballast for your TN75D I don't think a 15 gallon barrel (or two) would be enough. I use a 55 gallon plastic barrel for my 26 HP tractor. With the steel framework and filled 3/4 full of ready mix it weighs about 800 lb. Your backhoe weighs more than that and is plenty of ballast but I guess you don't have that on which is why you need the ballast.
/ Ballast/15gal barrel #11
This in on a Kubota M4800 with a Bushhog M346 loader. The tractor weighs 3750# dry. The loader weighs aprox. 2000#.
I have a 55 gallon drum as ballast. It took 13 bags of quickcrete to fill it. These were 80# bags. I added aprox 1 gallon of water to each bag.
80 pounds x13 bags = 1040#
13 gallons water x 8.35# = 108#
Total weight is aprox : 1148#
I have this along with filled 14.9x28 rear tires. Each tire at 75% holds 53 gallons of water. That add 442#s per tire.
Total Ballast 1148 + 884 = 2032#
There are times when I get a full scoop of gravel in the bucket (6' heavy bucket) that the back tires want to spin.
I can actually pick up a large enough rock in the bucket to loose traction and not be able to move the tractor (2wd).
Total weight of tractor with ballast and loader is aprox. 7800#
Appreciate the responses. Looks like given the size of my tractor, 55 gals might be more in what i need. Thanks guys.
/ Ballast/15gal barrel #13
I think concrete weight is always going to vary a bit due to differences in the aggregates weight but however you figure it, you have to weigh the cured concrete. You can't add the weight of the water to the weight of the cement and assume that will be a finished weight. Much of the water is used in the chemical hydration process and then evaporates out of the cured concrete.
/ Ballast/15gal barrel #14
That being said, by the time you add the 13 (80#) bags of concrete and the weight of the drum and all the steel that it takes to put together the ballast box the weight is going to be pretty close to the 1150# that I listed.
Chris
/ Ballast/15gal barrel #15
Save a few bucks and first fill your barrel with rocks and then mix the concrete fairly loose (extra water as strength is not a big issue) and add the concrete to the barrel. Being a thin (lose) mix it will flow into the spaces between rocks pretty good and not trap a lot of air. Banging on the barrel with a hammer or a club will help release trapped air.
If you have or get a carry all platform for the 3PH you won't need to build attachment points on the barrel AND you can use the carry all for other things as well. Putting the barrel on and off the carry all is not trivial but not all that difficult. One way is to put an eye bolt or equivalent in the top of the barrel. Lift the carry all and attach a holder (chain or whatever to the eye) and then lower the 3PH. That removes the barrel. Reverse the process to put it on the carry all.
Pat
/ Ballast/15gal barrel #16
Or use a 50gallon drum 1/2 full of concrete, leaving the top half as a carry-all. Before you add the concrete run a suitable size rod thru it about 8" from the bottom so you can attach your 3pth. Ditto with the upper link so it doesn't swing when under way. You can also add a receiver hitch to the bottom rear for a drawbar or trailer ball....
As long as the bottom is flat enough so it doesn't tip when you lower it for removal you are good to go, just keep adding more concrete until its heavy enough..(or add used wheel weights, scrap chain, etc)
/ Ballast/15gal barrel #18
Allot of great ideas here. Something that I found useful was to use a 30 gallon plastic barrel, mount it on a draw-bar from TSC and use dry sand in it. I can adjust the weight for what I'm doing whether it's counter weight for the front bucket or the front blower. I use the sand to combat ice when needed. I was lucky enough to find a barrel that has a ring clamp that holds the top on which is rain tight. I keep a feed scoop inside the barrel so I can throw some sand around the driveway when it gets icy. My tractor is a SC2400 so it's not real big, but it sure helps to stabilize it when hauling gravel around in the bucket or when using the blower.---DTS---
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
2012 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR2CJ453403 (A61165)
2012 International...
2025 Pabreak 74in. Hydraulic Dual Cylinder 4-in-1 Bucket Skid Steer Attachment (A61567)
2025 Pabreak 74in...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
New/Unused Wolverine Ripper (A61166)
New/Unused...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61568)
2013 Ford F-550...
