Troy-Bilt Horse ID
/ Troy-Bilt Horse ID #21
CR172, 17566 is not a part number in my 1982 parts catalog for the Horse Model. Could it be your tiller serial number? There are two locations to look for it. (BTW, Troy Bilt sold an optional snow plow as an accessory. :D)
Dennis, TH-1001-1 is also not a part number in my parts catalog. With it being cast, it might be a part number?
The controls on mine are limited to a throttle, the hi-low range lever and one lever that engages the tines and transmission. The tines always turn on mine whenever it is moving forward or backwards.
Mine has a shut off valve under the gas tank that you turn to turn off the gas. Could be that yours is frozen, but I think you can get replacements pretty easily.
If my single belt is worn or is the slightest bit out of adjustment, it wants to slip. If the two belt drive is less sensitive to slipping then the two belt system would the one to get. I've never felt the need to use anything other than the hi-lo range lever on mine.
Based on your questions, Dennis, I'm still not sure which tiller model you have. The briggs serial no. could be in the location shown in the attachment.
  • Tiller and Briggs serial nos..pdf
Rocks,
I would think it is the serial number.
Dennis,
I also have a shutoff valve on the bottom of my tank. It only wants to turn about a 1/4 turn. I think it's partly frozen has was mentioned above. I plan on replacing mine. Easy fix.
Bill
From what I can tell. With the serial number being what it is and located where it is, this is a pre 7-5-71 horse. Sill running strong....
But I thought the numbers for the engine indicated it was a '79 model......... So, either I misinterpreted the engine serial number, or it was replaced. Either way, now I know what parts to get if/when needed.....:D
/ Troy-Bilt Horse ID #25
Mine is definately like CR172's. In addition, it has HORSE on the shroud with all of the information about it on the big yellow sticker......I gotta take a pic.......
Anyway....it definately has the huge slow and fast lever on the right coming up out of the right side of the transmission, actually from underneath, and then the long lever coming up from the center area of the transmission for forward and reverse............
2manyrocks......you do know that you can adjust the belt for getting rid of slippage?????.....one adjusts the block at the base of the forward reverse lever up or down.......
Gotta get out there and look on the engine shroud for that number.....THANKS.......Dennis
Rocks or Dennis,
Could either of you post pictures of the side shields of your tine shroud? One side of mine is missing, and I think the other has been 'modified'.... I found a new tiller shroud, but it's ~250.00........ No thanks. I can get some sheet metal and fab one myself. I'm sure one of our neighbors has welding equipment. Just really needs to be spot welded. Or I could just bolt them on.
/ Troy-Bilt Horse ID #27
The tricky part may be that the side shield doesn't come straight down and appears to flare out about 1 1/4 to 1 1/2 inches roughly. I can't figure out how to measure it exactly. The side shield is 4 9/16 from the side of the cast iron tine housing, but keep in mind that the housing is inset relative to the top of the tine shield.
Thanks:) Yep, the one that isn't missing has been modified...... Maybe keep my eye open for a "dead horse"..... for parts....
/ Troy-Bilt Horse ID #29
Mr. 2many..........Thanks for the attachment about the serial numbers......I did find my engine numbers; but golly are they ever messed up. I need to get in touch with an archaeologist to be able to decipher them.......That's a joke but pretty true. I went to B&S web sight and tried to plug in what I could get, but no luck.........Anyway, life goes on. I really thank you guys for your input and thoughts........GOD BLESS........Dennis
/ Troy-Bilt Horse ID #30
It has been a pleasure to chat with both of you about these fine machines. I didn't understand the 2 belt 1 belt thing until Bill explained that the 2 belts go on the 2 speed transmission model. Now I get it.
I had one of the Troy Bilt Juniors. There weren't any side shields on it, and it always did a great job for me. If someone has really dusty soil or sensitive plants, maybe the side shields become important, but I never missed them on the Junior model.
/ Troy-Bilt Horse ID #31
I have a 1976 Horse that I purchased new. It has the 6HP Tecumseh engine. The side shields on the tiller shroud were straight when new but stretched to a convex shape under heavy tilling (roots, rocks, thick grass, etc.). The side shields were spot welded and one came off in heavy usage. Years ago I replaced the tiller shroud. The old shroud is long gone. I forget how much the new replacement cost, but it was not even close to $250. The tiller cost $675 in 1976.
I was looking at a 2001 Horse with the 8HP B&S the other day. This unit was for sale as new at the local Gateway Rescue Mission Thrift Store for $1,100. It looked new to me except for storage wear. The tiller housing on this tiller is much sturdier and should withstand much more abuse than the older model.
Hope this helps
/ Troy-Bilt Horse ID #32
Well, I've done a search here and found several places to look, but. We just acquired an older Troy-Bilt Horse with a 7HP Kohler K161T engine. The thing runs and works great. It has the 2 belts. I have found both the owners and service manual for the engine, but I can't find any model or serial numbers on the tiller itself. I've looked all over the castings and there aren't any numbers stamped anywhere. The serial number from the engine indicates it is a 1979. Also, the labels on the tiller shroud look different from all the others I've seen. It doesn't say Horse on it anywhere. It does say Garden-Way...
Any ideas?
Bill send me an email and I will send you a manual on the tiller. wbracy@gsinet.net Put troybilt tiller in the subject matter.
Wayne
I agree Rocks. I has been a pleasure. Once we dry out, we'll put the horse to the test. As you said, the side shields may not be that big of a deal. We'll see.
Now, if I could get info over on the Vintage thread.....:(
/ Troy-Bilt Horse ID #34
Wayne..........First rate help on the manual and I gotta thank YOU..........Have yet to find my serial number; but the parts manual says to look at the date cast into the side of the transmission for when it was made.........3/12/79...........If so I think I am totally lucky as this is when there were several very important changes........8 hp B&S and the single belt 2 speed transmission.............
Anyway.......Gotta thank you Wayne and ALL of you guys for the help, consideration, and patience for putting up with this ol boy..............GOD BLESS........Dennis
I'd like to give Wayne a big thank you also on the manual(s). He sent everything, and more, that I need for this machine. They will be a great help in maintenance and parts.
A big ol' thumbs up goes out to Wayne......:D
/ Troy-Bilt Horse ID #36
Thank you although it is not needed. Been at the same place as most of you guys trying to find parts for Troybilt.
Guess I got spoiled when I could drive right up to the factory in Troy and get parts!
Wayne
Got the old horse out in the dirt a little last Saturday. Still a little too wet to do any serious work but did get a complete pass over the 65 x 25 garden at 2". The majority of this area has never been worked. Was part of the yard. We had used a sod cutter then my neighbors tractor and FEL to remove the grass.
First thing I need to do is replace the belts. They slip real bad in the heavy clay soil. The guy we got this from said he thought they were the originals.....
I will say this. All the ads and stuff you see for these being used one handed..... Well, maybe after the ground has been worked and amended. Those tines bite into that clay and the horse wants to run......:eek: Still much better than a front or mid tine machine....
/ Troy-Bilt Horse ID #38
You'll save yourself and your machine a great deal of work if you break fresh ground with a plow first and then use the tiller to finish it off. When the ground is really broken, it would then be a one handed machine, but not when you're working fresh ground.
We'll have another two months of cold weather before I can get in our garden. All we have is mud and cold right now.
I don't have a plow.....
/ Troy-Bilt Horse ID #40
I don't have a Troybuilt tiller, but I have a snow plow blade for one that I am giving to my buddy. Does anyone know how it is attached and where it is attached? The Troybuilt website is totally useless.
2022 EZ-GO ELITE...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
2022 EZ-GO ELITE...
Man Basket (A65640)
Man Basket (A65640)
2010 Chevrolet Express 3500 Dive Team Cargo Van (A64556)
2010 Chevrolet...
2013 Chevrolet Tahoe SUV (A64194)
2013 Chevrolet...
