What are these called?
/ What are these called?
Thanks all for the resoponses:
Willl,
What kind of a idea you got brewing?
Kinda in the "Hmmm, I wonder if I could..." stage. But first got to gather where to get parts, how much, easier to buy or build, etc. But, if 'whatever' works, will be posting pictures.
charlz,
Thanks for that chart of sizes, went straight to my 'favorites'
Mas1237,
Thanks for the supply source, now I know at least a "already done" price.
bobodu,
That is such a great idea! What makes it so good is it's one of those so obvious things...after somebody else points it out!
/ What are these called? #22
Tisco sells an 'A' frame kit that you bolt to your 11-hole cat 1 drawbar... I got one from my dealer for about 20$ a few years ago..
soundguy
Soundguy - What you are describing is exactly what I'm looking for. I looked through the Tisco on-line catalog but couldn't find this kit. Any suggestions where to look?
Thanks!
/ What are these called? #23
my local tractor dealer was a tisco dealer, and i just walked in and asked for an a-frame kit, and he reache dunder the parts counter and plopped out the 2 uprights, and the short pipe sections as spacers at the top and a hand full of bolts.. said to use my own drawbar.. was 20$ and some change.. in 2004 or so..
soundguy
/ What are these called? #24
soundguy
What did you need it for, some type of trailer towing or just to keep the HDB from rolling?
I like the EZ mover, don't have one cause I have a dedicated Flexpoint mover, but if I didn't have the flexpoint I would get one of these. Either buy one or make it myself.
https://www.imcuniverse.com/store/ezmover.htm
JB.
/ What are these called? #26
JB.
I wanted to pull a flatbed trailer with hay on it for a hay ride..
worked great.
soundguy
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
2021 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2021 KENWORTH T680...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
Decorative Mermaid Light Post (A61574)
Decorative Mermaid...
