front wheel came off
/ front wheel came off
I think the hub is ok. I had very little shavings from the tap. I'm of two minds regarding the bolts too. I'd rather have them fail than rip up the hub but when I'm on a hill and there's stress on the wheel, I really really want the bolts to hold :)
When the snow dies down and we warm up, I'll pull the wheel again and really give the hub a close look.
/ front wheel came off #22
Heli coils have already been mentioned, but I prefere case savers if there is enough room on the hub. You drill out the damaged threads, tap the hole to a next larger size. Then red loctite the case saver in. Now you are back to all lug bolts being usuable, and of the same size. I check my lug bolts, and major tractor frame bolts twice a year. In the spring, and then the fall. My neighbor had his front wheel fall off his John Deere 650 4WDseveral years ago. He just didn't check them ever I think.
/ front wheel came off #23
I good well stocked hardware or old fashioned hardware. I've had very good luck with True Value. TSC doesn't tend to carry metrics.
they do.. but not in bulk.. they are inthe baggies inthe lil bins opposite the bulk isle..
also have nylon, stainless, and some brass fasteners too.. iffn' you can afford them per piece in them baggies..
soundguy
/ front wheel came off #24
put helicoils in where the threads are damaged, put the right OEM bolts in, torque it to spec and it will be good for life. Tire bolts don't just fall off when they get bored or tired.... my guess is they were not torqued right at some point in their lives.
wayne
That bored or tired thing cracked me up.:D
/ front wheel came off #26
Clean the threads if you must. Then get grade 8 bolts, screw them from the inside out... You now have studs that you can replace if necessary. Get the appropriate lug nut.
Mount these new studs with red locktite. With hardened studs mounted in the hub you will not have to worry about damaged threads.
If you have room for a lock nut on the inside you have room to mount a bolt as a stud. Plus you will never have a problem removing the wheel because you forgot there was a locking nut inside. KennyV
/ front wheel came off #27
What you have never heard of "metal fatigue"? :D. There are some great replies on here. I am always picking up bits of wisdom from this site. Eventually I may know a thing or two!
metal fatigue has nothing to do with bolts falling out. If his bolts all sheared off, the casting broke or something like that you can attribute it to fatigue, but in this case my money is on they were not torques properly.
On my 4400 they specifically tell you to re-torque the wheel bolts on a new machine after a few hours.
I'm still of the school that if you repair any of the damaged threads with your favorite thread repair system, put new OEM equilvilent bolts in, torque them to spec, you will be good for life and the bored lazy bolts will stay put!
Wayne
/ front wheel came off #28
From what I see from your Pictures of the bolts, and you had it to the dealer for inspection. My guess would be the Mechanic used a impact gun to install the wheels and over tighten the bolts. I have seen this many times the casting is harder then the bolts and the bolt keeps tightening to the point that it strips out ( rips the threads off ) from the impact gun and the wheel will stay tight for a while until the bolts back out and wheel falls off. You can see from the bolts that it was rotation force that took the threads off.
Just My opinion but I would say Impact gun damage.
/ front wheel came off #29
Wayne
Sorry Wayne you might have missed the sarcasm in reference to the "tired" bolts and metal fatigue. :)I really do know that was not the problem. I mentioned in posting number 2 on this thread that the bolts not being tightened down right may have started the whole failure. I am guilty myself of not rechecking the lug bolts on my tractor after I had the fronts filled with foam..
/ front wheel came off #31
Rotor is right. That bolt pic is a signature failure cause by overtorquing. In my opinion its a slow overtorque, not a high speed stripping caused by a pulsing impact wrench. Bolts are too soft. An impact would have snapped the head off. Are there supposed to be tapered pilots on those lugs instead of a flat head? Also, is the wheel piloted by a hubcentric ring? If so, the bolts just don't really need to be that tight. Your other wheels ought to tell the tale. They are probably in the same condition. Another thing to watch is the thread pitch. This could be an English tread in a Metric hub. It works for a while. Foam is for junkyard operation, not traction.
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
John Deere Hood Guard (A63116)
John Deere Hood...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
2005 Volvo VNL Truck, VIN # 4V4N19TGX5N374968 (A61165)
2005 Volvo VNL...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
Bushwhacker ST120 (A64047)
Bushwhacker ST120...
