Pressure relief valve
/ Pressure relief valve #1
cole0324
I have built a grapple for my New Holland L555 and the cylinder is way to strong for the grapple. Breaking welds when full of sticks. So, I have heard of this pressure relief valve but know nothing about them. Which one do I need if at all? How and where do I mount it etc? Or is there one somewhere already on the L555 to adjust? The grapple is running off of factory aux hydraulics.
/ Pressure relief valve #2
Think that a relief valve will need a bypass back to tank.
On the other hand a flow restricter could solve the problem.
A restricter slows things down for more precise control, basically, as name suggests, a restriction in the line.
If your handy, a fitting welded shut with a tiny hole drilled thru the weld will restrict flow.
You could start with 3/32" and drill larger as required.
/ Pressure relief valve #3
A relief valve will reduce hydraulic pressure and thus, the cylinder force by dumping some of the oil back to tank. Since you are using a factory auxiliary port you may want to look in to a cross port relief. A cross port relief will dump oil from one side of the cylinder to the other side if it exceeds the relief pressure setting. These are often used as torque limiters for hydraulic motors. You could install this valve in the lines that go to the cylinder and not have to run a separate return line back to the transmission.
/ Pressure relief valve #4
A flow restrictor will NOT releif excessive pressure and prevent from mechanical damages!
In my animation here you can see how that relief valve (2500psi), RV, should be plumbed....between control valve and cylinder....it is preferable to have a separate return to tank from the RV...but if you use it for shock protection (external force on the cylinder), it should be Tee'd into the other cylinder line together with a check valve (anti cavitation valve). This to refill oil on the low pressure side.
/ Pressure relief valve #5
Cool animation AKKAMAAN.:cool: How you do that. I agree a pressure relief valve is what is needed. A restrictor will only slow your actuator speed down. You still will have system pressure.
/ Pressure relief valve #6
AKKAMAAN .. your system will work but what if you install a reducing valve then you will not need to replumb to the tank. just install it in the line and let the RV on the tractor handle the relief. this will also prevent the cylinder from drifting down if there is more load placed on the cylinder after the control valve released. this will act as a load lock, with your style if there is more load after then the cylinder will drift. Jim Sun Hydraulics
/ Pressure relief valve #7
Good thinking Jim...but how do we get the retract return oil back to tank if it at the same time prevents from drifting???
/ Pressure relief valve #9
cross over relief???
cross over relief valves is basically for shock relief to provide anti cavitation refill to low pressure side and they still need contact with tank on the low pressure side if bi directional actuator is other than 1:1 ratio (motor, double rod cylinder or double cross connected cylinders see pic)
/ Pressure relief valve #10
A port relief with a make up check or a cross port relief on cross connect cylinders will provide shock protection in that they allow the cylinder to move when the control valve is closed, if the relief pressure is exceeded. On a single cylinder, a cross port relief will limit the force only when the control valve is open. When the control valve is open, high pressure is supplied to one side of the cylinder and the other side of the cylinder is connected to tank through the control valve. A cross port relief would dump oil from the high pressure side to the low pressure side, which is connected to tank through the control valve, if the relief pressure is exceeded. This will limit the force of the cylinder. When the control valve is closed you will have no shock protection but I do not think that is what cole0324 needs. He only wants to limit his grapple force when he is closing it. A cross port relief would also limit the grapples opening force but you should not need much to open it anyway. I figured a cross port relief would be the simplest for cole0324 to install since he would only need the valve and a couple short hoses so he could insert it in the lines to his cylinder and he would not have to figure out how to connect a separate tank line.
Cross-Over Relief Valve - 1/2" Port - Buyers HCR050
/ Pressure relief valve #12
A cross over work port RV need to be connected to tank if cylinder area ratio (capped area:rod side area) is other than 1:1
Yes that is true if you need to handle shock loads. If you just want to limit the force when closing the grapple, then the cross over has a path to tank through the return side of the control valve.
Well so far I like the song Stonehauler is singing. Thanks guys. I guess I could always just be careful. LOL
Got a diagram for the hookup of that valve? Please guys keep it simple.
/ Pressure relief valve #15
Normally a cross over relief is mounted as close to the cylinder as practical. But since you are not interested shock load reduction, you could probably mount this valve on the back of your tractor close to your auxiliary connections. This type of valve is basically inserted in series with the lines from the valve to the cylinder. Refer to the first attached image. The two lines from your tractor auxiliary ports go to the Valve A and Valve B ports and the Actuator A & B ports go to the cylinder. Before ordering a valve, you need to decide the pressure and port size you want. Valves are available in different pressure ranges.
The valve here may suit your application as it is adjustable from 1500-3000 psi.
Crossover Reliefs (Cushion Valves) - Cylinder Services
Another option is to mount a relief valve in the line that closes the grapple like AKKAMAAN proposed. With a valve like the Parker Series WJL shown in the second attached image you may be able to support with just a quick disconnect plugged into your auxiliary connection. One P port goes to the tractor auxiliary quick disconnect and the other P port goes the side of cylinder that closes the grapple. However, you will have to find a tank connection on your tractor for the T port.
The relief valve is cheaper than the cross over:
Differential Poppet Reliefs - Cylinder Services
:eek:Wow! who would have thought the Saints would try on an on side kick at the start of the 3rd? I must be nuts typing this during the Super bowl.
/ Pressure relief valve #16
I am puzzled by the problem of to much force. You, the operator, are the one applying the force via the lever on the valve. If you were to install a gage in the grapple cylinder circuit, you could see how much pressure that you are applying. When you activate the grapple, can you not see, hear or have a feel about the force applied. I have a gage in my cylinder lift circuit, and I can see what the pressure is, and when not doing hard work, the pressure is very low. The pressure will be proportional to the force applied. There may be times when you need max pressure in order to hold a large rock in the bucket. In that case,the relief valve would relieve at the set pressure. They make valves with more lever control, which is proportional control, or more finite movements.
I have seen demonstrations where the operator picks up coke cans and moves them around with out crushing.
/ Pressure relief valve #17
I have seen proportional electro-hydraulic servo controlled log cranes pick up, out of a case, glass beer bottles in the neck, and distribute them to the crowds....
2018 KAUFMAN 44 FT T/A  CAR CARRIER TRAILER (A59914)
2018 KAUFMAN 44 FT...
1996 FRUEHAUF 45' SLIDING AXLE FLATBED TRAILER (A59911)
1996 FRUEHAUF 45'...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
Bulldozer Rake (A64127)
Bulldozer Rake...
