Pole Barn Design-Over Building?
   / Pole Barn Design-Over Building? #21
I suggest that if you want a decent barn that you do not use rough cut hemlock for the framework construction. There are a couple reasons why I say this. First and foremost is that I am familiar with the Amish in your area and as far as I know their hemlock is not graded. In other words it may have different moisture content, large knots, and quite often shake. This results in low strength lumber with varying sizes. Rough cut hemlock certainly should not be used for trusses. I had the local Amish build my barn with such lumber and I have regretted it ever since. I was not unhappy with their work, just the results you get with rough cut hemlock. Also do not use any posts that are less than .60 treated, be they solid posts or laminated. That rough cut hemlock can vary in size a considerable amount from one board to another. I used solid 6 x 6 .60 treated posts with hemlock 2 x's for the framework. The outside is board and batten 1 x 10 white pine with a gambrel roof.
If you want a good building do your self a favor and go take a look at a couple of those barns with a "M" on the front of them. Take a digital camera with you. Kenny has also given you some good advise. Good luck in your project.
Bitternut-Points well taken! The Sawer that I've dealt with before turns out accurately sized boards, but your right about moisture content. It's all green wood and fresh cut. No drying, stickering, etc. Your taking it off the the 'blade'!! Yes, I'm familiar with Morten buildings! KennyD's got me turned around, to the manufactured trusses, and fully PT'ed subsurface wood products. I've Got an RFP out to a local lumberyard to get me a price on 30' "W" (fink) trusses w/4/12 pitch. Should get that tommorrow. Bottom line is that I want to design a plan that, will work, is what I want, and do it in the most cost effective manner. As Ken suggested, I may just go to the Amish, in the end, and say: "Quote me this building". But at least I've got plans to show them, or anyone! Scotty "Still Drawing" 370!!!
   / Pole Barn Design-Over Building? #23
Bitternut-Points well taken! The Sawer that I've dealt with before turns out accurately sized boards, but your right about moisture content. It's all green wood and fresh cut. No drying, stickering, etc. Your taking it off the the 'blade'!! Yes, I'm familiar with Morten buildings! KennyD's got me turned around, to the manufactured trusses, and fully PT'ed subsurface wood products. I've Got an RFP out to a local lumberyard to get me a price on 30' "W" (fink) trusses w/4/12 pitch. Should get that tommorrow. Bottom line is that I want to design a plan that, will work, is what I want, and do it in the most cost effective manner. As Ken suggested, I may just got to the Amish, in the end, and say: "Quote me this building". But at least I've got plans to show them, or anyone! Scotty "Still Drawing" 370!!!
You have a good handle on it now... I would be vary cautious about green lumber also...air dried a few years OK, Kiln dried even more OK but green-not for me.
I did the same as you-then got the price I told you before and was slapped in the face with the realization that I could not do it myself cheaper than they could, I hope you are as lucky.
   / Pole Barn Design-Over Building? #24
Check out these web pages to get an idea of the design.
Kit Includes :: APM Pole Building & Garage KIts
These guys will do the design for you if you buy their material (kit barn). These guys may not be in your area, but other lumber yards also do this.
Thanks Buck! More good info!!! Bookedmarked for sure! ~Scotty
   / Pole Barn Design-Over Building? #26
So the pulins on the roof don't sag, they are just 2x4's laying down. the 2x12 beams hold up the trusses between the post's.
I've also seen and wondered about that. Now I understand. Standard around here is trusses either side of all center posts at 12ft OC for post spacing, but we always have 2x6 perlins on edge also. 2x4's flat would make a huge difference to the structural strength of the roof.
   / Pole Barn Design-Over Building? #27
id check with your local lumber yard on what AG trusses they have on file that they can order.
i can tell you that standard AG trusses will come in 4,6,8,10' OC. standard AG loading should be something like 20-5-1, although local snow loads will vary the top chord live load. Top chord perlin spaceing is normally 2' OC but can be varied if factored into the truss design. but over 4' OC is uncommon due to support issues with the tin.
the nice thing about ordering a pole barn package from a truss company is they can plate treated material on the bottom 5' of the posts and then transition to standard material to save cost. sidewall height and OC post spaceing will play a role on size of posts (3ply 2x6, 4ply 2x6, 3ply 2x8 etc)
   / Pole Barn Design-Over Building? #28
There is a little engineering to building a good shed. Height of the walls is important, I didn't notice you ever mentioning that..... No one can really tell you what size poles to create without knowing how tall the sidewalls are - wind load gets worse on taller buildings.
Don't use green wood, or untreated wood, in the ground. That was aready covered, but reading this thread, I just had to say it also! 9 times out of 10, that would be a foolish mistake that would wreck your day within 10 years.
Often the best bang for the buck is to have a truss only on top of each set of poles. Then that top board around the walls doesn't have to be so big as it doesn't hold any weight. The trusses need to be bigger, but you only need 1/2 as many. Put the purlins on edge & possibly closer together - but it still pencils out cheaper this way than trying to do 6 foot poles & 3 foot trusses (or 8 & 4) - every other truss will want to sag, so you need a terrible strong doubled top girt.
If you engineer it all out proper, the best bang for the buck is a bigger truss, less of them, and perlins on edge to hold the tin.
If you just are guessing and overbuilding here & there and underbuilding there & here to hope it all holds together, well then who knows what is cheaper or too cheap?
I do hope the package deal comes out cheaper for you - it should. :) But the planning & figuring is sure fun, so no harm in that.
--->Paul
Latest progress:
   / Pole Barn Design-Over Building? #30
Have you considered a floating slab with the building bolted on top?
No chance of wood touching the ground and rotting away. It is also easier to have the top of the floor higher than the surrounding grade for drainage away from the building.
My building is 42' x 48' on a floating slab in southern Wisconsin. The posts and trusses are 8' on center. It is a Lester building.
I agree with the other comments. It isn't worth the effort to build your own trusses, not to mention trying to keep them all consistent.
I didn't notice on your design, but for ease of access and ventilation having an overhead door at both ends is really great. Also having 2' eves as well.
   / Pole Barn Design-Over Building? #31
What is the function / purpose of the knee braces? Seems like extra work.
If the trusses are located at the same spacing as the columns, only a girt is needed at the eave.
Just wondering.
Yooper Dave
   / Pole Barn Design-Over Building? #32
Just wondering.
Yooper Dave
I was wondering the same. This over-design is missing out on the benifits of a pole building.....
Wonder if he has a Menards (like a Lowes or Home Depot -upper-midwest region) near him - They have a building calculator kiosk in each store, go play with the design & it prints out materials & price list. Would be a cool starting point.
--->Paul
   / Pole Barn Design-Over Building? #34
Lateral stability. And they look nice:D
Knee braces up that high provide very little lateral resistance. I doubt the columns can accept the axial load from the braces induced into their side creating a weak-axis moment.
Those brace(s) need to extend down to the kick-board - that will provide effective lateral stability.
Post and beam construction is somewhat similar - but the members are substantially larger, and able to resist the imposed moment.
Yooper Dave
   / Pole Barn Design-Over Building? #35
Yooper Dave
OK, Thanks...
I will let my builder and county inspection department know they are wrong and the braces are not needed.
This is why is never posted a thread on building my building...to many opinions..Not say you are wrong.
   / Pole Barn Design-Over Building? #36
OK, Thanks...
The good thing here is you save $125/hour of structural engineering consulting fees in a relaxed format.
I will say I am concerned for the safety of the public. People expect a building to be safe - it is assumed.
Yooper Dave
   / Pole Barn Design-Over Building? #37
My barn has an upper floor and is over 25' to the peak. It was kind of scary standing in the upper floor with a stiff breeze. I asked the Amish guy that built it about how shaky it was and he said he builds all his barns like mine. I ended up running 2x6 diagonal braces from the skirt board to the top plate. Every girt was securely nailed with ring nails. No more wiggle even in real strong winds. I had a couple people get scared on windy days before I fixed things. Braces are your friend, use them.
   / Pole Barn Design-Over Building? #38
It still needed braces even after the building was sheeted?
   / Pole Barn Design-Over Building? #39
Sure did. The outside of the barn is covered with 1 x 10 pine board and batten so there is not a lot of support there. Also the barn sits kind of in the open on a small knoll at the end of a long valley that runs the same direction as the prevailing winds. The long side of the barn is more or less perpendicular to the wind direction. There is no wiggle at all now.
   / Pole Barn Design-Over Building? #40
I agree they look nice.
I rarely look at who is posting; my fault. I thought it was the original poster with a revised design for his future building.
If looks count, then that's different. For a covered pole barn often the idea is to have a good building, and make it cheap but sturdy.
Assuming it is tinned as most pole barns are, your supports aren't visible from outside. So the pretty - which I agree - gets lost.
As to support, I'm sure they offer some, but seems like a lot of wood & cutting & working up high; when the same support could be added with a few metal straps or top to bottom 2x4 angle bracing. The proportion of your andgles appear to be more for looks, than for good support.
Nothing wrong with your design if you are paying the bills and you pay extra for 'looks good'. That's cool. :)
For those looking to build a sturdy but inexpensive storage building, there would be simpler (ie cheaper) ways to build that.
I have a machine shed that was dragged ontot he place I guess in the 1940's, and added onto 2x, with the roof lifted once. It is built out of 2x4 for a lot of the support, and _not_ on 24 inch centers. Sort of 1/2 pole building, 1/2 stick built. It would _never_ pass a building inspection. The interior poles are set on piers that are 6 inches or a foot deep. And so on.
Somehow it keeps taking the MN winters here. And it has some of those top supports in it. They help, but they are too small, too weak.... But it keeps standing.
So, I'm not meaninb to be critical of your building! I guess I was looking at different angle than you were, and sorry if I came off wrong.
--->Paul
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2020 FREIGHTLINER...
2020 John Deere 1025R MFWD Compact Tractor (A56438)
2020 John Deere...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A59823)
KNOW BEFORE YOU...
MINI KID DIRT BIKE (A56859)
MINI KID DIRT BIKE...
