John Deere 4100 tires
/ John Deere 4100 tires #1
MRBLUBLR
I'm having a really hard time finding tires for my tractor.
I have a 2000 John Deere 4100 4x4. The rear tires are 315/75/D15 or 12.4x9.3 x15
I have worn out turf tires and would like to get some Ag (R1, etc) tread tires.
Thanks and great forum!
/ John Deere 4100 tires #2
On a 4100, The standard R1's were 9.5-16 in back, and 5-12 in front.
Turf, R3's were 315x75D-15 rear, and 23x8.5x12 in front.
R1's called for a different 16" rim on the rear as opposed to your 15"
Can't say if the R1 fronts will also fit your rims.:confused:
Do you know of a R1 that will fit my wheel?
/ John Deere 4100 tires #4
I would suggest checking with either a John Deere dealer, or better yet a commercial tire dealer that handles AG equipment.
Or search eBay for a set of rims with or without tires.
/ John Deere 4100 tires #5
To go from Turf's to R1's you will need new rim's...the ones you have will be to wide.
I found some at Tucker tire, thanks to the other post in the section.
I was able to get 31x15x15s in a R1 tread made my BKT
Anyone know how wide the rear wheels are on a 4100 with turf tires?
/ John Deere 4100 tires #8
Did those work? I’m looking to do the same thing. I thought the backs were 33x12.50x15. From what I’ve Gathered online you have to keep the tires close to what came on it or the same ratio for gearing/rotation of front to rear tires. Any Insight would be greatly appreciated. I’m having a hard time finding 16” rims or a pair of 15” r4 or r1 for the back to replace the useless r3 turf tires. Thanks
/ John Deere 4100 tires #10
You have a greater issue than just will fit for the sake of not damaging your tractor. Since the rear tires are typically and reported sizes support this much larger than the fronts, rolling circumference comes into play. JD has done all this math for you by providing tire sizes in given tire types.
My suggestion to avoid buy different wheels, is look for the turf sizes in industrial tires (R4’s). While a different tread, they are more similarly sized to turfs than R1’s.
2013 DODGE CHARGER (A63276)
2013 DODGE CHARGER...
Kuhn FC400RG (A60462)
2025 GRIFFIN DUMP TRAILER (A59910)
2025 GRIFFIN DUMP...
1999 FONTAINE 403A DETACH TRAILER (A62130)
1999 FONTAINE 403A...
KUHN KNIGHT SLINGER 8118 SPREADER (A63276)
KUHN KNIGHT...
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
