BX1860 or 2360?
/ BX1860 or 2360? #1
Danilo
Penfield NY
Kubota
Ok, So I have been seeking a tractor for general lawn care. I know either one will be overkill, however, I looked at "garden tractors" and for the money, they don't do much more than cut grass. My purpose is mowing less than an acre with hills and several trees at the rear of the yard. I also am putting in a garden, so a tiller will be used. light loader work with mulch and fill for flower beds as well. It seems the 1860 will do the job, however I have heard here that the 2360 has substantially more power. Also, what is a good price? tractor/loader/MMM.?? is it worth the extra $$ to jump up??
Thanks for the help!!
/ BX1860 or 2360? #2
The 2360 does have substantially more power if you consider it in terms of percntage more. It's about 28% more. 18 HP in a Diesel 4WD SCUT is a powerhouse and 23 HP in a Diesel 4WD SCUT is a Super Powerhouse. If comparing to a gas 2WD of equal HP they are not on the same planet. Check the weight difference is a good rule of thumb in my opinion on equipment that has to do heavy duty work. Tractor and implements. If you are a "Tim The Toolman" (UGH! MORE POWER) follower then go for the 23 HP between the 2 choices but alway realize there is a BX2660 that will drag you down the street backwards laughing all the way. Now past mentalities into job duties, get the BX1860 for your needs, it will do everything you have described and sooooooo much more.:) If you can be happy knowing you can whip some others (18HP )but also knowing there's someone out there that can kick your butt (26HP) then do the BX2360. If you have to kick all takers then the BX2660. Again the BX1860 will do all your needs at this time as you've described but just do an honest self appraisal of your personality then pull the trigger.:) Course if you have to have the "more power" you can justify it to yourself and others by the old "but my needs may change and then I'll be underpowered and have to trade again and lose a lot of money and I'm actually saving a lot of money by getting what I'll need later now" justification statement that man has used since near the beginning of time. :D
/ BX1860 or 2360? #3
What size mower deck do you want? I would have to have a 48", and I believe that is only available with the BX1860. The BX2360 has standard cruise control, whick I think is optional on the BX1860. I really like the cruise control on my L3940, and would have to get it on this tractor too. I am leaning towards a BX1860 with 48" mmm and loader and snowblower to replace my 1995 JD LX188 (17.5 hp liquid cooled v-twin) with 48" mmm and snowblower. You can get retail pricing by building your own tractor on Kubota's web site. Philip.
/ BX1860 or 2360? #4
Remember that the PTO HP (needed for the tiller) will be quite a bit less than the rated engine HP. Verify this before making your decision.
Before I purchased my BX2350, I also looked at the 1850. The cost difference was maybe $400 IIRC which wasn't worth the savings. Nobody complains that their machine has "too much power".
/ BX1860 or 2360? #5
I choose the BX2660 because of the comfort factor as well as power, but between the two mentioned, I would go with the BX2360.
The 1860 is a little shorter, has smaller tires and a little bit tighter turning radius according to what owners have posted, but I like bigger tires for a smoother ride and the turning radius isn't that much. That being said, neither would be a "mistake" and should meet your needs quite well.
/ BX1860 or 2360?
Thanks for the info. I got a quote for 1860 @ 11,950. Is that a good Price? The 2360 is another 1500 more so 13,450. Both are with a 54in MMM and loader. I think the 2660 is way overkill for my needs.
/ BX1860 or 2360? #7
Your quotes seem accurate. I bought the 1860 and power is never an issue. In my experience, I run out of traction before losing power. Not so very long ago, this 18 hp, 3 cyl diesel was the engine Du Jour of both the L series and the B series.
I also found $900 gap between these models, which is understandable, to make them fit a marketing slot. If money is no object, the 2660 has it all. For the base, tractor only price of $8800 for the 1860, I don't think it can be beat. Shoot, that's a big lawn mower price and look how more a BX does!!
If I really, really, felt I needed to feed the Tim, the Toolman, Taylor addiction of "more power", I'd either go with the BX2660 for it's great features, or for only $700 more, go all the way to a B2320 and have the taller ground clearance for gardening chores. See how this goes? Each "step" is just another few bucks.....:D:D
/ BX1860 or 2360?
Remember my lawn is under an acre.... But a Like your thinking...:D
/ BX1860 or 2360? #9
1*I have heard here that the 2360 has substantially more power.
2* is it worth the extra $$ to jump up??
1*I have a BX1500 with 15 hp which is more than enough power therefore the 1860 with 18HP is more then sufficent.
2*Either of them is a good choice.
and is worth the money - it depends on your preferences.
3* I would have to have a 48",
Philip.
3* why do you have to have a 48"?
I prefer at last a 54* maybe even a 60 inch because they leave less to trim with a back breakin string trimmer.
4*The 1860 is a little shorter.
5*It has smaller tires and a little bit tighter turning radius according to what owners have posted.
6*I like bigger tires for a smoother ride and the turning radius isn't that much. That being said, neither would be a "mistake" and should meet your needs quite well.
4*This BX1500 is the same size as a BX1860.
5*Same as this BX1500.
6*My BX23 has the same size tires as a BX2660
Since I have owned both sizes of these tractors with both the larger and smaller tires Ive not noticed any difference in ride between them .
The difference in tire size evidently is so insignificant it does not show up riding or operating them .
/ BX1860 or 2360? #10
I do not 'have to have' but would prefer the 48" mmm. I currently have a 48" mmm on my JD LX188 and it suits my mowing duties well, fits between all three of my gate post, fits in my mini barm, and with a little rubbing, fits between the wheel wells of my truck. I have the L3940 with 72" rd finish mower for the big areas so I don't really need a 54" or 60" deck. Philip
/ BX1860 or 2360?
So, you like the Bx1500? the dealer is telling me that the 2360 is the way to go, but the 1860 is a lot cheaper. I do not want to be cheap and have heard people say you can not buy too much, only too little. I am leaning towards the 1860 with the 54" MMM and loader. All for 11,950. Think that sounds like a good deal. My wife, said I could spend 3k. Ha, she is going to be very angry with me. Maybe I'll let her mow BEFORE I tell her the price.....
/ BX1860 or 2360? #12
whatever you buy . . . don't let your wife drive it, or even near it.
just my free unsolicited advice- shrekbelly, bx2360 driver
/ BX1860 or 2360? #13
I don't know about prices. I just contact Barlows to see their price delivered and then go from there. You can to. I had a B7800, traded it for a L3240HST then traded it to a B3200. So, I for one am telling you that you can buy/go to much and that's from buying 9 Kubotas in 6 years. As others have stated, you'll run out of traction before you run out of HP on the BX1860. A BX1860 will do all the jobs you described and more. If you want to spend more then buy a bigger one. Ask your dealer why he thinks you need a BX2360 over a BX1860. Maybe he makes $37.50 or $100 more on the BX2360 over the BX1860 or maybe he doesn't have a BX1860 on his lot and is having to pay a little extra to get one or maybe a trip to Disney World if he sells more BX2360's. Who knows if he won't/can't give you a real answer that matches the jobs you tell him you want to do with the tractor.
/ BX1860 or 2360? #15
leaving my wonderful goddess wife out of the garage and off/away from my bx is mandatory.
on a more serious note, i choose bx2360 for greater power at pto for the use of a tiller.
bx2360 has 1" greater clearance, which may make horsing the mower deck out easier. the two 48" decks have a set of fixed front gauge wheels. both 54" decks have 4 wheels that can be turned sideways for easier rollout
bx1860 will run either of the 54" decks, standard or finecut.
i should probably be in the outdoor power equipment junkie's hall of shame, as i will admitt to getting addicted to the sweet purrings of all the honda gx ohv motors (5 to 8hp) . . . but, there is in my opinion, no finer music than the gurgling and bubbling of my d902 kubota diesel. what a sweet and powerful
3 cyclinder . amen - shrekbelly
/ BX1860 or 2360? #16
1*I do not 'have to have' but would prefer the 48" mmm. I currently have a 48" mmm on my JD LX188 and it suits my mowing duties well, fits between all three of my gate post, fits in my mini barm, and
2*with a little rubbing, fits between the wheel wells of my truck.
3*I have the L3940 with 72" rd finish mower for the big areas so I don't really need a 54" or 60" deck. Philip
1* I replaced a CC GT2554 with a 54 ''mmm.
with a Kubota BX1500 with 48'' mower.
Wish I'd have gotten the 54 '' mower for the BX1500.
When mowing along side of walls fences and such I have to watch that I don't scrape the fenders on what I'm mowing along.
Banks and ditches present another problem as you have to stay further away from the edge to prevent caving in which results in more area to weed trim .
Your JD and the CC I had are built narrower than the BX1500 or BX1860 so a 48'' don't work as well as they do on the narrower tractors.
2*I would not recommend hauling a BX1860 or a BX2660 in a pick up truck bed.
3*I have a 60'' mmm on the BX23 for the larger open area but i still miss having a 54'' mower like I had on the CC for the rest of the property.
1*So, you like the Bx1500? the dealer is telling me that the 2360 is the way to go, but the 1860 is a lot cheaper.
2*I do not want to be cheap and have heard people say you can not buy too much, only too little.
3*I am leaning towards the 1860 with the 54" MMM and loader. All for 11,950.
1*I love both of mine; but I also like my Bx23 too.
2*That just isn't true .
The best is the right tractor for the task intended.
3*I see nothing wrong with that.
I bought my BX23 new 11/2004 and have put over 1200 hours on it doing more than you can ever imagine .
It has always suprised me and never dissapointed me.
In 2007 I bought 2 BX1500s 1 new 1 used .
It didn't take long for me to realize I could have done everything i did with the BX23 except BH work with the BX1500 .
Id' say i discovered this within the first week or 2 of owining the BX1500s.
/ BX1860 or 2360? #17
to the OP, from what you've described as your tractor needs, the 1860 will be more than enough. Between the two tractors, I see two measurable differences, and one is not really a tractor difference. First, the FEL for the 2360 will lift more weight - about 500 lbs max vs 410 +/- for the 1860. That difference is due to the loader model, not tractor as they both put out the same hydraulic PSI and flow. Second, PTO hp. The 2360 is about 17 PTO hp while the 1860 is 13.7 hp. The PTO hp difference may be important if you're going to run a chipper or some other power eating rear PTO implement. (Nevertheless, my 1860 runs a DR chipper with no issues up to about 4" diameter branches.)
So, if either of these differences truly matters to you, then go for the 2360, otherwise the 1860 will do all you want and then some.
/ BX1860 or 2360? #18
To the OP: You began with saying, "Both would be overkill".
You also mentioned your wife and her preference for keeping within a budget.
You mentioned limiting your size due to gates, shedding, etc.
From all that, I'd say keep your money. If the BX1860 is overkill, then so be it. You are gonna love it!!! I love mine. Want to see it work?
YouTube - DSCF1634.AVI
YouTube - BX1860 Working II
/ BX1860 or 2360? #19
Point taken about the BX1860 being wider than the JDLX188 and the deck not sticking out past the rear fenders. I will look into that detail during the Farm show next month in Louisville. Thanks.
I think the bed on my SuperDuty will eat the BX1860 without any problems. My ramps are rated 1500#. Truck is rated 2200#. For a quick trip or small job, I dont always like dragging out the 18' trailer.
Philip
/ BX1860 or 2360? #20
Just keep in mind, the 1860 alone, dry, weighs almost 1300. Add fuel, mower deck, or FEL, quick hitch, etc and you'll easily push the limits on your ramp. Your 2200 bed capacity is well able. I might be concerned about lashing it down, but I am sure you have that figured out already. Best regards on your shopping.
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2019 Volvo VNR64T T/A Sleeper Cab Truck Tractor (A61573)
2019 Volvo VNR64T...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
2016 Eager Beaver 20XPT 27ft 24 Ton T/A Tag Trailer (A61573)
2016 Eager Beaver...
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
